Extranet MPLS VPN basic question
news2010a
Level 3
Level 3
Imagine CompanyA acquired CompanyB. Same ISP for both companies.
Now CompanyA wants to access network from CompanyB (one-way access).
For this MPLS VPN Extranet scenario, do you know any good document explaining which parameters service provider is supposed to adjust in order to make this access possible? I believe that RD and RT Import should be changed on PE routers but I want to read more about it.
Giuseppe Larosa
Hello Marlon,
only additional route targets commands have to be added, RD do not play a role in building an extranet.
route targets are used to decide if a VPNv4 route has to be imported in one specific VRF. RD are used to solve overlapping issues and to create the VPNv4 prefixes.
you can refer to
http://www.cisco.com/en/US/docs/net_mgmt/ip_solution_center/5.1/mpls_vpn/user/guide/isc_mpls.html
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_cfg_layer3_vpn_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Hope to help
Giuseppe
Giuseppe Larosa
Hello Marlon,
you can refer to
Hope to help
Giuseppe
