ERROR: Cannot get pbr statistics data, please enable ITD statistics - Nexus 9504
Dear Friend,
I am facing issue to configuring ITD in nexus 9504 switch as i am getting below error
N9K-CORE-SW01# sh itd ITD-N9K statistics
ERROR: Cannot get pbr statistics data, please enable ITD statistics.
While i have already enable below feature
itd 1 enabled
lacp 1 enabled
pbr 1 enabled
sla_responder 1 enabled
sla_sender 1 enabled
Please share your suggestion ...
Ganesh Prasad Gupta
Georg Pauwen
highly likely that you are hitting the bug below. The workaround is:
Nexus9504(config)# route-map proxy_itd_pool pbr-statistics
ITD: 'show itd xxx statistics' reports Error 'ERROR: Cannot get pbr statistics data.'
CSCvc73162
Description
Symptom:
'show itd xxx statistics' doesn't work.
Conditions:
when issue the show CLI
Workaround:
Manually enable the pbr-statistics on the ITD route-map
Nexus-Core1(config)# route-map proxy_itd_pool pbr-statistics
