High CPU Utilization in cisco 4506 switch
Hi ,
Iam getting High CPU utilization in one of my switch which has many layer 3 vlan interface and many other routing interface.
In the o/p of show process cpu i get 64 % CPU utilization. The o/p is as below
PID Runtime(ms) Invoked    uSecs    5Sec    1Min       5Min    TTY  Process
30 37656252881151776906     3269     62.31%   63.95%   64.82%    0     Mgmt LoPri
And rest of the other process are very normal. Only cat4k Mgmt LoPri is consuming very high cpu utilization.
I have checked all the interface input queue and all are very normal.
Iam not able to get through what could be the actual problem. can anyone plsz guide me.
Rgds,
Ajith
10 Replies 10
garapoglou
Level 3
Level 3
Could you post the "sh platform health" output of that switch?
Best regards,
Giorgos
Thank you,
I'd like you to share the results of the "sh platform cpu packet statistics" as well.
Giorgos
Hi  Giorgos,
below is the sh platform cpu statistics all output.
switch#show platform cpu packet statistics all
Packets Dropped In Hardware By CPU Subport (txQueueNotAvail)
CPU Subport  TxQueue 0       TxQueue 1       TxQueue 2       TxQueue 3
           0            5939               0               0      4191546441
           1               0               0               0               0
           2               0          474885               0               0
           3               0         9777960               0               0
           4               0               0               0               0
           5               0               0               0               0
           6               0               0               0          112995
           7               0               0               0          195148
RkiosSysPacketMan:
Packet allocation falures: 0
Packet Buffer(Software Common) allocation falures: 20408
Packet Buffer(Software ESMP) allocation falures: 0
Packet Buffer(Software EOBC) allocation falures: 0
IOS Packet Buffer Wrapper allocation falures: 0
Packets Enqueued Overall
Total                5 sec avg 1 min avg 5 min avg 1 hour avg
                   0         0         0         0          0
Packets Not Enqueued Overall
                   0         0         0         0          0
Packets Dropped In Processing Overall
          1937982410        81        89        76         68
Packets Not Enqueued by CPU event
Event             Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Control Packet                       0         0         0         0          0
Input Acl                            0         0         0         0          0
RPF Fail                             0         0         0         0          0
Adjacency Same If                    0         0         0         0          0
L3 Forward                           0         0         0         0          0
NFL Copy To CPU                      0         0         0         0          0
Output Acl                           0         0         0         0          0
MTU Check Fail                       0         0         0         0          0
SA Miss                              0         0         0         0          0
L2 Forward                           0         0         0         0          0
SPAN                                 0         0         0         0          0
CPU Generated                        0         0         0         0          0
Unknown                              0         0         0         0          0
Packets Dropped In Processing by CPU event
Input Acl                   1937714758        81        89        76         68
RPF Fail                             0         0         0         0          0
SA Miss                            404         0         0         0          0
SPAN                                 0         0         0         0          0
Unknown                              0         0         0         0          0
Packets Not Enqueued by Priority
Priority          Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Unknown                              0         0         0         0          0
Normal                               0         0         0         0          0
Medium                               0         0         0         0          0
High                                 0         0         0         0          0
Crucial                              0         0         0         0          0
Super Crucial                        0         0         0         0          0
Packets Dropped In Processing by Priority
Unknown                              0         0         0         0          0
Normal                       148249321         2         1         2          0
Medium                          267652         0         0         0          0
High                        1789732685        78        85        72         61
Crucial                              0         0         0         0          0
Packets Not Enqueued by Reason
Reason            Total                5 sec avg 1 min avg 5 min avg 1 hour avg
RxQueueNotAvail                      0         0         0         0          0
RxNoBuffersAvail                     0         0         0         0          0
RxBadCpuEvent                        0         0         0         0          0
Testing                              0         0         0         0          0
Packets Dropped In Processing by Reason
BadPddType                            0         0         0         0          0
VlanZeroBadCrc                        0         0         0         0          0
VlanZeroGoodCrc                       0         0         0         0          0
ReplVlan0GoodCrc                      0         0         0         0          0
NoPimPhyportMap                       0         0         0         0          0
NoPimPhyport                          0         0         0         0          0
UnimplementedEvt                      0         0         0         0          0
SrcAddrTableFilt                    119         0         0         0          0
NoL2Vlan                              0         0         0         0          0
STPDrop                               0         0         0         0          0
UnknownLyr-Bridge                     0         0         0         0          0
UnknownLyr-OutAcl                     0         0         0         0          0
L2DstDrop                           290         0         0         0          0
L2DstDropInAcl                        0         0         0         0          0
L2DstDropOutAcl                       0         0         0         0          0
AclNoVlan                             0         0         0         0          0
