Enforced 'dynamic' OSPF cost in Etherchannel
Dear all,
I'm working in a network of Catalyst 4948Es. I want to enforce the ospf cost of a port-channel interface, but at the same time I want the port-channel cost to change when any of the member links fails. If I use commands like 'bandwidth' or 'ip ospf cost' on the port-channel interface the cost remains the same when a link comes down. I thought that maybe changing ospf cost of the members could influence in any way the cost of the port-channel, but it has no impact. Changing the global reference bandwidth is not an option either. At present time the only option I see is using the embeded event manager, but I would be grateful if you could suggest me another way to get this 'dynamically modified' OSPF cost for a port-channel.
Thank you
Octavio
8 Replies 8
Rolf Fischer
Level 9
Level 9
Hi Octavio,
did you configure the port-channel interfaces as a layer 3 interfaces or layer 2 + SVIs?
Rolf
Hi Rolf,
As a layer 3 interface:
interface Port-channel60
vrf forwarding DIST
ip address 10.10.10.5 255.255.255.252
ip pim query-interval 500 msec
ip pim sparse-mode
ip ospf network point-to-point
load-interval 30
carrier-delay msec 0
end
interface GigabitEthernet1/1
no switchport
dampening
load-interval 30
channel-group 60 mode active
end
interface GigabitEthernet1/2
no switchport
dampening
load-interval 30
end
Thanks in advance
Octavio
Could you please also post a 'show ip ospf interface po60', I'd be interested in the cost for this 2Gig port-channel interface.
Did you increase the OSPF reference-bandwidth (otherwise every link >= FastEthernet will have an OSPF cost of 1) ?
Both member ports are bundled?
Rolf
Hi Rolf,
Both 4948Es have the same outputs, so I send the ones of one of them.
* Reference bw is 1Tbps
C4900A#sh run | i reference
auto-cost reference-bandwidth 1000000
* Both members are GE interfaces, son 1Tbps/2Gbps=500
C4900A#sh ip ospf interface port-channel 60
Port-channel60 is up, line protocol is up (connected)
  Internet Address 10.10.10.1/30, Area 0, Attached via Network Statement
  Process ID 1, Router ID 10.0.0.1, Network Type POINT_TO_POINT, Cost: 500
  Topology-MTID    Cost    Disabled    Shutdown      Topology Name
        0           500      no          no            Base
  Transmit Delay is 1 sec, State POINT_TO_POINT
  Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
    oob-resync timeout 40
    Hello due in 00:00:01
  Supports Link-local Signaling (LLS)
  Cisco NSF helper support enabled
  IETF NSF helper support enabled
  Index 2/2, flood queue length 0
  Next 0x0(0)/0x0(0)
  Last flood scan length is 1, maximum is 1
  Last flood scan time is 0 msec, maximum is 0 msec
  Neighbor Count is 1, Adjacent neighbor count is 1
    Adjacent with neighbor 10.0.0.3
  Suppress hello for 0 neighbor(s)
* Both members are bundled:
C4900A#sh lacp internal
Flags:  S - Device is requesting Slow LACPDUs
        F - Device is requesting Fast LACPDUs
        A - Device is in Active mode       P - Device is in Passive mode
Channel group 60
                            LACP port     Admin     Oper    Port        Port
Port      Flags   State     Priority      Key       Key     Number      State
Gi1/1     SA      bndl      32768         0x3C      0x3C    0x3B        0x3D
Gi1/2     SA      bndl      32768         0x3C      0x3C    0x3C        0x3D
C4900A#sh lacp internal detail
Channel group 60
Actor (internal) information:
          Actor                 Actor                       Actor
Port      System ID             Port Number     Age         Flags
Gi1/1     32768,78da.6ecb.9540  0x3B             22s        SA
          LACP Actor           Actor           Actor
          Port Priority        Oper Key        Port State
          32768                0x3C            0x3D
          Port State Flags Decode:
          Activity:   Timeout:   Aggregation:   Synchronization:
          Active      Long       Yes            Yes
          Collecting:   Distributing:   Defaulted:   Expired:
          Yes           Yes             No           No
          Actor                 Actor                       Actor
Gi1/2     32768,78da.6ecb.9540  0x3C              1s        SA
          32768                0x3C            0x3D
          Active      Long       Yes            Yes
          Yes           Yes             No           No
Thanks a lot. I really appreciate your help.
Octavio
Rolf Fischer
Level 9
Level 9
Octavio,
you're welcome.
From what I see, everything looks like expected.
I'd assume that the cost increases to 1000 when one of the member-ports unbundles? Would that solve your reqirements?
Rolf
Sent from Cisco Technical Support Android App
Hi Rolf,
It's as you described. If I shut down one GE interface, the cost is 1000.
The point is that I would like to go one step beyond. I would like to have a cost for the same port-channel of 4000 and, if one GE fails, I want it to be 8000. I tried several things:
* "ip ospf cost 4000" on the port-channel. If one GE comes down, the cost remains the same
* "ip ospf cost 8000" on both GE members. It has no impact on the cost of the port-channel, as it is 500
* "banwidth 250Mbps" on both GE members to get a cost of 4000 per link. It has no impact on the cost of the port-channel, as it is 500
I can not change the cost of the port-channel and, at the same time, keep its dependancy with the number of active member links.
The only option I find is making a script with the Embedded Event Manager to track both GE members and, if one fails, change the cost of the port-channel.
Thank you
Octavio
Octavio,
o.k., now I understand. Sorry for beeing somewhat slow-witted.
Perhaps somebody else can provide a solution, but I think you've already tried everything possible with standard-IOS.
If the all-or-nothing approach of the port-channel min-links command is no option, I'd also use EEM to solve this.
The EC-5-BUNDLE/UNBUNDLE syslog messages look promising to trigger an applet/script.
Rolf
Thank you very much, Rolf. I really appreciate your guidance to verify that everything was as it should be. Thanks a lot for the syslog message to track, too. Really useful.
Thanks a lot
Octavio
