EIGRP will only route to VLAN1 on 4507
thunder_denton
I am setting up Layer 3 switches (3560s) at our remote sites to allow me to use EIGRP and MPLS to add an additional route back to corporate (currently using ASA VPN Tunnels).
From at 4507r+e at corporate on VLAN1, I can reach any computer on any of the VLANs I have setup as Network (and visa versa)....  But ONLY VLAN1 at corporate.
Maybe my version is not correct?  Version 03.09.01.E  I have downloaded the latest version, but I hesitate to do the upgrade if not needed.
I do not know why 10.100.10.0 is not advertised to the core (and that would impact access to anything on the core from that subnet). But I have identified the main reason why the remote can only access vlan 1 of the core. Other than the connected subnet of 10.10.5.0 the core advertises 3 subnets to the remote. It advertises 192.168.100.0 which is vlan 1 and that works. It advertises 192.168.0.0 which is vlan 100 and it does not work. It advertises 172.16.103.0 which is vlan 903 and it does not work. The two vlans that do not work have configured Policy Based Routing. The normal route to get to the Remote is to use connected 10.10.5.2 but the PBR over rides the normal routing and set ip next-hop to a different IP and that prevents traffic from those vlans returning to the remote.
The solution for this issue is to revise the ACL used by PBR for those subnets and make the ACL deny traffic from the core subnets to the remote subnets. This will allow normal routing to take place and the remote will be able to access those subnets.
Rick
Rick
26 Replies 26
Richard Burts
We do not know nearly enough about your environment and about how you have implemented EIGRP to be able to answer your question. Let us know more detail and we try to understand it.
Rick
Rick
Jaderson Pessoa
Dear,
Please provide more detail about your doubt or issue.
Could you post ouput from:
show ip route eigrp
show ip interfaces
show running-config
show ip eigrp interfaces
Jaderson Pessoa
*** Rate All Helpful Responses ***
This is the corporate side...
address-family ipv6
exit-address-family
no logging console
enable secret 4 q1pjUDv7NfMntmdGfrq75jZkci9c7OylfYvP7HX9beE
enable password 7 055C0B0E33555A010B0012564A
username tharris privilege 15 password 7 0800484A000A551943
username rhapsody privilege 15 password 7 1545060D16333F2C3A3630
username thunder privilege 15 password 7 064557721F6A1C1D00
username mikep privilege 15 password 7 073F2D4D401D1C5247
username mplante privilege 15 secret 5 $1$bpUx$AA74dp/6IGMrFTVvKeXlZ/
aaa new-model
CoreSwitch4507#how ip eigrp interfaces
% Invalid input detected at '^' marker.
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#
CoreSwitch4507#show ip route eigrp
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 192.168.0.253 to network 0.0.0.0
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
D 10.10.10.0/24 [90/3072] via 10.10.5.2, 03:33:02, GigabitEthernet7/14
CoreSwitch4507#show ip interfaces
CoreSwitch4507#show running-config
Building configuration...
Current configuration : 43763 bytes
! Last configuration change at 09:52:44 CST Wed Feb 13 2019 by thunder
! NVRAM config last updated at 09:52:46 CST Wed Feb 13 2019 by thunder
version 15.2
no service pad
service password-encryption
service compress-config
hostname CoreSwitch4507
boot-start-marker
boot system flash bootflash:cat4500es8-universalk9.SPA.03.09.01.E.152-5.E1.bin
license boot level entservices
boot-end-marker
vrf definition mgmtVrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no logging console
D 10.10.10.0/24 [90/3072] via 10.10.5.2, 03:33:20, GigabitEthernet7/14
CoreSwitch4507#show ip interface GigabitEthernet7/14
GigabitEthernet7/14 is up, line protocol is up
Internet address is 10.10.5.1/24
Broadcast address is 255.255.255.255
Address determined by setup command
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Multicast reserved groups joined: 224.0.0.10
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP Flow switching is disabled
IP CEF switching is enabled
IP CEF switching turbo vector
IP Null turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Probe proxy name replies are disabled
Policy routing is disabled
Network address translation is disabled
BGP Policy Mapping is disabled
Input features: MCI Check
IPv4 WCCP Redirect outbound is disabled
IPv4 WCCP Redirect inbound is disabled
IPv4 WCCP Redirect exclude is disabled
CoreSwitch4507#
CoreSwitch4507#show ip eigrp interfaces
EIGRP-IPv4 Interfaces for AS(7)
Xmit Queue PeerQ Mean Pacing Time Multicast Pending
Interface Peers Un/Reliable Un/Reliable SRTT Un/Reliable Flow Timer Routes
Gi7/14 1 0/0 0/0 4 0/0 50 0
version 15.2
no service pad
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no logging console
aaa new-model
aaa authentication fail-message ^CCCC
You have entered either incorrect user name or password! Please try again.^C
aaa authentication username-prompt "Enter Username: "
aaa authentication login UserList local
aaa session-id common
clock timezone CST -6 0
clock summer-time DST recurring 2 Sun Mar 2:00 2 Sun Nov 2:00
hw-module module 7 mode 1
ip domain-list lonestar.local
ip domain-lookup source-interface Vlan1
ip domain-name lonestar.local
ip name-server 192.168.0.170
ip name-server 192.168.0.160
ip dhcp-server 172.16.102.1
ip dhcp pool Guest_Wireless
network 172.16.102.0 255.255.255.0
default-router 172.16.102.253
