EIGRP Redistribute Static
worldcalltel
I have 2 ISPs and each has its own 7206 Router with 3 FA interfaces.
Fa0/0 = WAN going to ISP
Fa0/1 = LAN Public IP Addresses
Fa0/2 = LAN Private IP Addresses
FA0/2 is connected to a layer 3 switch. The layer 3 switch was configured 3 vlans. and a brige group. So on both 7206 router, if i configured both with redistribut static, on what behavior will the layer 3 switch react ? would this be possible ?
Jaime,
What's the static route you're going to do? A default route? I'm not clear about your question.
Technically speaking,L3 switch(running EIGRP) will see those routes as external routes.
Please provide more information.
Toshi
Peter010101
Redistribute static will redistribute static routes.
I think you are looking for redistribute connected which will redistribute your connected interfaces.
