Flushes on a POS interface
phillipediab
I am getting a lot of flushes on a POS interface. Can someone tell me why i am seeing these flushes and how can I fix the problem.
thanks
show int pos 1/1/0
POS1/1/0 is up, line protocol is up
Hardware is Packet over Sonet
Internet address is 172.24.254.14/30
MTU 4470 bytes, BW 155000 Kbit, DLY 200 usec,
reliability 255/255, txload 9/255, rxload 85/255
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Scramble disabled
Last input 00:00:00, output 00:00:01, output hang never
Last clearing of "show interface" counters 1d15h
Input queue: 33/75/2/753013 (size/max/drops/flushes); Total output drops: 25
Queueing strategy: VIP-based fair queuing
Output queue: 0/40 (size/max)
30 second input rate 51818000 bits/sec, 11471 packets/sec
30 second output rate 5889000 bits/sec, 2702 packets/sec
599539441 packets input, 298870698550 bytes, 0 no buffer
Received 16477 broadcasts, 47 runts, 0 giants, 0 throttles
0 parity
1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 1 abort
202510627 packets output, 52630640776 bytes, 0 underruns
0 output errors, 0 applique, 2 interface resets
2 carrier transitions
wong34539
Level 11
Level 11
I think Flushes or overrun error occurs on a POS(Packet over SONET) because the input rate may be exceeding the receiver's ability to handle the data.This means that the other side of the connection sends the data faster than the receiving controller could process it. One solution would be to rate-limit the TX traffic on the remote end or change the connection to a higher speed interface.If it is a backup link for any GigE card, then try moving that card to someother Bus
