ESP100 REPLACE VIA ESP200 in ASR1009-x Box
palash0072000
Dear Members:
We are planing to replace ESP100 by ESP200 in one of our router [ASR 1009-x] for upgrading the overall througput.
Can anyone please explain the total procedure/dependency in breif or share a good link to start?
And we have few specific question as well if possible please share insight
  1. Currently we have single RP in RO slot and single ESP100 on FO slot. so if we insert the ESP200 on F1 slot and then remove ESP100 from FO slot will it work or we have to remove the ESP100 from FO slot and insert the new ESP200 on FO slot?
  2. Can we insert the new ESP200 while router power on?
  3. Do we need to reboot the router after ESP200 insertion completes?
  4. Any license required or only insertion of ESP200 is good enough?
output of show platform command from the router is shared below for your kind observation
aggregation.gw#show platform
Chassis type: ASR1009-X
Slot      Type                State                 Insert time (ago)
0         ASR1000-6TGE        ok                    31w4d
 0/0      BUILT-IN-6TGE       ok                    31w4d
1         ASR1000-SIP40       ok                    31w4d
 1/0      SPA-8X1GE-V2        ok                    31w4d
 1/1      SPA-1X10GE-L-V2     ok                    31w4d
 1/2      SPA-1X10GE-L-V2     ok                    31w4d
 1/3      SPA-1X10GE-L-V2     ok                    29w4d
2         ASR1000-6TGE        ok                    4w2d
 2/0      BUILT-IN-6TGE       ok                    4w2d
R0        ASR1000-RP3         ok, active            31w4d
F0        ASR1000-ESP100      ok, active            31w4d
P0        ASR1000X-AC-1100W   ok                    31w4d
P1        ASR1000X-AC-1100W   ok                    31w4d
P2        Unknown             ps, fail              never
P3        Unknown             ps, fail              never
P4        Unknown             ps, fail              never
P5        Unknown             ps, fail              never
P6        ASR1000X-FAN        ok                    31w4d
P7        ASR1000X-FAN        ok                    31w4d
P8        ASR1000X-FAN        ok                    31w4d
Slot      CPLD Version        Firmware Version
0         14011701            16.2(1r)
1         00200800            15.3(3r)S
2         14011701            16.2(1r)
R0        16082219            16.3(2r)
F0        12071700            16.2(1r)
Thanking,
Palash
0 Replies 0
