error 403 forbidden
unidadso
when I connect the isr 1100 to navigate into the published services alocate in the web server of my company, I get this, "error 403 forbidden", if I connect the cisco rv042g I have no problem entering into the same page.
15 Replies 15
brimerwells95612
Community Member
This error indicates that the server has determined that you are not allowed access to the thing you've requested, either on purpose or due to a misconfiguration . It's probably because the site owner has limited access to it and you don't have permission to view it. The vast majority of the time, there's not much you can do to fix things on your (*client) end. There are three common causes for 403 Forbidden error (server side) . Here they are listed from most likely to least likely:
  • An empty website directory
  • No index page
  • Incorrect settings in the .htaccess file
  • Permission / Ownership error
If authentication credentials were provided in the request, the server considers them insufficient to grant access. The client SHOULD NOT automatically repeat the request with the same credentials. The client MAY repeat the request with new or different credentials. However, a request might be forbidden for reasons unrelated to the credentials.