domain-name Lonestar.public
dns-server 4.2.2.2 4.2.2.3
vtp mode transparent
crypto pki trustpoint TP-self-signed-2039194
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2039194
revocation-check none
rsakeypair TP-self-signed-2039194
crypto pki certificate chain TP-self-signed-2039194
certificate self-signed 01
30820225 3082018E A0030201 02020101 300D0609 2A864886 F70D0101 05050030
2E312C30 2A060355 04031323 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32303339 31393430 1E170D31 37303131 39323035 3631375A
170D3230 30313031 30303030 30305A30 2E312C30 2A060355 04031323 494F532D
53656C66 2D536967 6E65642D 43657274 69666963 6174652D 32303339 31393430
819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100 CCDB33A8
F2805831 A56EEAEF 4F7B1FC9 2C54BC45 707C151D 80BD04AD 08B205E4 63E1E5D0
FDA74E32 315AD880 6ADB03F3 F914B3DB 6F835AED 565C5E0F 719CB164 15EC2FB6
B99BB6DB DBB4A3C5 CA9294CE F70C010C 279E8FCE 9DADB329 9B9FB123 1899F035
F3E4B4ED 0B9D0D44 16FA3FF4 4F711B2F 4F53D2C2 496BC2A1 B3F2C86D 02030100
01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D 23041830
16801482 F4D9F9C7 7A8F0AFE A5F2873D 9C8A5791 BF979130 1D060355 1D0E0416
041482F4 D9F9C77A 8F0AFEA5 F2873D9C 8A5791BF 9791300D 06092A86 4886F70D
01010505 00038181 004F71CC 1089F1FF D88B261F D6353B08 E6E52049 9C41AC34
FD986064 E4ECADE1 0FF993BF 324678FC B0E0452A 10AAAAAC DB10D3BF EB147814
C5DAA9A3 0CDF0DCE 2FB20F67 FBB27E29 AC71A0C9 5E94F356 1367A273 1591CDC5
E45382BC 7A3B16CA 92D5735B CD84ADA2 B594980C 3394C033 88608F35 5084E344
01957C8A 6CB82749 6E
quit
power redundancy-mode redundant
archive
log config
record rc
logging enable
logging size 1000
path ftp://192.168.0.101/CoreSwitch4507.txt
spanning-tree mode rapid-pvst
exception coredump
redundancy
mode rpr
main-cpu
auto-sync standard
vlan 10
name IDF B PhonesComputers
vlan 12
name LonestarWireless
vlan 15
name SAN2
vlan 20
name SAN1
vlan 60
name P2P_Spring
vlan 100
name ServersDistribLayer
vlan 200
name CiscoWAPsPADs
vlan 201
name Security
vlan 202
name HVAC
vlan 901
name IDF A PhonesComputers
vlan 902
name Guest_Wireless
vlan 903
name 2nd_Floor
vlan 909
name LonestarCellPhones
bridge irb
interface Port-channel1
description Port Channel Link to IDF B
switchport
switchport trunk allowed vlan 10,12,100,200,201,901-903,909
switchport mode trunk
interface Port-channel2
description Port Channel Link to IDFA
switchport
switchport access vlan 12
interface Port-channel8
description Port Channel link to Lonestar-Core
switchport
interface FastEthernet1
vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface GigabitEthernet1/1
switchport mode access
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface GigabitEthernet1/5
interface GigabitEthernet1/6
interface GigabitEthernet1/7
interface GigabitEthernet1/8
interface GigabitEthernet1/9
interface GigabitEthernet1/10
interface GigabitEthernet1/11
interface GigabitEthernet1/12
interface GigabitEthernet1/13
description Managment Port on SANs
switchport access vlan 20
spanning-tree portfast edge
interface GigabitEthernet1/14
description Managment Port on SANS
interface GigabitEthernet1/15
description P2P going to Spring Clinic
switchport access vlan 60
interface GigabitEthernet1/16
description LSFMWAP15
speed 1000
duplex full
spanning-tree portfast edge trunk
interface GigabitEthernet1/17
description LSFMWAP16
speed 1000
duplex full
interface GigabitEthernet1/18
description WAP
speed 1000
duplex full
interface GigabitEthernet1/19
description WAP
speed 1000
duplex full
interface GigabitEthernet1/20
description Patch Pannel D040
switchport access vlan 10
interface GigabitEthernet1/21
description Director of Busness Development
switchport access vlan 200
interface GigabitEthernet1/22
switchport access vlan 903
interface GigabitEthernet1/23
interface GigabitEthernet1/24
interface GigabitEthernet1/25
interface GigabitEthernet1/26
interface GigabitEthernet1/27
interface GigabitEthernet1/28
interface GigabitEthernet1/29
interface GigabitEthernet1/30
interface GigabitEthernet1/31
interface GigabitEthernet1/32
interface GigabitEthernet1/33
interface GigabitEthernet1/34
interface GigabitEthernet1/35
interface GigabitEthernet1/36
interface GigabitEthernet1/37
interface GigabitEthernet1/38
interface GigabitEthernet1/39
interface GigabitEthernet1/40
interface GigabitEthernet1/41
interface GigabitEthernet1/42
interface GigabitEthernet1/43
interface GigabitEthernet1/44
interface GigabitEthernet1/45
interface GigabitEthernet1/46
interface GigabitEthernet1/47
interface GigabitEthernet1/48
description Printer on VLAN903
interface GigabitEthernet2/1
description Port Channel Link To IDF A
speed 1000
duplex full
no cdp enable
channel-group 2 mode active
interface GigabitEthernet2/2
description Port Channel Link 2 To IDF A
speed 1000
duplex full
interface GigabitEthernet2/3
interface GigabitEthernet2/4
interface GigabitEthernet2/5
description Internet TVs
interface GigabitEthernet2/6
interface GigabitEthernet2/7
interface GigabitEthernet2/8
interface GigabitEthernet2/9
interface GigabitEthernet2/10
interface GigabitEthernet2/11
interface GigabitEthernet2/12
interface GigabitEthernet2/13
description Going to Netgear Switch
switchport access vlan 201
speed 1000
interface GigabitEthernet2/14
description Avaya IP Office Control Unit port 1 on back
interface GigabitEthernet2/15
description POE Netgear G5728TP Switch for Phones
