Failed to ping port connected to a serial connection.
bmukwiilongo1
Hi.
I've been trying to ping port Se0/0/0 on Router 2 from either stations, but has ended in numerous failed attempts. Attached is a screenshot, really don't know how to upload my .pkt file.
Thanks.
pwwiddicombe
Level 4
Level 4
The IP address of se 0/0/0 - is it advertised internally by any routing protocol; or are there statics in place to allow forwarding of packets to R2 ?
What specific error are you getting?  Post the output of "tracert x.x.x.x" and ping x.x.x.x where the x.x.x.x is the known address of se0/0/0.
Did external addressing, please find a word document with the two outputs you requested. Thanx.
No tracert (traceroute) is included.  this just says SOMEWHERE before the address is reached (or on the return path) packet is dropped.  tracert will give a clue as to WHERE it's failing.
Let me check.
