EIGRP/BGP routing loop Help
powermann
Community Member
Hi Guys.I am trying to learn BGP and  I have been playing around with a BGP lab config using GNS3. It calls for different autonomous systems running different IGPs and these atonomous systems are connected via eBGP. iBGP is also running withing the AS.  The router are are all connected via loop back addresses. To achieve full BGP connectivity the redistibute connected command is used under the BGP process on each router. There is no redistribution with IGPs. No filtering or router manipulaiton is being performed as yet.
There is a problem within the AS that is running EIGRP and iBGP. When i do the debug ip routing and debug bgp updates on these routers i see where the router's   loopback is being learn by learn via iBGP and then withdrawn and the relearned via EIGRP and the flapping continues. I have shut down all outgoing connections from these routers and they are in essence connected back to back just now and the problem still continues.
I would love some advice on this issue. Thanks in advance.
Some configs are listed below.
-------R6------R7-------
R6#sho ver
Cisco IOS Software, 3700 Software (C3745-ADVENTERPRISEK9_IVS-M), Version 12.4(15)T8, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Mon 01-Dec-08 20:17 by prod_rel_team
ROM: ROMMON Emulation Microcode
ROM: 3700 Software (C3745-ADVENTERPRISEK9_IVS-M), Version 12.4(15)T8, RELEASE SOFTWARE (fc3)
R6 uptime is 3 days, 19 hours, 54 minutes
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19
System image file is "tftp://255.255.255.255/unknown"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3745 (R7000) processor (revision 2.0) with 249856K/12288K bytes of memory.
Processor board ID FTX0945W0MY
R7000 CPU at 350MHz, Implementation 39, Rev 2.1, 256KB L2, 512KB L3 Cache
3 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
151K bytes of NVRAM.
16384K bytes of ATA System CompactFlash (Read/Write)
R6: sho run
interface Loopback0
ip address 6.6.6.6 255.255.255.255
interface FastEthernet0/0
ip address 192.168.46.6 255.255.255.0
shutdown
speed 100
full-duplex
interface FastEthernet0/1
ip address 192.168.56.6 255.255.255.0
shutdown
speed 100
full-duplex
interface FastEthernet1/0
ip address 192.168.67.6 255.255.255.0
duplex auto
speed auto
router eigrp 10
network 6.6.6.6 0.0.0.0
network 192.168.67.0
no auto-summary
router bgp 200
no synchronization
bgp log-neighbor-changes
redistribute connected
neighbor 4.4.4.4 remote-as 300
neighbor 4.4.4.4 ebgp-multihop 2
neighbor 4.4.4.4 update-source Loopback0
neighbor 5.5.5.5 remote-as 300
neighbor 5.5.5.5 ebgp-multihop 2
neighbor 5.5.5.5 update-source Loopback0
neighbor 7.7.7.7 remote-as 200
neighbor 7.7.7.7 update-source Loopback0
no auto-summary
ip forward-protocol nd
ip route 4.4.4.4 255.255.255.255 192.168.46.4
ip route 5.5.5.5 255.255.255.255 192.168.56.5
R7: sho run
interface Loopback0
ip address 7.7.7.7 255.255.255.255
ip address 192.168.67.7 255.255.255.0
speed 100
full-duplex
ip address 192.168.117.7 255.255.255.0
shutdown
duplex auto
speed auto
router eigrp 10
network 7.7.7.7 0.0.0.0
auto-summary
router bgp 200
no synchronization
neighbor 6.6.6.6 remote-as 200
neighbor 6.6.6.6 update-source Loopback0
neighbor 11.11.11.11 remote-as 400
neighbor 11.11.11.11 password VAULT
neighbor 11.11.11.11 ebgp-multihop 2
neighbor 11.11.11.11 update-source Loopback0
no auto-summary
ip route 11.11.11.11 255.255.255.255 192.168.117.11
R6: debug ip routing and debug bgp updates
Mar  4 19:59:03.597: RT: del 7.7.7.7/32 via 7.7.7.7, bgp metric [200/0]
*Mar  4 19:59:03.601: RT: delete subnet route to 7.7.7.7/32
*Mar  4 19:59:03.601: RT: NET-RED 7.7.7.7/32
*Mar  4 19:59:03.617: RT: Try lookup less specific 7.7.7.7/32, default 1
*Mar  4 19:59:03.621: RT: Found major net on less specific 7.0.0.0/8
--More--
*Mar  4 19:59:30.257: RT: network 7.0.0.0 is now variably masked
*Mar  4 19:59:30.261: RT: add 7.7.7.7/32 via 7.7.7.7, bgp metric [200/0]
*Mar  4 19:59:30.265: RT: NET-RED 7.7.7.7/32
--More--
*Mar  4 19:59:35.369: RT: del 7.7.7.7/32 via 7.7.7.7, bgp metric [200/0]
*Mar  4 19:59:35.373: RT: delete subnet route to 7.7.7.7/32
*Mar  4 19:59:35.377: RT: NET-RED 7.7.7.7/32