interface GigabitEthernet2/16
description wap
speed 1000
duplex full
interface GigabitEthernet2/17
description wap
speed 1000
duplex full
interface GigabitEthernet2/18
description WAP
speed 1000
duplex full
interface GigabitEthernet2/19
description WAP
speed 1000
duplex full
interface GigabitEthernet2/20
description PDU-A
interface GigabitEthernet2/21
description PDU-A
interface GigabitEthernet2/22
interface GigabitEthernet2/23
interface GigabitEthernet2/24
interface GigabitEthernet2/25
interface GigabitEthernet2/26
interface GigabitEthernet2/27
interface GigabitEthernet2/28
interface GigabitEthernet2/29
interface GigabitEthernet2/30
interface GigabitEthernet2/31
interface GigabitEthernet2/32
interface GigabitEthernet2/33
interface GigabitEthernet2/34
interface GigabitEthernet2/35
interface GigabitEthernet2/36
interface GigabitEthernet2/37
interface GigabitEthernet2/38
interface GigabitEthernet2/39
interface GigabitEthernet2/40
interface GigabitEthernet2/41
interface GigabitEthernet2/42
interface GigabitEthernet2/43
interface GigabitEthernet2/44
interface GigabitEthernet2/45
interface GigabitEthernet2/46
interface GigabitEthernet2/47
interface GigabitEthernet2/48
interface TenGigabitEthernet3/1
description Port Channel FDDI to IDF B Dell Stack
switchport access vlan 100
switchport trunk allowed vlan 10,12,100,200,201,902,909
no cdp enable
interface TenGigabitEthernet3/2
description Port Channel FDDI to IDF A Dell Stack
switchport trunk allowed vlan 10,12,100,200,201,901,902,909
no cdp enable
interface TenGigabitEthernet3/3
interface TenGigabitEthernet3/4
interface TenGigabitEthernet3/5
interface TenGigabitEthernet3/6
interface TenGigabitEthernet3/7
interface TenGigabitEthernet3/8
interface GigabitEthernet6/1
interface GigabitEthernet6/2
description ASA 5510 port 5 NewASA
switchport trunk allowed vlan 10,12,100,200-202,901-903,909
speed 1000
duplex full
interface GigabitEthernet6/3
description ASA 5510 port 0 NewASA
interface GigabitEthernet6/4
description 10GB SW01 oob
interface GigabitEthernet6/5
interface GigabitEthernet6/6
interface GigabitEthernet6/7
interface GigabitEthernet6/8
interface GigabitEthernet6/9
interface GigabitEthernet6/10
interface GigabitEthernet6/11
description Netgear N300 Switch for Pheresia
switchport trunk allowed vlan 1,10,12,15,20,100,200-202,901-903
switchport trunk native vlan 200
interface GigabitEthernet6/12
interface GigabitEthernet6/13
interface GigabitEthernet6/14
interface GigabitEthernet6/15
description B; Connected to Master Cisco AP B+
switchport trunk allowed vlan 1,10,12,15,20,100,200-202,901-903,909
interface GigabitEthernet6/16
interface GigabitEthernet6/17
description B; Connected to Slave Cisco AP B+
interface GigabitEthernet6/18
interface GigabitEthernet6/19
interface GigabitEthernet6/20
interface GigabitEthernet6/21
interface GigabitEthernet6/22
interface GigabitEthernet6/23
interface GigabitEthernet6/24
interface GigabitEthernet6/25
interface GigabitEthernet6/26
interface GigabitEthernet6/27
interface GigabitEthernet6/28
interface GigabitEthernet6/29
interface GigabitEthernet6/30
interface GigabitEthernet6/31
interface GigabitEthernet6/32
interface GigabitEthernet6/33
interface GigabitEthernet6/34
interface GigabitEthernet6/35
interface GigabitEthernet6/36
interface GigabitEthernet6/37
interface GigabitEthernet6/38
interface GigabitEthernet6/39
interface GigabitEthernet6/40
interface GigabitEthernet6/41
interface GigabitEthernet6/42
interface GigabitEthernet6/43
interface GigabitEthernet6/44
interface GigabitEthernet6/45
interface GigabitEthernet6/46
interface GigabitEthernet6/47
interface GigabitEthernet6/48
interface TenGigabitEthernet7/1
description LSFMS-HOST1 LAN On Board Port2
interface TenGigabitEthernet7/2
description LSFMS-HOST1 VM1 On Board Port3
interface TenGigabitEthernet7/3
description LSMFS-HOST2 LAN On Board Port2
interface TenGigabitEthernet7/4
description LSMFS-HOST2 VM1 On Board Port3
interface TenGigabitEthernet7/5
description LSMFS-HOST3 LAN 2nd 10Gig Port 1
interface TenGigabitEthernet7/6
description LSMFS-HOST3 VM1 On Board Port3
interface TenGigabitEthernet7/7
description LSFMS-BACKUP LAN1 PORT1
interface TenGigabitEthernet7/8
description LSFMS-BACKUP LAN2 PORT2
interface TenGigabitEthernet7/9
description LSMFS-HOST4 LAN 2nd 10Gig Port 1
interface TenGigabitEthernet7/10
description LSMFS-HOST4 VM1 On Board Port3
interface TenGigabitEthernet7/11
interface TenGigabitEthernet7/12
interface GigabitEthernet7/13
description LSFMS-DR-HOST NIC
switchport trunk allowed vlan 10,12,15,20,100,199,901,909
speed 1000
duplex full
description P2P going to Hospital port 5
no switchport
ip address 10.10.5.1 255.255.255.0
interface GigabitEthernet7/15
interface GigabitEthernet7/16
description IDF B Dell POE Managment
switchport trunk allowed vlan 10,12,100,200,201,901,909
speed 1000
duplex full
interface GigabitEthernet7/17
description LSFMS-Access
switchport trunk allowed vlan 10,12,15,20,100,199,201,901,909
speed 1000
duplex full
interface GigabitEthernet7/18
no switchport
no ip address
duplex full
interface GigabitEthernet7/19
description Fax Server
interface GigabitEthernet7/20
description Phone Controller
interface GigabitEthernet7/21
description New EPS Pharmacy Server
interface GigabitEthernet7/22
description LFSMS-Backup iDrac
interface GigabitEthernet7/23
description LFSMS-HOST1 iDrac
interface GigabitEthernet7/24
