Frame Relay configuration
rohit_kulkarni
I've a cisco 7206 Router on which 2 FR configured as:
Serial1/0 up
Serial1/0.300 -- 172.26.xxx.x
Serial1/1 -- 172.26.xxx.x
Now, I am having one more FR and after few days MPLS connectivity between India n US.
I've one subnet 172.26.x.0/22 on LAN. That is connected to core L3 switch --Firewall and router pointing towards core.
Can I use 172.26.X.0/24 subnet as a Secondary IP because my client has allowed me /22 only.
Can you suggest me any other solution?
Diagram:
LAN-->FW-->Router-->Multiplexer-->(US)multiplexer2-->Router2---client network
I've Static routes configured.
Rohit
rajivrajan1
Level 3
Level 3
most probably i might work.is it possible to see the config.. so that exact picture would be clear.
sh run
Building configuration...
Current configuration : 5474 bytes
version 12.3
service tcp-keepalives-in
service timestamps debug datetime msec localtime
service timestamps log datetime localtime
service password-encryption
hostname
boot-start-marker
boot system flash disk0:c7200-ik9s-mz.123-13.bin
boot system flash disk0:c7200-is-mz.122-11.T.bin
boot-end-marker
logging buffered notifications
no logging console
logging monitor notifications
enable secret level 5 5
enable password 7 C
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization commands 1 default group tacacs+ local if-authenticated
aaa authorization commands 15 default group tacacs+ local if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default stop-only group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
aaa accounting network default start-stop group tacacs+
aaa session-id common
ip subnet-zero
no ip source-route
ip flow-cache timeout active 1
ip cef
no ip domain lookup
ip domain name etpl
ip host 172.26.xxx.x
ip host 172.25.xx.xx
no ip bootp server
ip ssh time-out 60
voice call carrier capacity active
interface FastEthernet0/0
ip address 172.25.xx.x 255.255.255.240
no ip proxy-arp
ip route-cache flow
duplex full
speed 100
ntp disable
no cdp enable
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no cdp enable
interface Serial1/0
ip address 172.26.xxx.x 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation frame-relay
ip route-cache flow
no ip mroute-cache
ntp disable
serial restart-delay 0
no fair-queue
frame-relay interface-dlci 300
interface Serial1/1
no ip proxy-arp
frame-relay interface-dlci 301
frame-relay lmi-type cisco
interface Serial1/2
no ip address
no ip proxy-arp
shutdown
no cdp enable
interface Serial1/3
ip address 10.2x.xx.x 255.255.255.252
no ip proxy-arp
ip route-cache flow
frame-relay interface-dlci 77
ip classless
Hi!
Can anyone provide me solution that how should I do Routing without single point of failuer.
As of now I have configured 3 FR and waiting for MPLS link.I am thinking for CE router also as will that connect to process router or to FW or L3switch.Where should I connect?
Rohit
