ESR 10008 and NetFlow Sampling
peteroseneff
Hello!
Does ESR 10008 router support NetFlow Sampling? I want to lower netflow export proccess CPU load by (for instance) exporting with packet interval 100 or more.
CPU utilization for five seconds: 38%/20%; one minute: 45%; five minutes: 46%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
232   7147543164186505465          0  7.67%  7.93%  7.93%   0 C10K Netflow Toa
230   314814348   8867268      35503  3.11%  5.17%  5.18%   0 c10k_periodic_st
310   1681353761267524883        132  2.63%  3.17%  3.10%   0 RADIUS
226    60430536  15349311       3937  0.87%  0.83%  0.84%   0 CEF: IPv4 proces
149    48171848 589780175         81  0.79%  0.93%  1.04%   0 IP Input
145    23333936 233074591        100  0.55%  0.39%  0.40%   0 AAA ACCT Proc
262     3836748    256504      14957  0.39%  0.07%  0.05%   0 URPF stats
146    37883924 231763732        163  0.23%  0.70%  0.68%   0 ACCT Periodic Pr
294    16160820 151541800        106  0.15%  0.18%  0.21%   0 PPPoE Background
295    27949612 445819138         62  0.15%  0.13%  0.16%   0 PPPoE Discovery
169    33372604 192576187        173  0.15%  0.32%  0.29%   0 SSM connection m
298    32182808 403705989         79  0.15%  0.27%  0.24%   0 PPP Events
329     6880416  22443345        306  0.07%  0.09%  0.11%   0 BGP Router
   4     2330908  26951650         86  0.07%  0.03%  0.03%   0 C10K Card Event
103     2316956    900720       2572  0.07%  0.04%  0.03%   0 Compute load avg
158    34598128  99212850        348  0.07%  0.24%  0.24%   0 SSS Manager
thanks.
Giuseppe Larosa
Hello Osenevp,
according to feature navigator
http://www.cisco.com/go/fn
sampled netflow is supported only on 10700
search by feature: sampled netflow
Hope to help
Giuseppe
Hello. Thanks for fn. In my case probably the only one thing that I'm able to do with 10008 is to turn off 'ip flow egress' on uplink interface (while keeping 'ip flow ingress' on)
Hello Osenevp,
yes removing netflow accounting in one direction should reduce cpu load.
Hope to help
Giuseppe