AclActionDrop                         0         0         0         0          0
AclActionRedirect                     0         0         0         0          0
AclActionUnsupptd                     0         0         0         0          0
UnknownBridgeAct                      0         0         0         0          0
NoTxInfo                              0         0         0         0          0
NoDstPorts                          599         0         0         0          0
NoFloodPorts                 1937981402        81        89        76         68
ControlNoL2DstEnt                     0         0         0         0          0
InvalidAclAction                      0         0         0         0          0
AclInputErr                           0         0         0         0          0
OutAclEvntOnInAcl                     0         0         0         0          0
AclOutputErr                          0         0         0         0          0
ReservedPort                          0         0         0         0          0
EsmpNoTxInfo                          0         0         0         0          0
UnknownSource                         0         0         0         0          0
NoDriverTxPackets                     0         0         0         0          0
NoPimPort                             0         0         0         0          0
RouteLookupFailed                     0         0         0         0          0
FragPktAllocFailed                    0         0         0         0          0
IpHdrException                        0         0         0         0          0
SpanEvent                             0         0         0         0          0
Dot1xUnauthCtrlPkt                    0         0         0         0          0
No Sw port for ARP                    0         0         0         0          0
No Sw port for ESMP                    0         0         0         0          0
Total packet queues 16
Packets Received by Packet Queue
Queue                  Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Esmp                        2065654863        81        86        72         71
Control                     1657903727        99       105        89         76
Host Learning                 31293215         1         0         0          0
L3 Fwd High                        921         0         0         0          0
L3 Fwd Medium                      108         0         0         0          0
L3 Fwd Low                327477670905     40628     46863     39023      37637
L2 Fwd High                       5977         0         0         0          0
L2 Fwd Medium                 30603047         0         0         0          0
L2 Fwd Low                  4205922340       106       113        97         71
L3 Rx High                   295806868         0         0         0          0
L3 Rx Low                    233898239        25        20        18         15
RPF Failure                         78         0         0         0          0
ACL fwd(snooping)           1957754823        82        90        77         70
ACL log, unreach                     0         0         0         0          0
ACL sw processing                    0         0         0         0          0
MTU Fail/Invalid                     0         0         0         0          0
Packets Dropped by Packet Queue
Esmp                                 0         0         0         0          0
Control                              0         0         0         0          0
Host Learning                   121604         0         0         0          0
L3 Fwd High                          0         0         0         0          0
L3 Fwd Medium                        0         0         0         0          0
L3 Fwd Low                  1248193440        58       177       141        139
L2 Fwd High                          0         0         0         0          0
L2 Fwd Medium                        0         0         0         0          0
L2 Fwd Low                   143658539         0         0         0          0
L3 Rx High                           0         0         0         0          0
L3 Rx Low                            0         0         0         0          0
RPF Failure                          0         0         0         0          0
ACL fwd(snooping)              3174004         0         0         0          0
Packets Transmitted from CPU per Output Interface
Interface              Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Fa2/1                                0         0         0         0          0
Fa2/2                                0         0         0         0          0
Fa2/3                                0         0         0         0          0
Fa2/4                                0         0         0         0          0
Fa2/5                                0         0         0         0          0
Fa2/6                                0         0         0         0          0
Fa2/7                                0         0         0         0          0
Fa2/8                                0         0         0         0          0
Fa2/9                                0         0         0         0          0
Fa2/10                               0         0         0         0          0
Fa2/11                               0         0         0         0          0
Fa2/12                               0         0         0         0          0
Fa2/13                               0         0         0         0          0
Fa2/14                               0         0         0         0          0
Fa2/15                               0         0         0         0          0
Fa2/16                               0         0         0         0          0
Fa2/17                               0         0         0         0          0
Fa2/18                               0         0         0         0          0
Fa2/19                               0         0         0         0          0
Fa2/20                               0         0         0         0          0
Fa2/21                               0         0         0         0          0
Fa2/22                               0         0         0         0          0
Fa2/23                               0         0         0         0          0
Fa2/24                               0         0         0         0          0
Fa2/25                               0         0         0         0          0
Fa2/26                               0         0         0         0          0
Fa2/27                               0         0         0         0          0
Fa2/28                               0         0         0         0          0
