Help with packet tracer PC command prompt
se~40465
I am new to packet tracer. I need to ping from PC4 to PC1. Networking is done and its okay when I check via router. But I need to ping from PC command promt but why is it showing my own pc... how can I change that and do the ping in PC4??
not sure what you are asking. The prompt you see is from PC4. What do you expect to see ?
Post the zipped Packet Tracer project (.pkt) file if possible...
Martin L
it is not showing your own cml, it is PC4.  you can see device id on thop left corner of window, PC4. and cml shows Packet tracer PC Command line 1.0 which is PT cml not your Windows cml
you can click on a device to see tabs and options, then click on a tab to go there. Command line is in the Desktop tab of PC. Find icons of PC1 and PC4, click on each to bring tab window.
Go to Cisco Net Academy site to learn about PT; they have basic to advanced class with instructions and videos on PT.
https://www.netacad.com/courses/packet-tracer
Regards, ML
**Please Rate All Helpful Responses **
