DS3 per-packet Load-sharing???
john.dean
Problem Details: I am trying to do per-packet load sharing across two DS3 circuits to
achieve 88Mb aggregate.
Attempting to use per-packet load sharing on the DS3 interfaces results in
dangerously high cpu utilization.
CEF load sharing appears to be supported only on 7200/7500 platform...
Q1. Is per-packet load sharing on DS3's even a realistic goal on this platform...
Q2. Is there any other way to aggregate DS3's (other than an Imux) that I
am not aware of?
>>> hardware details <<
cisco 7140-2T3 (EGR) processor (revision A) with 122880K/73728K bytes of
memory.
Processor board ID 4501867
R7000 CPU at 262Mhz, Implementation 39, Rev 1.0, 256KB L2, 2048KB L3 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
2 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
125K bytes of non-volatile configuration memory.
125440K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
wkumari
You should be able to do multilink PPP. This may or may not use even more CPU.
CEF load-sharing is supported on more than the 7200/7500 series and I suspect it is on the 7140 too.
Did you configure the per-packet on the outgoing interfaces?
Other than that you may want to consider upgrading the router. The 7140 is end of life and if you have that much traffic it is probably with having a newer / more capable router....
Warren
