g.shdsl sync problems
fsoffia
Level 3
Level 3
hallo I have a cisco1841 IOS 12.4(15)T8 with a HWIC-2SHDSL card in slot 0.
It is connected to a 4-wire, annex B, 4096kbps shdsl line.
If I disconnect the shdsl cable the hwic does not resync !!!!
I must shutdown and the up the shdsl-group to resync.
The only debug that give me an output is this:
1841-TEST01#debug hwic-shdsl firmware
HWIC-SHDSL firmware events logging debugging is on
1841-TEST01#
Mar 24 10:26:42.815: SHDSL0/0/0 FW MSG: DMT[0]: Waiting for ATM-TC sync: 0x0
1841-TEST01#
Mar 24 10:26:45.259: SHDSL0/0/0 FW MSG: DMT[0]: Waiting for ATM-TC sync: 0x0
1841-TEST01#
Mar 24 10:26:47.715: SHDSL0/0/0 FW MSG: DMT[0]: Waiting for ATM-TC sync: 0x110
1841-TEST01#
Mar 24 10:26:50.207: SHDSL0/0/0 FW MSG: DMT[0]: Waiting for ATM-TC sync: 0x0
1841-TEST01#
Mar 24 10:26:52.659: SHDSL0/0/0 FW MSG: DMT[0]: Waiting for ATM-TC sync: 0x0
1841-TEST01#
Mar 24 10:26:55.107: SHDSL0/0/0 FW MSG: DMT[0]: Waiting for ATM-TC sync: 0x110
1841-TEST01#
Mar 24 10:26:57.563: SHDSL0/0/0 FW MSG: DMT[0]: Waiting for ATM-TC sync: 0x10
1841-TEST01#
Mar 24 10:27:00.059: SHDSL0/0/0 FW MSG: DMT[0]: Waiting for ATM-TC sync: 0x0
1841-TEST01#
This is the shdsl config I'm using:
controller SHDSL 0/0/0
dsl-group 0 pairs 0, 1
shdsl annex B
shdsl rate 4096
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
ip address 80.244.113.48 255.255.255.0
pvc 8/35
encapsulation aal5snap
I tried config oam-pvc manage but it does not work.
A bintec R3400 router on same line works fine !!
COULD IT BE AN HWIC FIRMWARE PROBLEM ?
coul you hel me ?
francesco
Giuseppe Larosa
Hello Francesco,
there has been another thread about G.SHDSL some mounths ago.
The problem was the cable
check the cabling because the sh controller shows the DSL pairs as down or you need to define what pairs you use.
see
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cc22735/10#selected_message
Hope to help
Giuseppe
hello Giuseppe
I have an HWIC-2SHDSL card with RJ11 port
My cable is:
CISCO-RJ11 6/4 LINE-RJ45
pin 1 --------- green ----------- pin 7
pin 2 ------ white/orange ------- pin 4
pin 3 ------- orange ------------ pin 5
pin 4 ------- white/green ------- pin 8
RJ11
L0 pin 2,3
L1 pin 1,4
If I disconnect the cable for about 40'' then the controller does not resynch
If I cler the controller it resynch but not always, it depends on time elapsed without cable, so I must shutdown the dsl-group 0 to resync the line !!
I watched the thread you send me but I don't know how to read "show controlle shdsl 0/0/0 detailed " !!!
I attached "show controller shdsl detailed" without sync and with sync.
Please could you tell me something about the output ?
thanks, best regards
Francesco
Hello Francesco,
this document can help for configuration and troubleshooting
https://www.cisco.com/en/US/docs/routers/access/interfaces/software/feature/guide/shdslfm.html#wp1088634
for example I would add
shdsl 4-wire mode
in controller shdsl
Edit:
I see that the 4 wire mode is enabled term cpe
Termination: CPE, line mode: 4-wire, Annex-B
Hope to help
Giuseppe