description LFSMS-HOST2 iDrac
interface GigabitEthernet7/25
description LFSMS-HOST3 iDrac
interface GigabitEthernet7/26
description LFSMS-HOST4 iDrac
interface GigabitEthernet7/27
description Test of VLAN 1
interface GigabitEthernet7/28
interface GigabitEthernet7/29
interface GigabitEthernet7/30
interface GigabitEthernet7/31
interface GigabitEthernet7/32
interface GigabitEthernet7/33
interface GigabitEthernet7/34
interface GigabitEthernet7/35
interface GigabitEthernet7/36
interface GigabitEthernet7/37
description PACS
speed 1000
duplex full
interface GigabitEthernet7/38
interface GigabitEthernet7/39
interface GigabitEthernet7/40
interface GigabitEthernet7/41
interface GigabitEthernet7/42
interface GigabitEthernet7/43
interface GigabitEthernet7/44
interface GigabitEthernet7/45
interface GigabitEthernet7/46
description TEMPORARY
interface GigabitEthernet7/47
interface GigabitEthernet7/48
interface Vlan1
ip address 192.168.100.1 255.255.255.0
ip policy route-map PolicyRoute_Distro
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip broadcast-address 192.168.10.255
ip helper-address 192.168.0.50
ip policy route-map PolicyRoute_Access
interface Vlan11
description No Content Filter Restrictions
ip address 192.168.11.1 255.255.255.0
shutdown
interface Vlan12
ip address 192.168.12.1 255.255.255.0
ip broadcast-address 192.168.12.255
ip policy route-map PolicyRoute_Access2
interface Vlan15
description SAN2 iSCSI Access
ip address 192.168.15.1 255.255.255.0
interface Vlan20
description SAN1 iSCSI Access
ip address 192.168.20.1 255.255.255.0
ip broadcast-address 192.168.20.255
ip policy route-map PolicyRoute_SANMgmt
interface Vlan100
ip address 192.168.0.1 255.255.255.0
ip helper-address 192.168.0.101
interface Vlan200
ip address 192.168.200.1 255.255.255.0
ip broadcast-address 192.168.200.255
ip policy route-map PolicyRoute_Wireless
interface Vlan201
ip address 192.168.201.1 255.255.255.0
ip policy route-map PolicyRoute_Security
interface Vlan202
description HVAC And Environmental Controls Network
ip address 192.168.202.1 255.255.255.0
ip policy route-map PolicyRoute_Environment
interface Vlan901
description IDF A Workstations
ip address 172.16.100.1 255.255.255.0
ip broadcast-address 172.16.100.255
ip helper-address 192.168.0.170
ip policy route-map PolicyRoute_901
interface Vlan902
description Guest Wireless Network
ip address 172.16.102.1 255.255.255.0
ip broadcast-address 172.16.102.255
ip helper-address 172.16.102.1
ip policy route-map PolicyRoute_902
interface Vlan903
description 2nd_Floor_VLAN
ip address 172.16.103.1 255.255.255.0
ip broadcast-address 172.16.103.255
ip policy route-map PolicyRoute_903
interface Vlan909
description Lonestar Cell Phones
ip address 172.16.90.1 255.255.255.0
ip broadcast-address 172.16.90.255
ip policy route-map PolicyRoute_909
router eigrp 7
network 10.10.5.0 0.0.0.255
network 172.16.103.0 0.0.0.255
network 192.168.0.0
network 192.168.100.0
passive-interface Vlan1
passive-interface Vlan100
passive-interface Vlan903
ip forward-protocol nd
ip forward-protocol spanning-tree
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.253
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip access-list extended PolicyRoute_1
deny ip 192.168.0.0 0.0.0.255 192.168.0.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.0.255 192.168.10.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.0.255 192.168.20.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.0.255 192.168.30.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.0.255 192.168.40.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.0.255 192.168.99.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.0.255 192.168.100.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.0.255 192.168.101.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.0.255 192.168.200.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.0.255 192.168.201.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.0.255 192.168.202.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.0.255 192.168.254.0 0.0.0.255 log
permit ip 192.168.0.0 0.0.0.255 any
deny ip 192.168.0.0 0.0.0.255 192.168.12.0 0.0.0.255 log
ip access-list extended PolicyRoute_10
deny ip 192.168.10.0 0.0.0.255 172.16.90.0 0.0.0.255
deny ip 192.168.10.0 0.0.0.255 172.16.100.0 0.0.0.255 log
deny ip 192.168.10.0 0.0.0.255 192.168.0.0 0.0.0.255 log
deny ip 192.168.10.0 0.0.0.255 172.16.101.0 0.0.0.255
deny ip 192.168.10.0 0.0.0.255 192.168.1.0 0.0.0.255 log
deny ip 192.168.10.0 0.0.0.255 192.168.10.0 0.0.0.255 log
deny ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255 log
deny ip 192.168.10.0 0.0.0.255 192.168.30.0 0.0.0.255 log
deny ip 192.168.10.0 0.0.0.255 192.168.40.0 0.0.0.255 log
deny ip 192.168.10.0 0.0.0.255 192.168.99.0 0.0.0.255 log
deny ip 192.168.10.0 0.0.0.255 192.168.100.0 0.0.0.255 log
deny ip 192.168.10.0 0.0.0.255 192.168.200.0 0.0.0.255 log
deny ip 192.168.10.0 0.0.0.255 192.168.254.0 0.0.0.255 log
deny ip 192.168.10.0 0.0.0.255 192.168.201.0 0.0.0.255 log
deny ip 192.168.10.0 0.0.0.255 192.168.202.0 0.0.0.255 log
permit ip any any
deny ip 192.168.10.0 0.0.0.255 192.168.12.0 0.0.0.255 log
ip access-list extended PolicyRoute_100
deny ip 192.168.0.0 0.0.0.255 172.16.90.0 0.0.0.255
deny ip 192.168.0.0 0.0.0.255 172.16.100.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.0.255 172.16.101.0 0.0.0.255