Fa2/29                               0         0         0         0          0
Fa2/30                               0         0         0         0          0
Fa2/31                               0         0         0         0          0
Fa2/32                               0         0         0         0          0
Fa2/33                               0         0         0         0          0
Fa2/34                               0         0         0         0          0
Fa2/35                               0         0         0         0          0
Fa2/36                               0         0         0         0          0
Fa2/37                               0         0         0         0          0
Fa2/38                               0         0         0         0          0
Fa2/39                               0         0         0         0          0
Fa2/40                               0         0         0         0          0
Fa2/41                               0         0         0         0          0
Fa2/42                               0         0         0         0          0
Fa2/43                               0         0         0         0          0
Fa2/44                               0         0         0         0          0
Fa2/45                               0         0         0         0          0
Fa2/46                               0         0         0         0          0
Fa2/47                               0         0         0         0          0
Fa2/48                               0         0         0         0          0
Fa3/1                                0         0         0         0          0
Fa3/2                                0         0         0         0          0
Fa3/3                                0         0         0         0          0
Fa3/4                                0         0         0         0          0
Fa3/5                                0         0         0         0          0
Fa3/6                                0         0         0         0          0
Fa3/7                                0         0         0         0          0
Fa3/8                                0         0         0         0          0
Fa3/9                                0         0         0         0          0
Fa3/10                               0         0         0         0          0
Fa3/11                               0         0         0         0          0
Fa3/12                               0         0         0         0          0
Fa3/13                               0         0         0         0          0
Fa3/14                               0         0         0         0          0
Fa3/15                               0         0         0         0          0
Fa3/16                               0         0         0         0          0
Fa3/17                               0         0         0         0          0
Fa3/18                               0         0         0         0          0
Fa3/19                               0         0         0         0          0
Fa3/20                               0         0         0         0          0
Fa3/21                               0         0         0         0          0
Fa3/22                               0         0         0         0          0
Fa3/23                               0         0         0         0          0
Fa3/24                               0         0         0         0          0
Fa3/25                               0         0         0         0          0
Fa3/26                               0         0         0         0          0
Fa3/27                               0         0         0         0          0
Fa3/28                               0         0         0         0          0
Fa3/29                               0         0         0         0          0
Fa3/30                               0         0         0         0          0
Fa3/31                               0         0         0         0          0
Fa3/32                               0         0         0         0          0
Fa3/33                               0         0         0         0          0
Fa3/34                               0         0         0         0          0
Fa3/35                               0         0         0         0          0
Fa3/36                               0         0         0         0          0
Fa3/37                               0         0         0         0          0
Fa3/38                               0         0         0         0          0
Fa3/39                               0         0         0         0          0
Fa3/40                               0         0         0         0          0
Fa3/41                               0         0         0         0          0
Fa3/42                               0         0         0         0          0
Fa3/43                               0         0         0         0          0
Fa3/44                               0         0         0         0          0
Fa3/45                               0         0         0         0          0
Fa3/46                               0         0         0         0          0
Fa3/47                               0         0         0         0          0
Fa3/48                               0         0         0         0          0
Gi1/1                                0         0         0         0          0
Gi1/2                                0         0         0         0          0
Packets Received at CPU per Input Interface
Fa2/1                                0         0         0         0          0
Fa2/2                                0         0         0         0          0
Fa2/3                                0         0         0         0          0
Fa2/4                                0         0         0         0          0
Fa2/5                                0         0         0         0          0
Fa2/6                                0         0         0         0          0
Fa2/7                                0         0         0         0          0
Fa2/8                                0         0         0         0          0
Fa2/9                                0         0         0         0          0
Fa2/10                               0         0         0         0          0
Fa2/11                               0         0         0         0          0
Fa2/12                               0         0         0         0          0
Fa2/13                               0         0         0         0          0
Fa2/14                               0         0         0         0          0
