Finding best solution for small ISP network
perpaal
Level 4
Level 4
Want some input on what will be the best solution in this scenario.
Basicly this is a small ISP network.
In each area, behind the C3750s, there are som DSLAMs, access switches and wireless base stations.
Some of the clients need L2 connections across the network, as they have several offices.
The C3750s are all Cisco WS-C3750G-12S-E.
The management networks must be isolated, but be able to reach each other.
What do you think would be the best solution realising this network, based on the awailable hardware?
perpaal
Level 4
Level 4
Bumping this up
What solution would you use?