deny ip 192.168.0.0 0.0.0.255 172.16.103.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.0.255 192.168.15.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.0.255 172.16.102.0 0.0.0.255
deny ip 192.168.0.0 0.0.0.255 10.10.5.0 0.0.0.255
deny ip 192.168.0.0 0.0.0.255 10.100.10.0 0.0.0.255
ip access-list extended PolicyRoute_12
deny ip 192.168.12.0 0.0.0.255 172.16.90.0 0.0.0.255
deny ip 192.168.12.0 0.0.0.255 172.16.100.0 0.0.0.255 log
deny ip 192.168.12.0 0.0.0.255 192.168.0.0 0.0.0.255 log
deny ip 192.168.12.0 0.0.0.255 172.16.101.0 0.0.0.255
deny ip 192.168.12.0 0.0.0.255 192.168.1.0 0.0.0.255 log
deny ip 192.168.12.0 0.0.0.255 192.168.12.0 0.0.0.255 log
deny ip 192.168.12.0 0.0.0.255 192.168.20.0 0.0.0.255 log
deny ip 192.168.12.0 0.0.0.255 192.168.30.0 0.0.0.255 log
deny ip 192.168.12.0 0.0.0.255 192.168.40.0 0.0.0.255 log
deny ip 192.168.12.0 0.0.0.255 192.168.99.0 0.0.0.255 log
deny ip 192.168.12.0 0.0.0.255 192.168.100.0 0.0.0.255 log
deny ip 192.168.12.0 0.0.0.255 192.168.200.0 0.0.0.255 log
deny ip 192.168.12.0 0.0.0.255 192.168.254.0 0.0.0.255 log
deny ip 192.168.12.0 0.0.0.255 192.168.201.0 0.0.0.255 log
deny ip 192.168.12.0 0.0.0.255 192.168.202.0 0.0.0.255 log
permit ip any any
deny ip 192.168.12.0 0.0.0.255 192.168.10.0 0.0.0.255 log
ip access-list extended PolicyRoute_15
deny ip 192.168.15.0 0.0.0.255 192.168.0.0 0.0.0.255 log
deny ip 192.168.15.0 0.0.0.255 192.168.1.0 0.0.0.255 log
deny ip 192.168.15.0 0.0.0.255 192.168.10.0 0.0.0.255 log
deny ip 192.168.15.0 0.0.0.255 192.168.15.0 0.0.0.255 log
deny ip 192.168.15.0 0.0.0.255 192.168.20.0 0.0.0.255 log
deny ip 192.168.15.0 0.0.0.255 192.168.30.0 0.0.0.255 log
deny ip 192.168.15.0 0.0.0.255 192.168.40.0 0.0.0.255 log
deny ip 192.168.15.0 0.0.0.255 192.168.99.0 0.0.0.255 log
deny ip 192.168.15.0 0.0.0.255 192.168.100.0 0.0.0.255 log
deny ip 192.168.15.0 0.0.0.255 192.168.101.0 0.0.0.255 log
deny ip 192.168.15.0 0.0.0.255 192.168.200.0 0.0.0.255 log
deny ip 192.168.15.0 0.0.0.255 192.168.201.0 0.0.0.255 log
deny ip 192.168.15.0 0.0.0.255 192.168.202.0 0.0.0.255 log
deny ip 192.168.15.0 0.0.0.255 192.168.254.0 0.0.0.255 log
permit ip 192.168.15.0 0.0.0.255 any
deny ip 192.168.15.0 0.0.0.255 192.168.12.0 0.0.0.255 log
ip access-list extended PolicyRoute_20
deny ip 192.168.20.0 0.0.0.255 192.168.0.0 0.0.0.255 log
deny ip 192.168.20.0 0.0.0.255 192.168.1.0 0.0.0.255 log
deny ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255 log
deny ip 192.168.20.0 0.0.0.255 192.168.20.0 0.0.0.255 log
deny ip 192.168.20.0 0.0.0.255 192.168.30.0 0.0.0.255 log
deny ip 192.168.20.0 0.0.0.255 192.168.40.0 0.0.0.255 log
deny ip 192.168.20.0 0.0.0.255 192.168.50.0 0.0.0.255 log
deny ip 192.168.20.0 0.0.0.255 192.168.99.0 0.0.0.255 log
deny ip 192.168.20.0 0.0.0.255 192.168.100.0 0.0.0.255 log
deny ip 192.168.20.0 0.0.0.255 192.168.200.0 0.0.0.255 log
deny ip 192.168.20.0 0.0.0.255 192.168.201.0 0.0.0.255 log
deny ip 192.168.20.0 0.0.0.255 192.168.202.0 0.0.0.255 log
permit ip any any
deny ip 192.168.20.0 0.0.0.255 192.168.12.0 0.0.0.255 log
ip access-list extended PolicyRoute_200
deny ip 192.168.200.0 0.0.0.255 172.16.100.0 0.0.0.255 log
deny ip 192.168.200.0 0.0.0.255 192.168.0.0 0.0.0.255 log
deny ip 192.168.200.0 0.0.0.255 172.16.101.0 0.0.0.255
deny ip 192.168.200.0 0.0.0.255 192.168.1.0 0.0.0.255 log
deny ip 192.168.200.0 0.0.0.255 192.168.10.0 0.0.0.255 log
deny ip 192.168.200.0 0.0.0.255 192.168.20.0 0.0.0.255 log
deny ip 192.168.200.0 0.0.0.255 192.168.30.0 0.0.0.255 log
deny ip 192.168.200.0 0.0.0.255 192.168.40.0 0.0.0.255 log
deny ip 192.168.200.0 0.0.0.255 192.168.99.0 0.0.0.255 log
deny ip 192.168.200.0 0.0.0.255 192.168.100.0 0.0.0.255 log
deny ip 192.168.200.0 0.0.0.255 192.168.200.0 0.0.0.255 log
deny ip 192.168.200.0 0.0.0.255 192.168.201.0 0.0.0.255 log
deny ip 192.168.200.0 0.0.0.255 192.168.202.0 0.0.0.255 log
deny ip 192.168.200.0 0.0.0.255 192.168.254.0 0.0.0.255 log
permit ip any any
deny ip 192.168.200.0 0.0.0.255 192.168.12.0 0.0.0.255 log
ip access-list extended PolicyRoute_201
deny ip 192.168.201.0 0.0.0.255 192.168.0.0 0.0.0.255 log
deny ip 192.168.201.0 0.0.0.255 192.168.1.0 0.0.0.255 log
deny ip 192.168.201.0 0.0.0.255 192.168.10.0 0.0.0.255 log
deny ip 192.168.201.0 0.0.0.255 192.168.20.0 0.0.0.255 log
deny ip 192.168.201.0 0.0.0.255 192.168.30.0 0.0.0.255 log
deny ip 192.168.201.0 0.0.0.255 192.168.40.0 0.0.0.255 log
deny ip 192.168.201.0 0.0.0.255 192.168.99.0 0.0.0.255 log
deny ip 192.168.201.0 0.0.0.255 192.168.100.0 0.0.0.255 log
deny ip 192.168.201.0 0.0.0.255 192.168.101.0 0.0.0.255 log
deny ip 192.168.201.0 0.0.0.255 192.168.200.0 0.0.0.255 log
deny ip 192.168.201.0 0.0.0.255 192.168.201.0 0.0.0.255 log
deny ip 192.168.201.0 0.0.0.255 192.168.202.0 0.0.0.255 log
deny ip 192.168.201.0 0.0.0.255 192.168.254.0 0.0.0.255 log
permit ip 192.168.201.0 0.0.0.255 any
deny ip 192.168.201.0 0.0.0.255 192.168.12.0 0.0.0.255 log
ip access-list extended PolicyRoute_202
deny ip 192.168.202.0 0.0.0.255 192.168.0.0 0.0.0.255 log
deny ip 192.168.202.0 0.0.0.255 192.168.1.0 0.0.0.255 log
deny ip 192.168.202.0 0.0.0.255 192.168.10.0 0.0.0.255 log
deny ip 192.168.202.0 0.0.0.255 192.168.20.0 0.0.0.255 log
deny ip 192.168.202.0 0.0.0.255 192.168.30.0 0.0.0.255 log
deny ip 192.168.202.0 0.0.0.255 192.168.40.0 0.0.0.255 log
deny ip 192.168.202.0 0.0.0.255 192.168.99.0 0.0.0.255 log
deny ip 192.168.202.0 0.0.0.255 192.168.100.0 0.0.0.255 log
