{ DRDY ERR },{ UNC } and Error 096 on 1006-x router, while file coping
Ram1100
I got the below error while coping a OS file form hard disk to the standby hard disk on CICO 1006-x router, Can someone explain what this issues is and how to fix this. Suspecting this is hard disk issue,
Error 096 in res 41/40:08:18:20:00/00:00:00:00:00/40 Emask 0x409 (media error): This indicates a media error, which typically means there is an issue with the hard disk itself, such as bad sectors or a failing drive.
%IOSXE-3-PLATFORM: R0/0: kernel: ata1.00: status: { DRDY ERR }: The "DRDY ERR" status means that the device is ready, but an error has occurred.
%IOSXE-3-PLATFORM: R0/0: kernel: ata1.00: error: { UNC }: The "UNC" error stands for "Uncorrectable Error," which means that the data on the disk cannot be read or corrected.
I tried to copy the files from remote server, but not alloing and giving the below error
%Error opening harddisk:/Test_file.txt (Permission denied)
Mark Elsen
                    >Suspecting this is a hard  disk issue
      Yes the hard disk is failing ; check if you can   do
      router      # fsck   harddisk:
            You will probably need to replace it ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Unable to find the harddisk form in the router after running the command. Any  suggestions
   - Post the output of   dir  (command)
M.
       Beauty and terror
      Just keep going
       No feeling is final
RMA the HDD.
