Help NATing LAN host to Loopback interface.
Lewis Goulden
         Due to security reasons the VPN only allows the source IP of a loopback with a PUB IP.
In order to use this address from the LAN I assuming the best approach is to NAT the LAN host to the Loopback IP.
I need help doing this.
Host IP : 192.168.1.10 (in vlan1)
loopback0 :  1.1.1.1  (all traffic needs to be NATed to this from host to transit VPN)
any help would be greatly appreciated.
Hello, Lewis.
Now it's much clearer.
I guess you need a single command on your router:
ip nat inside source static udp 192.168.1.10 3305 1.1.1.1 3305
(or replace it with tcp if needed)
it won't help if client will originate session from any other port (than 3305).
8 Replies 8
Hello.
What kind of VPN do you want?
Do you use the loopback to originate/receive any other traffic?
PS:
The easiest could be like
int LAN_internal_interface
ip nat inside
int WAN_external_interface
ip nat outside
ip access-l sta LAN_NAT
permit 192.168.1.0 0.0.0.255
ip nat inside source list LAN_NAT int lo0 overload
or
ip nat pool LO0 1.1.1.1 1.1.1.1 prefix-length 30
ip nat inside source list LAN_NAT pool LO0 overload
to do a simple test i connected two routers via GNS3
R2 ------ fa0/0 ------ ----- fa0/0 -----> R3
R2 has loopback0 1.1.1.1
R2 has LAN (fa0/0) 192.168.1.1/24
R2 has loopback1 192.168.2.1
R3 is acting as a LAN host 192.168.1.10
When i telnet from R3 to the Loopback1 address 192.168.2.1 i should be natted to 1.1.1.1 and if i do a show users i should see 1.1.1.1 IP
but i do not.
Example:
R2#telnet 192.168.2.1
Trying 192.168.2.1 ... Open
User Access Verification
Password:
R2>en
Password:
R2#show users
    Line       User       Host(s)              Idle       Location
   0 con 0                idle                 00:03:14
  66 vty 0                192.168.2.1          00:00:00 192.168.1.10
* 67 vty 1                idle                 00:00:00 192.168.2.1
  Interface    User               Mode         Idle     Peer Address
R2#
Here is the configurations.
R2:
Current configuration : 1569 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
enable secret 5 $1$mxfk$S00eOFiT06vvqUnP/8NKo0
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip tcp synwait-time 5
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip nat outside
ip virtual-reassembly
interface Loopback2
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/0
ip nat inside
duplex auto
speed auto
interface Serial0/0
no ip address
encapsulation frame-relay
clock rate 2000000
interface Serial0/0.100 point-to-point
ip address 23.23.23.1 255.255.255.252
frame-relay interface-dlci 100
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool Lo0 1.1.1.1 1.1.1.1 prefix-length 30
ip nat inside source list LAN-NAT pool Lo0 overload
ip access-list standard LAN-NAT
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
password nortel
login
end
R3:
Current configuration : 1181 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip address 192.168.1.10 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
clock rate 72000
interface Serial0/0.200 point-to-point
ip address 23.23.23.2 255.255.255.252
frame-relay interface-dlci 200
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
Please use 3 routers in GNS: R1-R2-R3. Don't us ip unnumbered.
R2 is doing NAT.
telnet from R1 to R3.
provide your config from R2.
PS: "ip nat ouside" is needed under WAN interface, not loopback!
Lewis,
I don't believe you're going to need "ip nat outside" on your loopback interface in order to get this to work the way that you want. You will, however, need "ip nat outside" on the serial side interface since your traffic is really going out of that interface. Also, when you telnet, source the interface that you're using for nat inside like:
telnet 192.168.2.1 /source f0/0
If you don't source it, it's going to use the wan interface in your situation.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
sorry just to explain my problem better.
The IP of the loopback has to be the source IP of traffic when transiting this VPN.
The GNS lab config is purly to try and NAT LAN traffic the the IP of a loopback.
Sorry, Lewis, but word VPN is a little confusing.
Could you please explain what do you want to achieve?
What traffic will host be sending - will it be common TCP sessions, or some sort of VPN (SSL VPN, IPSec or any other encapsulation)?
IPSec VPN
Diagram attached
Hello, Lewis.
