GDOI problem
Ahmed90
Community Member
Hello, I'm new here,
I want to execute GDOI command on Cisco 1700 router in GNS3 but it doesn't execute and says "invalid input "
what's the problem ??
the command is " crypto gdoi group GDOI_GROUP "
the error is    " invalid input detected at '^' marker
6 Replies 6
omz
What version of IOS?
Command History
Release
Modification
12.4(6)T
This command was introduced.
15.2(3)T
This command was modified. The ipv6 keyword was added.
Please move this thread to something more appropriate. You have posted in policy and access which has to do with Ise anyconnect segmentation issues
To what part of the community should i moved it..
BR,
Are you running the right version of IOS. ? Does 1700 has an IOS which
supports GDOI. I don't think so
Thanks a lot ,
you right ,it does not support GDOI
Hello
GNS3 - <-- 3700 Software (C3725-ADVENTERPRISEK9-M), Version 12.4(15)T14, supports GDOI, In fact i have recently created a proof of concept with multiple key servers and group members all running in gns3 with the above
Kind Regards
Paul
