Frame-Relay Priority Queuing defaults?
jimmycher
We have a 3845 (v12.4) that has a frame-relay connection on it's S2/0 interface.
It calls out "priority-queue 1", but there is no frame-relay map class "1".
Does this mean everything goes into the "normal" queue, and it is effectively FIFO ??
Thanks.
Peter Paluch
Jimmy,
Can you post the full configuration of the Serial2/0 interface including subinterfaces, if any? More context is needed to understand the configuration. Thanks!
Best regards,
Peter
Sadly, I can not copy the config.
But if I have an interface that states "Priority-Queue 1", and "1" is not defined anywhere, it would have no effect, right?
thanks.