deny ip 192.168.202.0 0.0.0.255 192.168.101.0 0.0.0.255 log
deny ip 192.168.202.0 0.0.0.255 192.168.200.0 0.0.0.255 log
deny ip 192.168.202.0 0.0.0.255 192.168.201.0 0.0.0.255 log
deny ip 192.168.202.0 0.0.0.255 192.168.202.0 0.0.0.255 log
permit ip 192.168.202.0 0.0.0.255 any
deny ip 192.168.202.0 0.0.0.255 192.168.12.0 0.0.0.255 log
ip access-list extended PolicyRoute_901
deny ip 172.16.100.0 0.0.0.255 172.16.100.0 0.0.0.255
deny ip 172.16.100.0 0.0.0.255 172.16.101.0 0.0.0.255
deny ip 172.16.100.0 0.0.0.255 192.168.0.0 0.0.0.255
deny ip 172.16.100.0 0.0.0.255 192.168.10.0 0.0.0.255
deny ip 172.16.100.0 0.0.0.255 192.168.15.0 0.0.0.255
deny ip 172.16.100.0 0.0.0.255 192.168.20.0 0.0.0.255
deny ip 172.16.100.0 0.0.0.255 192.168.30.0 0.0.0.255
deny ip 172.16.100.0 0.0.0.255 192.168.40.0 0.0.0.255
deny ip 172.16.100.0 0.0.0.255 192.168.99.0 0.0.0.255
deny ip 172.16.100.0 0.0.0.255 192.168.100.0 0.0.0.255
deny ip 172.16.100.0 0.0.0.255 192.168.254.0 0.0.0.255
deny ip 172.16.100.0 0.0.0.255 192.168.101.0 0.0.0.255
deny ip 172.16.100.0 0.0.0.255 192.168.200.0 0.0.0.255
deny ip 172.16.100.0 0.0.0.255 192.168.201.0 0.0.0.255
deny ip 172.16.100.0 0.0.0.255 192.168.202.0 0.0.0.255
permit ip 172.16.100.0 0.0.0.255 any
deny ip 172.16.100.0 0.0.0.255 192.168.12.0 0.0.0.255 log
ip access-list extended PolicyRoute_902
deny ip 172.16.102.0 0.0.0.255 172.16.100.0 0.0.0.255
deny ip 172.16.102.0 0.0.0.255 172.16.101.0 0.0.0.255
deny ip 172.16.102.0 0.0.0.255 172.16.102.0 0.0.0.255
deny ip 172.16.102.0 0.0.0.255 192.168.0.0 0.0.0.255
deny ip 172.16.102.0 0.0.0.255 192.168.10.0 0.0.0.255
deny ip 172.16.102.0 0.0.0.255 192.168.15.0 0.0.0.255
deny ip 172.16.102.0 0.0.0.255 192.168.20.0 0.0.0.255
deny ip 172.16.102.0 0.0.0.255 192.168.30.0 0.0.0.255
deny ip 172.16.102.0 0.0.0.255 192.168.40.0 0.0.0.255
deny ip 172.16.102.0 0.0.0.255 192.168.99.0 0.0.0.255
deny ip 172.16.102.0 0.0.0.255 192.168.100.0 0.0.0.255
deny ip 172.16.102.0 0.0.0.255 192.168.254.0 0.0.0.255
deny ip 172.16.102.0 0.0.0.255 192.168.101.0 0.0.0.255
deny ip 172.16.102.0 0.0.0.255 192.168.200.0 0.0.0.255
deny ip 172.16.102.0 0.0.0.255 192.168.201.0 0.0.0.255
deny ip 172.16.102.0 0.0.0.255 192.168.202.0 0.0.0.255
permit ip 172.16.102.0 0.0.0.255 any
deny ip 172.16.102.0 0.0.0.255 192.168.12.0 0.0.0.255 log
ip access-list extended PolicyRoute_903
deny ip 172.16.103.0 0.0.0.255 192.168.0.0 0.0.0.255
deny ip 172.16.103.0 0.0.0.255 192.168.10.0 0.0.0.255
deny ip 172.16.103.0 0.0.0.255 192.168.200.0 0.0.0.255
deny ip 172.16.103.0 0.0.0.255 172.16.90.0 0.0.0.255
deny ip 172.16.103.0 0.0.0.255 172.16.100.0 0.0.0.255
permit ip 172.16.103.0 0.0.0.255 any
deny ip 172.16.103.0 0.0.0.255 192.168.12.0 0.0.0.255 log
ip access-list extended PolicyRoute_909
deny ip 172.16.90.0 0.0.0.255 172.16.90.0 0.0.0.255
deny ip 172.16.90.0 0.0.0.255 172.16.101.0 0.0.0.255
deny ip 172.16.90.0 0.0.0.255 192.168.0.0 0.0.0.255
deny ip 172.16.90.0 0.0.0.255 192.168.10.0 0.0.0.255
deny ip 172.16.90.0 0.0.0.255 192.168.15.0 0.0.0.255
deny ip 172.16.90.0 0.0.0.255 192.168.20.0 0.0.0.255
deny ip 172.16.90.0 0.0.0.255 192.168.30.0 0.0.0.255
deny ip 172.16.90.0 0.0.0.255 192.168.40.0 0.0.0.255
deny ip 172.16.90.0 0.0.0.255 192.168.99.0 0.0.0.255
deny ip 172.16.90.0 0.0.0.255 192.168.100.0 0.0.0.255
deny ip 172.16.90.0 0.0.0.255 192.168.254.0 0.0.0.255
deny ip 172.16.90.0 0.0.0.255 192.168.101.0 0.0.0.255
deny ip 172.16.90.0 0.0.0.255 192.168.200.0 0.0.0.255
deny ip 172.16.90.0 0.0.0.255 192.168.201.0 0.0.0.255
deny ip 172.16.90.0 0.0.0.255 192.168.202.0 0.0.0.255
permit ip 172.16.90.0 0.0.0.255 any
deny ip 172.16.90.0 0.0.0.255 192.168.12.0 0.0.0.255 log
logging trap errors
logging host 192.168.0.101
access-list 23 permit 24.28.23.243 log
access-list 23 permit 192.168.0.0 0.0.255.255 log
access-list 23 permit 172.16.0.0 0.0.255.255 log
access-list 23 deny any log
access-list 101 deny ip any 170.146.0.0 0.0.255.255 log
access-list 101 permit ip any any
access-list 102 deny ip any 170.146.0.0 0.0.255.255 log
access-list 102 permit ip any any
access-list 199 deny tcp host 192.168.0.99 eq www any log
access-list 199 deny tcp any eq www host 192.168.0.99 log
access-list 199 deny tcp 192.168.0.0 0.0.0.255 eq 443 any log
access-list 199 permit ip any any
route-map PolicyRoute_Access permit 100
match ip address PolicyRoute_10
set ip next-hop 192.168.10.253
route-map PolicyRoute_Wireless permit 10
match ip address PolicyRoute_200
set ip next-hop 192.168.200.253
route-map PolicyRoute_Security permit 201
match ip address PolicyRoute_201
set ip next-hop 192.168.201.253
route-map PolicyRoute_Distro permit 20
match ip address PolicyRoute_100
set ip next-hop 192.168.0.253
route-map PolicyRoute_909 permit 909
match ip address PolicyRoute_909
set ip next-hop 172.16.90.253
route-map PolicyRoute_100 permit 100
set ip next-hop 192.168.100.253
route-map PolicyRoute_903 permit 903
match ip address PolicyRoute_903
set ip next-hop 172.16.103.253
route-map PolicyRoute_902 permit 902
match ip address PolicyRoute_902
set ip next-hop 172.16.102.253
route-map PolicyRoute_901 permit 901
match ip address PolicyRoute_901
set ip next-hop 172.16.100.253
route-map PolicyRoute_15 permit 15
match ip address PolicyRoute_15
set ip next-hop 192.168.15.253
route-map PolicyRoute_10 permit 10
route-map Failover permit 207
match ip address Failover
set ip next-hop 207.70.158.189
route-map PolicyRoute_Access2 permit 12
set ip next-hop 192.168.12.253
