DS3 to T1s
m.palisson
We have a 3845 with T3 link, and want to resell 10-20 T1s to customers. We were initially thinking of a bunch of NM-2MFT-T1 dual-T1 cards with NM-2FE-2W network modules, to buy as customer base grows.
Is there a better and cheaper to do that, considering we would reach our max. within one year ?
Thanks!
Max
wong34539
Level 6
Level 6
I think the NM-2MFT-T1 dual T1 cards and the NM-2FE-2W cards are the best option. Taking the scalability factor into consideration i would still suggest that you use the above mentioned cards for the network.
