Flow control error
prashantrecon
Level 7
Level 7
On site 2 etherchannel is showing up but site 1 etherchannel is showing suspended
I am geeting flow control eeror
site2
47     Po47(RU)         -        Gi1/0/39(P) Gi2/0/39(P)
MUMBAISW1#show int gi1/0/39
GigabitEthernet1/0/39 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is e8b7.4812.a943 (bia e8b7.4812.a943)
  Description: " p2p tata 10mbps"
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:36:38, output 00:00:03, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 11
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     1330462 packets input, 1732660399 bytes, 0 no buffer
     Received 358 broadcasts (237 multicasts)
     0 watchdog, 237 multicast, 0 pause input
     891799 packets output, 117989357 bytes, 0 underruns
MUMBAISW1#show int gi2/0/39
GigabitEthernet2/0/39 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is e8b7.4812.a945 (bia e8b7.4812.a945)
  Description: " p2p airtel 10mbps"
     reliability 255/255, txload 1/255, rxload 26/255
  Last input 00:00:03, output 00:00:32, output hang never
  5 minute input rate 10506000 bits/sec, 908 packets/sec
  5 minute output rate 417000 bits/sec, 519 packets/sec
     2878288 packets input, 3998920212 bytes, 0 no buffer
     Received 93 broadcasts (88 multicasts)
     0 watchdog, 88 multicast, 0 pause input
     1792396 packets output, 204999828 bytes, 0 underruns
Site1
77     Po77(RU)         -        Gi1/32(s)      Gi2/32(P)
nihilent01#show int gi1/32
GigabitEthernet1/32 is up, line protocol is down (notconnect)
  Hardware is C6k 1000Mb 802.3, address is 001e.f7e6.a180 (bia 001e.f7e6.a180)
  Description: "tata point to point etherchannel"
  MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input 00:00:37, output 00:42:58, output hang never
  Input queue: 0/75/1/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 1000 bits/sec, 2 packets/sec
  L2 Switched: ucast: 12 pkt, 768 bytes - mcast: 45 pkt, 2880 bytes
  L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
     366592733 packets input, 64046114375 bytes, 0 no buffer
     Received 71925 broadcasts (0 IP multicasts)
     1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     520052593 packets output, 646656050119 bytes, 0 underruns
     3 output errors, 0 collisions, 8 interface resets
nihilent01#show int gi2/32
GigabitEthernet2/32 is up, line protocol is up (connected)
  Description: "p2p airtel 10 Mbps"
     reliability 255/255, txload 26/255, rxload 1/255
  input flow-control is off, output flow-control is on
  Clock mode is auto
  Last input 00:00:05, output 00:00:06, output hang never
  5 minute input rate 374000 bits/sec, 511 packets/sec
  5 minute output rate 10506000 bits/sec, 906 packets/sec
  L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
     1939787 packets input, 217667628 bytes, 0 no buffer
     Received 8949 broadcasts (653 multicasts)
--More--
prashantrecon
Level 7
Level 7
Hi all
Above flowcontrol issue is sorted.
But the issue we are not able to obtain redudancy
As there are two isp link.
When my one link goes down  than the entire traffic is dropping
