help with router logging using "logging persistent url flash:"
Andy White
Level 3
Level 3
I have a few Cisco 3G routers configured across Europe which VPN back to an ASA and occasionally 3G will drop and sometimes someone will power-cycle the router which loses the log history so I started to use logging persistent url flash: to save the logs to flash, but I don't think it is working properly or the log space is getting used up as it currently only has 2 days worth of syslog info in the flash and I need it much longer so I can see what the 3G router is trying to do when offline.
I have added a reachability SLA on another site that pings Google and when it can't after so many attempts it does a "shut" no "no shut" on the cellular interface which has helped with reliability.
Anyway here is the loging and flash info, maybe you can see an issue?
sh flas
-#- --length-- -----date/time------ path
1     31291784 Aug 21 2012 09:04:50 +01:00 c800-universalk9-mz.SPA.151-4.M4.bin
2         3214 Aug 21 2012 09:23:12 +01:00 cpconfig-8xx.cfg
3      3000320 Aug 21 2012 09:23:28 +01:00 cpexpress.tar
4         1038 Aug 21 2012 09:23:36 +01:00 home.shtml
5       122880 Aug 21 2012 09:23:44 +01:00 home.tar
6      1697952 Aug 21 2012 09:23:58 +01:00 securedesktop-ios-3.1.1.45-k9.pkg
7       415956 Aug 21 2012 09:24:10 +01:00 sslclient-win-1.1.4.176.pkg
8            0 Aug 29 2013 11:46:48 +01:00 syslogs
9        28938 Jan 23 2014 04:25:56 +00:00 syslogs/log_20140123-024152
10       28938 Jan 23 2014 08:28:44 +00:00 syslogs/log_20140123-064440
11       28938 Jan 23 2014 10:30:08 +00:00 syslogs/log_20140123-084605
12       28938 Jan 23 2014 06:27:20 +00:00 syslogs/log_20140123-044316
13         660 Aug 29 2013 11:47:20 +01:00 vlan.dat
14       12570 Jan 24 2014 01:40:02 +00:00 syslogs/log_20140123-103334
223473664 bytes available (36700160 bytes used)
logging buffered 51200 informational
logging persistent url flash:/syslogs size 131072 filesize 32768
no logging console
logging monitor informational
Maybe my sizing's are all wrong (never been too good at judging them)?
0 Replies 0
