High CPU usage due Encrypt Proc
OMAR CANDARAVE
Hi all,
I have a router with high CPU usage due:
Encrypt Proc
Router
cisco 1721 (MPC860P) processor (revision 0x300) with 57506K/8030K bytes of memory.
interface Serial0
description #### TELCO
bandwidth 128
ip address 200.94.44.65 255.255.255.252
no cdp enable
crypto map MYCRYPO
end
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key myKey address 216.33.48.49
crypto isakmp keepalive 10
crypto ipsec transform-set XX esp-3des esp-md5-hmac
mode transport
crypto map MYCRYPO 10 ipsec-isakmp
set peer 216.33.48.49
set transform-set XX
match address 102
router1#sh int s0
Serial0 is up, line protocol is up
  Hardware is PowerQUICC Serial
  Description: #### TELCO
  Internet address is 200.94.44.65/30
  MTU 1500 bytes, BW 128 Kbit, DLY 20000 usec,
     reliability 255/255, txload 176/255, rxload 3/255
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 28/75/158175/0 (size/max/drops/flushes); Total output drops: 497
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/293 (size/max total/threshold/drops)
     Conversations  0/9/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 96 kilobits/sec
  5 minute input rate 892000 bits/sec, 140 packets/sec
  5 minute output rate 226000 bits/sec, 106 packets/sec
     42910203 packets input, 3602478677 bytes, 10 no buffer
     Received 75479 broadcasts, 16 runts, 1 giants, 0 throttles
     44323 input errors, 18116 CRC, 15616 frame, 0 overrun, 0 ignored, 10591 abort
     33670083 packets output, 33720500 bytes, 0 underruns
     0 output errors, 0 collisions, 328 interface resets
     34 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
router1#sh proc cpu sor
CPU utilization for five seconds: 99%/8%; one minute: 99%; five minutes: 97%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  80   283596832  26700772      10621 90.18% 89.03% 86.46%   0 Encrypt Proc
  35      498200    979207        508  0.24%  0.08%  0.07%   0 IP Input
  61      251432   1082701        232  0.16%  0.04%  0.03%   0 CEF process
   5      428608     83317       5144  0.16%  0.08%  0.06%   0 Check heaps
  78        5248      4008       1309  0.16%  0.30%  0.39%   6 Virtual Exec
  10      589400    649052        908  0.16%  0.07%  0.06%   0 ARP Input
  41      100488   2992151         33  0.08%  0.03%  0.01%   0 SSS Feature Time
  95      216732    417253        519  0.08%  0.01%  0.00%   0 IP SNMP
........ more
Let me know if more information needed.
Any advice?
8 Replies 8
John Blakley
Can you clear counters and repost "sh int s0"? I'm curious about the CRCs that you have on the interface. I'm not sure how long this router's been up, but the counters have never been cleared. If you're still incrementing, I'd talk to the provider about having your line checked.
Has this worked ok in the past?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
If you don't have the optional encryption module, or if for some reason it's not being used, it doesn't take much 3DES to consume the main CPU.
Hi Omar,
Encryption can be done in software or hardware. You need to have a VAM module in the router which would do the hardware encryption. If software is not able to handle the encrytpion you would see high CPU utilization due to Encrypt process.Temporay fix is you need to remove the crypto map on the interface. You can use show version to see if VAM module is thereon the device.
Sathvik
This is the show ver but I can´t see the VAM module, Sathvik do you recomend install that moduele?
router1#sh ver
IOS (tm) C1700 Software (C1700-K9O3SY7-M), Version 12.3(20), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Tue 08-Aug-06 17:59 by kesnyder
Image text-base: 0x8000816C, data-base: 0x810A3620
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-BK9NO3R2SY7-M), Version 12.3(9), RELEASE SOFTWARE (fc2)
router1 uptime is 1 week, 2 days, 22 hours, 50 minutes
System restarted at 20:31:41 Summer Tue Jun 25 2013
System image file is "flash:c1700-k9o3sy7-mz.123-20.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Processor board ID FOC08080QDN (3072600685), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Hi Omar,
Yes would recommend to install a VPM module. Hacve taken some  text capture from the  below mentioned URL which would help you understand.
The optional VPN hardware encryption module for the Cisco 1721 router further optimizes VPN encryption performance. By offloading encryption tasks to the VPN module, the router processor is freed to handle other operations. The VPN module accelerates the rate at which encryption occurs, speeding the process of transmitting secure data, a critical factor when using 3DES encryption.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00800920ec.html
Rate the post if it helps!!
Sathvik K V
Hi Sathvik, this router is end of life so the customer would not want to buy a VPN module for it. What other router do you recommend?
Hi Omar,
Would recommend Cisco1921. Please note if your are using IOS version universalk9 they you would have to purchase the license.
Show version should show you the below logs after installing a license.
Technology Package License Information for Module:'c1900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
data          None          None           None
Sathvik K V
Disclaimer
Posting
The 1721 is rated at 12 Kpps, and doesn't have any hardware encryption, standard.
The current high end 800 series have a faster Kpps rating, and I believe, come with hardware encryption standard.  (The hardware for encryption makes a huge difference).  For example the 880 series is rated at 50 Kpps.
I've attached a Cisco white paper on ISR performance.  Select a model for your expected bandwidth processing needs.
