Do you know this problem? (SUP720 problem)
Soon Kwan Kwon
Level 7
Level 7
Problem)
I have WS-SUP720-3B and compact flash.
Using the compact flash adaptor, I did boot SUP.
However, continuously entered rommon mode.
Steps below)
First of all, I inserted another compact flash into the disk0:
and then entered boot disk0:s72033-ipservicesk9_wan-mz.122-18.SXF16.bin command.
Second, after I entered privileged mode.
Router#show sup-bootdisk
-#- --length-- -----date/time------ path
1     80175620 May 22 2015 07:04:20 s72033-ipservicesk9_wan-mz.122-18.SXF16.bin
Router#conf t
Router(config)#boot system sup-bootdisk:s72033-ipservicesk9_wan-mz.122-18.SXF16.bin
Router(config)#end
Router#wr
Router#reload
------------------------------------------------------------------------------------but
rommon>
definitely
register value : 0x2102
SP power on
Maybe you know what can I do?
I'm waiting for your replyㅠ_ㅠ
2 Accepted Solutions
InayathUlla Sharieff
I expect the flash file is good and verified.
Do the following thing from Rommon mode:-
dev
set
sync
reset
boot disk0:imagename
Once the device is back up then:-
conf-reg 0x2102
remove previous boot commands and try boot disk0:image name
wr
reload
Inayath
Here you go for the last time:-
config t
boot system flash bootdisk:s72033-ipservicesk9_wan-mz.122-18.SXF16.bin
wr
reload
I will wait for your reply.
Inayath
*Plz rate all usefull posts.
13 Replies 13
dev
set
sync
reset
conf-reg 0x2102
wr
reload
Inayath
wow Thank you so much!
I'm in subway.. So after I come back to the PC, I'll give a try!
And let you know what's going on!^^
Ah..... I want to boot sup-bootdisk Not disk0:..
The reason that I use compact flash into the disk0: is just using the booting IMAGE...
because,, although I entered boot system sup-bootdisk: IOS NAME command, continuously entered rommon mode...
So I want to know how to boot using the sup-bootdisk: !!ㅠ_ㅠ
I really don't know;;;';
Sure no problem just verify the image once again on the sup-bootdisk.
Then check show bootvar and verify that it is set correctly.
Else provide me the output of show ver & show bootvar
REgards
inayath
Ok inayath, wait a minute plz.
I tried below command.
Router#show bootvar
BOOT variable =
CONFIG_FILE variable does not exist
BOOTLDR variable =
Standby is not present.
Router#
Router#
2     80465924 Jan 05 2000 21:52:38 s72033-ipservices_wan-mz.122-18.SXF8.bin
351412224 bytes available (160653312 bytes used)
Router#
Router#
Router#
Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#$ sup-bootdisk:s72033-ipservicesk9_wan-mz.122-18.SXF16.bin
Router(config)#do wr
Building configuration...
[OK]
Router(config)#end
00:04:22: %SYS-5-CONFIG_I: Configured from console by console
Router#show run
Current configuration : 1143 bytes
upgrade fpd auto
version 12.2
service timestamps debug uptime
service timestamps log uptime
service counters max age 10
hostname Router
no aaa new-model
ip subnet-zero
mls ip multicast flow-stat-timer 9
no mls flow ip
no mls flow ipv6
no mls acl tcam share-global
 --More--
After that,
Router#show bootvar
BOOT variable = sup-bootdisk:s72033-ipservicesk9_wan-mz.122-18.SXF16.bin,12;
BOOTLDR variable =
Router#
Router#show ver
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Wed 08-Feb-06 13:31 by kellmill
Image text-base: 0x40021040, data-base: 0x42B48000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXE5, RELEASE SOFTWARE (fc1)
Router uptime is 7 minutes
Time since Router switched to active is 6 minutes
System returned to ROM by reload at 04:15:11 UTC Tue Jun 9 2015 (SP by reload)
System image file is "disk0:s72033-ipservicesk9-mz.122-18.SXE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6503-E (R7000) processor (revision 1.3) with 458720K/65536K bytes of memory.