route-map PolicyRoute_Access2 permit 100
match ip address PolicyRoute_12
route-map PolicyRoute_SANMgmt permit 50
set ip next-hop 192.168.20.253
route-map PolicyRoute_Wireless_903 permit 903
route-map PolicyRoute_Wired permit 20
route-map PolicyRoute_Environment permit 40
match ip address PolicyRoute_202
set ip next-hop 192.168.202.253
route-map PolicyRoute_Environment permit 254
match ip address PolicyRoute_254
set ip next-hop 192.168.254.253
snmp-server community public RO
banner motd ^CC
THIS IS A PRIVATE COMPUTER SYSTEM. It is for authorized use only.
Users (authorized or unauthorized) have no explicit or implicit
expectation of privacy.
Any or all uses of this system and all files on this system may
be intercepted, monitored, recorded, copied, audited, inspected,
and disclosed to authorized site and law enforcement personnel,
as well as authorized officials of other agencies, both domestic
and foreign. By using this system, the user consents to such
interception, monitoring, recording, copying, auditing, inspection,
and disclosure at the discretion of authorized site personnel.
Unauthorized or improper use of this system may result in
administrative disciplinary action and civil and criminal penalties.
By continuing to use this system you indicate your awareness of and
consent to these terms and conditions of use. LOG OFF IMMEDIATELY
if you do not agree to the conditions stated in this warning.
^C
alias exec sa show arp
alias exec smt show mac-address-table
alias exec sir show ip route
alias exec cmt clear mac-address-table dynamic
alias exec wr write mem
alias exec con config term
alias exec cmtd clear mac-address-table dynamic
alias exec ca clear arp
alias exec si show interface
alias exec sci show config | inc
alias exec scg show run | grep
alias exec sis sh interface status mod
alias exec sri show running interface
line con 0
stopbits 1
line vty 0 4
session-timeout 35791
access-class 23 in
privilege level 15
password 7 096D4A0D1016471C5A
transport input all
line vty 5
access-class 23 in
privilege level 15
transport input all
line vty 6 15
transport input all
ntp update-calendar
ntp server 192.168.0.170
end
CoreSwitch4507#
And this is the remote side....
Willis-3560#interface Vlan1
Willis-3560#no ip address 192.168.100.1 255.255.255.0
Willis-3560#no ip policy route-map PolicyRoute_Distro
Willis-3560#ping 192.168.0.170
Sending 5, 100-byte ICMP Echos to 192.168.0.170, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Willis-3560#ping 192.168.0.165
Sending 5, 100-byte ICMP Echos to 192.168.0.165, timeout is 2 seconds:
Willis-3560#config t
Enter configuration commands, one per line. End with CNTL/Z.
Willis-3560(config)#interface Vlan1
Willis-3560(config-if)# ip address 10.100.10.1 255.255.255.0
Willis-3560(config-if)#exit
Willis-3560(config)#exit
Willis-3560#ping 192.168.0.181
Sending 5, 100-byte ICMP Echos to 192.168.0.181, timeout is 2 seconds:
Willis-3560#
Willis-3560#
Willis-3560#ping 192.168.100.100
Sending 5, 100-byte ICMP Echos to 192.168.100.100, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/5/9 ms
Willis-3560#
Willis-3560#
Willis-3560#
Willis-3560#
Willis-3560#
Willis-3560#
Willis-3560#
Willis-3560#writ t
Current configuration : 4200 bytes
! Last configuration change at 13:03:38 CST Mon Mar 1 1993
version 15.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service unsupported-transceiver
hostname Willis-3560
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$hYn/$ObM6LBC7.dXXA/bx5p3oa/
enable password 7 13521A131915102239212D77
username tharris privilege 15 password 7 06270B25455D591754
username rhapsody privilege 15 password 7 0876414F1B00111F000E0940
username thunder privilege 15 password 7 03470358552B34484B
username mplante privilege 15 password 7 153F020F0C2B2E28
aaa new-model
Wrong Password **bleep**! Try again.^C
system mtu routing 1500
vtp interface Vlan100
ip routing
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
description "Point to Point to Corporate"
no switchport
ip address 10.10.5.2 255.255.255.0
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
description Test of VLAN 100
interface GigabitEthernet0/49
interface GigabitEthernet0/50
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface Vlan1
interface Vlan100
ip address 10.10.10.1 255.255.255.0
router eigrp 7
network 10.10.10.0 0.0.0.255
network 10.100.10.0 0.0.0.255
eigrp stub connected summary
no ip classless
no ip http server
no ip http secure-server
vstack
alias exec sr show run
alias exec sis show interface status
alias exec siib sh ip int brief
line con 0
line vty 4
privilege level 15
transport input ssh
line vty 5 13
privilege level 15
password 7 052A020B285F1E0748
transport input ssh
line vty 14
privilege level 15
transport input ssh
line vty 15
privilege level 15
password 7 047A0F0206321C4058
transport input ssh
ntp server 128.194.254.9
end
Willis-3560#
Willis-3560(config)#router eigrp 7
Willis-3560(config-router)# passive-interface Vlan100
Willis-3560(config-router)#exit
Willis-3560#writ t
Current configuration : 4227 bytes
! Last configuration change at 13:33:01 CST Mon Mar 1 1993
version 15.0
no service pad
boot-start-marker
boot-end-marker
no logging console
aaa new-model
ip routing
no switchport
interface Vlan1
interface Vlan100
router eigrp 7
no ip classless
no ip http server
Password:
Willis-3560#show ip route eigrp
Gateway of last resort is not set
