EIGRP Between Two Networks
Islam Nadim
Level 3
Level 3
Hello All,
I have a network built on GNS3 where I have a router that acts as a Crypto Gateway that connects to another router on a different remote network.
This is one portion of the network. I have EIGRP Running on both, the VPN and LAN Routers. I have the same on the other side.
The other side exists on a physical remote network and the VPN Routers on both ends communicate with the public IPs. I can reach LAN-to-LAN.
BUT, I have to create a default route on the LAN routers which I don't want to. I want the EIGRP Routes to traverse between the two VPN routers. Or at least, the VPN router sends a default route to the LAN Router.
I actually prefer if it is possible to traverse the EIGRP Routes.
5 Replies 5
willwetherman
Hi Islam,
An IPSec tunnel only transmits/receives unicast IP traffic so EIGRP messages (OSPF as well) will not be communicated between your VPN routers via IPSec alone.
You will need to create a GRE tunnel between the VPN routers (or LAN routers depending on the requirement) which will allow EIGRP packets to be encapsulated and sent between devices allowing them to establish an EIGRP adjacency. Once EIGRP has established then you will be able to propagate the required routes between your LAN routers.
Thank you! I totally forgot about the GRE Tunnels .. I forgot how it was configured. Can you guide me? This is my current configuration:
VPN Router:
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key address
crypto ipsec transform-set TS esp-3des esp-md5-hmac
crypto map CMAP 10 ipsec-isakmp
set peer
set transform-set TS
match address VPN-TRAFFIC
interface FastEthernet0/0
ip address 10.10.2.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.250 255.255.255.0
duplex auto
speed auto
crypto map CMAP
router eigrp 50
network 10.10.2.0 0.0.0.255
network 192.168.1.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 10.10.4.0 255.255.255.0 ! This is done to overcome the routing issue
ip access-list extended VPN-TRAFFIC
permit ip 10.10.2.0 0.0.0.255 10.10.4.0 0.0.0.255
permit ip 10.10.0.0 0.0.255.255 any
access-list 25 permit 10.10.0.0 0.0.255.255
line vty 0 4
access-class 25 in
login local
LAN Router:
ip address 10.10.2.2 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 50
no auto-summary
ip route 0.0.0.0 0.0.0.0 10.10.2.1
line vty 0 4
login local
Best Regards,
Islam M. Nadim.
Hi Islam,
Example configs below assuming GRE between the VPN routers. New config in bold
VPN Router 1:
encr 3des
hash md5
group 2
set peer
interface loopback 0
ip address 10.1.1.2 255.255.255.255
interface tunnel 0
ip address 10.10.24.1 255.255.255.0
tunnel source loopback 0
tunnel destination 10.1.1.4
description LAN
duplex auto
speed auto
description WAN
duplex auto
speed auto
crypto map CMAP
router eigrp 50
network 10.10.24.0 0.0.0.255
no auto-summary
permit gre host 10.1.1.2 host 10.1.1.4
VPN Router 2:
encr 3des
hash md5
group 2
set peer
ip address 10.1.1.4 255.255.255.255
interface tunnel 0
ip address 10.10.24.2 255.255.255.0
tunnel destination 10.1.1.2
description LAN
ip address 10.10.4.1 255.255.255.0
duplex auto
speed auto
description WAN
ip address
duplex auto
speed auto
crypto map CMAP
router eigrp 50
network 10.10.4.0 0.0.0.255
no auto-summary
permit gre host 10.1.1.4 host 10.1.1.2
Hello willwetherman,
     Apologies for the late reply, as per your updated config, will the data traffic pass between the routers, or shall I permit it to the access list?
permit ip host 10.1.1.4 host 10.1.1.2
Hi Islam,
The data traffic will be encpsulated by GRE before encryption so you do not need to match the data traffic in the crypto access list.
Will
