extended ping data patterns defined
Peter010101
Level 4
Level 4
I am looking for information on data patterns used while performing extended pings.
So far this is all I can find:
0xffff = repeater power problems
0x0000 = line code mismatches
0x4040 = timing problems.
0x5555 = The alternating pattern represents a "typical" data pattern
Are these accurate and are there any more data patterns I can test with?
dan_sharp
Visitor
What are you pinging across? A frame relay set up or? Will depend on what patterns are worthwhile for each case.
I am ping across t1-t3 and atm links.