172.16.0.0/24 is subnetted, 1 subnets
D 172.16.103.0 [90/3072] via 10.10.5.1, 04:26:17, GigabitEthernet0/1
D 192.168.0.0/24 [90/3072] via 10.10.5.1, 04:26:17, GigabitEthernet0/1
D 192.168.100.0/24 [90/3072] via 10.10.5.1, 04:19:14, GigabitEthernet0/1
Willis-3560#show ip interface
Vlan1 is up, line protocol is down
Internet address is 10.100.10.1/24
MTU is 1500 bytes
Output features: Check hwidb
Vlan100 is up, line protocol is up
Internet address is 10.10.10.1/24
MTU is 1500 bytes
GigabitEthernet0/1 is up, line protocol is up
Internet address is 10.10.5.2/24
MTU is 1500 bytes
GigabitEthernet0/2 is down, line protocol is down
GigabitEthernet0/3 is down, line protocol is down
GigabitEthernet0/4 is down, line protocol is down
GigabitEthernet0/5 is down, line protocol is down
GigabitEthernet0/6 is down, line protocol is down
GigabitEthernet0/7 is down, line protocol is down
GigabitEthernet0/8 is down, line protocol is down
GigabitEthernet0/9 is down, line protocol is down
GigabitEthernet0/10 is down, line protocol is down
GigabitEthernet0/11 is down, line protocol is down
GigabitEthernet0/12 is down, line protocol is down
GigabitEthernet0/13 is down, line protocol is down
GigabitEthernet0/14 is down, line protocol is down
GigabitEthernet0/15 is down, line protocol is down
GigabitEthernet0/16 is down, line protocol is down
GigabitEthernet0/17 is down, line protocol is down
GigabitEthernet0/18 is down, line protocol is down
GigabitEthernet0/19 is down, line protocol is down
GigabitEthernet0/20 is down, line protocol is down
GigabitEthernet0/21 is down, line protocol is down
GigabitEthernet0/22 is down, line protocol is down
GigabitEthernet0/23 is down, line protocol is down
GigabitEthernet0/24 is down, line protocol is down
GigabitEthernet0/25 is down, line protocol is down
GigabitEthernet0/26 is down, line protocol is down
GigabitEthernet0/27 is down, line protocol is down
GigabitEthernet0/28 is down, line protocol is down
GigabitEthernet0/29 is down, line protocol is down
GigabitEthernet0/30 is down, line protocol is down
GigabitEthernet0/31 is down, line protocol is down
GigabitEthernet0/32 is down, line protocol is down
GigabitEthernet0/33 is down, line protocol is down
GigabitEthernet0/34 is down, line protocol is down
GigabitEthernet0/35 is down, line protocol is down
GigabitEthernet0/36 is down, line protocol is down
GigabitEthernet0/37 is down, line protocol is down
GigabitEthernet0/38 is down, line protocol is down
GigabitEthernet0/39 is down, line protocol is down
GigabitEthernet0/40 is down, line protocol is down
GigabitEthernet0/41 is down, line protocol is down
GigabitEthernet0/42 is down, line protocol is down
GigabitEthernet0/43 is down, line protocol is down
GigabitEthernet0/44 is down, line protocol is down
GigabitEthernet0/45 is down, line protocol is down
GigabitEthernet0/46 is down, line protocol is down
GigabitEthernet0/47 is down, line protocol is down
GigabitEthernet0/48 is up, line protocol is up
GigabitEthernet0/49 is down, line protocol is down
GigabitEthernet0/50 is down, line protocol is down
GigabitEthernet0/51 is down, line protocol is down
GigabitEthernet0/52 is down, line protocol is down
Willis-3560#
Willis-3560#
Willis-3560#show ip eigrp interfaces
Gi0/1 1 0/0 0/0 1 0/0 50 0
Willis-3560#show running config
Willis-3560#show running-config
! Last configuration change at 13:59:23 CST Mon Mar 1 1993
version 15.0
no service pad
boot-start-marker
boot-end-marker
no logging console
aaa new-model
ip routing
no switchport
interface Vlan1
interface Vlan100
router eigrp 7
no ip classless
no ip http server
vstack
line con 0
line vty 4
privilege level 15
transport input ssh
line vty 5 13
privilege level 15
transport input ssh
line vty 14
privilege level 15
transport input ssh
line vty 15
privilege level 15
transport input ssh
end
Willis-3560#
I found something in your configuration.
 coporate route
router eigrp 7
network 192.168.0.0
show ip route eigrp
Here you have a summary route address /24, but in your remote site you have other network 10.10.5.0/24, 10.100.10.0/24
try to run: no auto-summary on eigrp configuration in remote site.
remote site
eigrp 7
show ip route
Jaderson Pessoa
I entered the command no auto-summary on the remote site.
Still no love.
By the way the remote switch is a 3560 and EIGRP is restricted to stub configurations.
remote site
run this command and all wil works fine
after it, on corporate site
show ip route eigrp
test your connections.
Jaderson Pessoa
D 10.10.10.0/24 [90/3072] via 10.10.5.2, 00:01:33, GigabitEthernet7/14
Dear,
On remote site run this command:
configure terminal
router eigrp 7
Jaderson Pessoa
Yes, thank you, it was done.
router eigrp 7
Great... Please if possible, mark this as solved and helpful..
Thanks in advance.
Jaderson Pessoa
Sorry. I entered the command.
It is still not hitting any VLANs at corporate except for VLAN1.
I going back to my original thinking. Maybe I need to load the latest IOS?
Its not related about IOS version, your corporate route has just one route to remote_site that is 10.10.10.0/24
try it it on your corporate site.
ip route 10.10.5.0 255.255.255.0 10.10.5.2
ip route 10.100.10.0 255.255.255.0 10.10.5.2
Jaderson Pessoa
I had tried adding static routes before and I tried it just now again. It did not work.
I can always move the servers to VLAN1. It is not being used for anything at corporate.
