GRE tunneling
ColForbin
Level 3
Level 3
I have a remote site I need to make some tunneling changes to. It connects back to the core router by way of a layer 3 circuit to another remote location that has a dedicated p2p to the core. R1<>L3circuit<>R2<>leasedline<>R3core
R1-R2have a gre tunnel.  L3 circuit is just transport the isp does no routing.
i need to encrypt traffic from R1 to R3 and back. 2 questions naturally
what’s the best way to accomplish if that means replacing hardware so be it
and two, best way given constraints of current hardware?
""R1-R2have a gre tunnel.  L3 circuit is just transport the isp does no routing.
i need to encrypt traffic from R1 to R3 and back. 2 questions naturally""
This your requirements and it need mandatory two tunnel.
Since we use two tunnel R1 must do dual encap' other routers only have one encap
To test ping from R1 to R3 you need to specify LO to check underlying abd you can use tunnel IP to check overlying
MHM
19 Replies 19
Why you not use VTI ?
MHM
I think it get solution
Underlying 1
R1 To R2 abd R2 to R3
Underlying 2
GRE tunnel between R1 abd R2 advertise IP that use for ...
... overlaying 1 GRE tunnel (protect by IPsec) between R1 and R3
MHM
Because of the reliance on the existing gre tunnel. Causes an encapsulation problem from R1->R3
Because of the reliance on the existing gre tunnel. Causes an encapsulation problem from R1->R3 <<- can you elaborate
MHM
Quick answer is put a tunnel from R1 to R3 then r1 encapsulates original tunnel and then the new tunnel. From R3 it’s just wrapped in the new tunnel.
I dont get again
Which crom these below layer can not config?
Underlying 1
Underlying 2
So implementing vti:
r3 sends traffic to r1 by encapsulating it in the new IPsec tunnel and sends it off to the next hop on the point to point connection which is r2, no issue.
The return traffic from r1:
encapsulates it in the new IPsec tunnel, how do I get to r3? Oh existing gre tunnel. Adds second encapsulation and sends off to r2.
To elaborate further the r3 connection to r2 is a /30, it’s a leased line.
The connection from r1 to r2 is a /29 using rfc1918 addressing from that isp.
r1 gi0/0 192.168.5.154/29
Ip route 192.168.5.144 255.255.255.248 gi0/0 192.168.5.155
r2 gi0/0 192.168.5.146/29
ip route 192.168.5.152 255.255.255.248 gi0/0 192.168.5.145
gre is r1 192.168.5.154 to 192.168.5.146
that tunnel is the only path for r1 to r3 in the current topology. So that tunnel must exist. So adding a tunnel from 1->3 creates a double encaps from r1.
if there’s a better way to do the underlay?
or another similar tunnel added to the underlay from r3 to r2 so both sides are symmetrical?
then a tunnel over the top with double encapsulation at either end?
Interesting I can’t see this diagram unless I log off my profile. Anyway yes that is 100% the topology. I’m not clear on what you mean by the route statements.
R1 use static route using egress gre tunnel to learn far R3 LO
R2 use same to learn R1 LO
R3 use static route egress direct connect to R2 to learn R1 LO
R2 use static route egress direct connect to R3 to learn R3 LO
Now R1/R3 LO is known by R1 and R3
We run gre tunnel using these LO as source/dest
That it
MHM
  • ip route 3.3.3.3 255.255.255.255 next hop Tunnel0 or R2 tunnel addr?
  • ip route 1.1.1.1 255.255.255.255 next hop tunnel0 or R1 tunnel addr?
  • r1 gi0/0 is 10.10.10.1/30
  • r2 gi0/1 is 10.10.10.2/30
  • Ip route 1.1.1.1 255.255.255.255 10.10.10.2?
  • just the reverse of r3 to r2?
New tunnel 2 on r1
tunnel source 1.1.1.1
Tunnel dest 3.3.3.3
Reverse that for r3 of course.
that’s all the new stuff. The underlay would just be the existing working current config right?
  • ip route 3.3.3.3 255.255.255.255 next hop Tunnel0 or R2 tunnel addr? Ip route 3.3.3.3 255.255.255.255 tunnel 0
  • ip route 1.1.1.1 255.255.255.255 next hop tunnel0 or R1 tunnel addr? Ip route 1.1.1.1 255.255.255.255 tunnel0
In R3
Ip route 1.1.1.1 255.255.255.255 <R2 Ip of interface connect to R3>