*Mar  4 19:59:35.389: RT: Try lookup less specific 7.7.7.7/32, default 1
*Mar  4 19:59:35.393: RT: Found major net on less specific 7.0.0.0/8
*Mar  4 20:01:34.265: RT: network 7.0.0.0 is now variably masked
*Mar  4 20:01:34.269: RT: add 7.7.7.7/32 via 7.7.7.7, bgp metric [200/0]
*Mar  4 20:01:34.273: RT: NET-RED 7.7.7.7/32
--More--
*Mar  4 20:01:39.377: RT: del 7.7.7.7/32 via 7.7.7.7, bgp metric [200/0]
*Mar  4 20:01:39.381: RT: delete subnet route to 7.7.7.7/32
*Mar  4 20:01:39.381: RT: NET-RED 7.7.7.7/32
*Mar  4 20:01:39.397: RT: Try lookup less specific 7.7.7.7/32, default 1
*Mar  4 20:01:39.401: RT: Found major net on less specific 7.0.0.0/8
The following also appears in the logs
*Mar  4 20:23:23.137: RT: recursion error routing 7.7.7.7 - probable routing loop
*Mar  4 20:23:23.449: RT: recursion error routing 7.7.7.7 - probable routing loop
*Mar  4 20:23:23.917: RT: recursion error routing 7.7.7.7 - probable routing loop
*Mar  4 20:23:24.057: RT: recursion error routing 7.7.7.7 - probable routing loop
*Mar  4 20:23:24.065: RT: recursion error routing 7.7.7.7 - probable routing loop
--More--
*Mar  4 20:23:24.669: RT: recursion error routing 7.7.7.7 - probable routing loop
*Mar  4 20:23:25.289: RT: recursion error routing 7.7.7.7 - probable routing loop
--More--
*Mar  4 20:23:25.893: RT: recursion error routing 7.7.7.7 - probable routing loop
--More--
*Mar  4 20:23:27.737: RT: recursion error routing 7.7.7.7 - probable routing loop
*Mar  4 20:23:28.357: RT: recursion error routing 7.7.7.7 - probable routing loop
--More--
*Mar  4 20:23:32.633: RT: recursion error routing 7.7.7.7 - probable routing loop
*Mar  4 20:23:33.297: RT: recursion error routing 7.7.7.7 - probable routing loop
--More--
*Mar  4 20:23:38.825: RT: del 7.7.7.7/32 via 7.7.7.7, bgp metric [200/0]
*Mar  4 20:23:38.829: RT: delete subnet route to 7.7.7.7/32
*Mar  4 20:23:38.833: RT: NET-RED 7.7.7.7/32
*Mar  4 20:23:38.849: RT: Try lookup less specific 7.7.7.7/32, default 1
*Mar  4 20:23:38.849: RT: Found major net on less specific 7.0.0.0/8
Mar  4 20:44:05.952: BGP(0): no valid path for 7.7.7.7/32
*Mar  4 20:44:06.044: BGP(0): nettable_walker 7.7.7.7/32 no best path
*Mar  4 20:44:06.048: RT: del 7.7.7.7/32 via 7.7.7.7, bgp metric [200/0]
*Mar  4 20:44:06.048: RT: delete subnet route to 7.7.7.7/32
*Mar  4 20:44:06.052: RT: NET-RED 7.7.7.7/32
*Mar  4 20:44:06.068: RT: Try lookup less specific 7.7.7.7/32, default 1
*Mar  4 20:44:06.072: RT: Found major net on less specific 7.0.0.0/8
R6#
*Mar  4 20:44:31.300: BGP(0): Revise route installing 1 of 1 routes for 7.7.7.7/32 -> 7.7.7.7(main) to main IP table
*Mar  4 20:44:31.304: RT: network 7.0.0.0 is now variably masked
*Mar  4 20:44:31.308: RT: add 7.7.7.7/32 via 7.7.7.7, bgp metric [200/0]
*Mar  4 20:44:31.312: RT: NET-RED 7.7.7.7/32
R6#
*Mar  4 20:44:36.328: BGP(0): no valid path for 7.7.7.7/32
*Mar  4 20:44:36.444: BGP(0): nettable_walker 7.7.7.7/32 no best path
*Mar  4 20:44:36.448: RT: del 7.7.7.7/32 via 7.7.7.7, bgp metric [200/0]
*Mar  4 20:44:36.448: RT: delete subnet route to 7.7.7.7/32
*Mar  4 20:44:36.448: RT: NET-RED 7.7.7.7/32
*Mar  4 20:44:36.456: RT: Try lookup less specific 7.7.7.7/32, default 1
*Mar  4 20:44:36.456: RT: Found major net on less specific 7.0.0.0/8
R6#
*Mar  4 20:45:02.556: BGP(0): Revise route installing 1 of 1 routes for 7.7.7.7/32 -> 7.7.7.7(main) to main IP table
*Mar  4 20:45:02.560: RT: network 7.0.0.0 is now variably masked
*Mar  4 20:45:02.564: RT: add 7.7.7.7/32 via 7.7.7.7, bgp metric [200/0]
*Mar  4 20:45:02.568: RT: NET-RED 7.7.7.7/32
R6#
Thanks in advance.
Marlon
Hello.
EIGRP is using auto-summary that is causing the issue.
In your case EIGRP is advertising classful route (like 7.0.0.0/8), but your BGP peer is advertising more specific 7.7.7.7/32 that will be [recursively] used in the next-hop.
PS: the issue you are observing is not "routing loop" it's a "recursive routing" issue.
PS2: route to iBGP peers [next-hops and tcp endpoints] must be always known/learnt via IGP.
Hello.
Thank you very much. I saw the error and corrected it. That problem is now solved. I now have some route flapping the other routers that i need to sort out. Thanks again.