Processor board ID FOX095205V1
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
1 Virtual Ethernet/IEEE 802.3 interface
2 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Router#
Router#relod
Router#reload
Proceed with reload? [confirm]
00:08:00: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
00:08:03: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:08:03: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
00:08:03: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:08:05: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*** --- SHUTDOWN NOW ---
00:08:05: %SYS-SP-5-RELOAD: Reload requested
00:08:05: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
00:08:06: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
System Bootstrap, Version 8.1(3)
Copyright (c) 1994-2004 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot executing command: "boot "
Read cis from dev 1 error (-6)device does not contain a valid magic number
boot: cannot open "bootflash:"
boot: cannot determine first file name on device "bootflash:"
rommon 1 >
rommon 1 > set
PS1=rommon ! >
LOG_PREFIX_VERSION=1
SLOTCACHE=cards;
CRASHINFO=crashinfo_FAILED
RANDOM_NUM=552461918
?=0
TYFIB_BLOCK_ALLOC=
BSI=0
ACL_DENY=0
PF_REDUN_CRASH_COUNT=0
BOOT=bootdisk:s72033-ipservicesk9_wan-mz.122-18.SXF16.bin,12;
RET_2_RTS=04:28:34 UTC Tue Jun 9 2015
RET_2_RCALTS=1433824113
rommon 2 >
again... rommon... why still entered rommon ㅠㅠah..
Does this happens with the Disk0?
Second whats the bootvar at the SP mode:
remote command switch show bootvar & show ver ?
Inayath
Q : Does this happens with the Disk0?
A : No, It is occurred only sup-bootdisk
Q : Second whats the bootvar at the SP mode:
A : I don't understand its mean..
rommon 2 > dir disk0:
Directory of disk0:
2      40583140  -rw-     s72033-ipservicesk9-mz.122-18.SXE5.bin
rommon 3 > dir bootflash:
dir: cannot open device "bootflash:"
rommon 4 > dir sup-bootflash:
bad device name (device not supported)
usage: dir <device>
rommon 5 > dir sup-bootdisk:
usage: dir <device>
ine too large ***
I did not enter Router# mode using the sup-bootdisk !! ;;
Q : remote command switch show bootvar & show ver ?
A :
Router#remote command switch show bootvar
BOOT variable = bootdisk:s72033-ipservicesk9_wan-mz.122-18.SXF16.bin,12;
BOOTLDR variable does not exist
Router#
Router#
Router#
Router#show ver
Router uptime is 1 minute
Time since Router switched to active is 0 minutes
System returned to ROM by  power cycle at 04:28:28 UTC Tue Jun 9 2015 (SP by power on)
export@cisco.com.
Bridging software.
Okay last can you try this command:-
conf t
no boot <Previous command> the configure the below
boot system flash sup-bootdisk:s72033-ipservicesk9_wan-mz.122-18.SXF16.bin
wr
reload
Let me know th result
Inayath
wow.... Failed..haha ㅠㅠ..
I tried this..
Router>en
Router#
Router#
Router#
Router#show run
Current configuration : 1150 bytes
upgrade fpd auto
version 12.2
hostname Router
no aaa new-model
ip subnet-zero
no mls flow ip
no mls flow ipv6
Router#conf t
Router(config)#no boot system flash sup-bootdisk:s72033-ipservicesk9_wan-mz.122-18.SXF16.bin
Router(config)#end
Router#
00:03:17: %SYS-5-CONFIG_I: Configured from console by console
Router#boot system flash sup-bootdisk:s72033-ipservicesk9_wan-mz.122-18.SXF16.bin
Router#wr
00:04:01: %SYS-5-CONFIG_I: Configured from console by console[OK]
Router#
Router#
Router#reload
00:04:09: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
00:04:12: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:04:12: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
00:04:12: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:04:15: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:04:15: %SYS-SP-5-RELOAD: Reload requested
00:04:15: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
00:04:15: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
rommon 1 >
Maybe.. Isn't there another method to solve it.......?
config t
wr
reload
Inayath
OK wait a minute plz!
Again .rommon...
maybe hardware problem?
but SP power on!! ㅠㅠ
Anyway .. Thank you ...
and I choose your answering!