Fa2/15                               0         0         0         0          0
Fa2/16                               0         0         0         0          0
Fa2/17                               0         0         0         0          0
Fa2/18                               0         0         0         0          0
Fa2/19                               0         0         0         0          0
Fa2/20                               0         0         0         0          0
Fa2/21                               0         0         0         0          0
Fa2/22                               0         0         0         0          0
Fa2/23                               0         0         0         0          0
Fa2/24                               0         0         0         0          0
Fa2/25                               0         0         0         0          0
Fa2/26                               0         0         0         0          0
Fa2/27                               0         0         0         0          0
Fa2/28                               0         0         0         0          0
Fa2/29                               0         0         0         0          0
Fa2/30                               0         0         0         0          0
Fa2/31                               0         0         0         0          0
Fa2/32                               0         0         0         0          0
Fa2/33                               0         0         0         0          0
Fa2/34                               0         0         0         0          0
Fa2/35                               0         0         0         0          0
Fa2/36                               0         0         0         0          0
Fa2/37                               0         0         0         0          0
Fa2/38                               0         0         0         0          0
Fa2/39                               0         0         0         0          0
Fa2/40                               0         0         0         0          0
Fa2/41                               0         0         0         0          0
Fa2/42                               0         0         0         0          0
Fa2/43                               0         0         0         0          0
Fa2/44                               0         0         0         0          0
Fa2/45                               0         0         0         0          0
Fa2/46                               0         0         0         0          0
Fa2/47                               0         0         0         0          0
Fa2/48                               0         0         0         0          0
Fa3/1                                0         0         0         0          0
Fa3/2                                0         0         0         0          0
Fa3/3                                0         0         0         0          0
Fa3/4                                0         0         0         0          0
Fa3/5                                0         0         0         0          0
Fa3/6                                0         0         0         0          0
Fa3/7                                0         0         0         0          0
Fa3/8                                0         0         0         0          0
Fa3/9                                0         0         0         0          0
Fa3/10                               0         0         0         0          0
Fa3/11                               0         0         0         0          0
Fa3/12                               0         0         0         0          0
Fa3/13                               0         0         0         0          0
Fa3/14                               0         0         0         0          0
Fa3/15                               0         0         0         0          0
Fa3/16                               0         0         0         0          0
Fa3/17                               0         0         0         0          0
Fa3/18                               0         0         0         0          0
Fa3/19                               0         0         0         0          0
Fa3/20                               0         0         0         0          0
Fa3/21                               0         0         0         0          0
Fa3/22                               0         0         0         0          0
Fa3/23                               0         0         0         0          0
Fa3/24                               0         0         0         0          0
Fa3/25                               0         0         0         0          0
Fa3/26                               0         0         0         0          0
Fa3/27                               0         0         0         0          0
Fa3/28                               0         0         0         0          0
Fa3/29                               0         0         0         0          0
Fa3/30                               0         0         0         0          0
Fa3/31                               0         0         0         0          0
Fa3/32                               0         0         0         0          0
Fa3/33                               0         0         0         0          0
Fa3/34                               0         0         0         0          0
Fa3/35                               0         0         0         0          0
Fa3/36                               0         0         0         0          0
Fa3/37                               0         0         0         0          0
Fa3/38                               0         0         0         0          0
Fa3/39                               0         0         0         0          0
Fa3/40                               0         0         0         0          0
Fa3/41                               0         0         0         0          0
Fa3/42                               0         0         0         0          0
Fa3/43                               0         0         0         0          0
Fa3/44                               0         0         0         0          0
Fa3/45                               0         0         0         0          0
Fa3/46                               0         0         0         0          0
Fa3/47                               0         0         0         0          0
Fa3/48                               0         0         0         0          0
Gi1/1                                0         0         0         0          0
Gi1/2                                0         0         0         0          0
switch#
Thank you Ajith,
I don't see any major problem. Leaving the CPU usage as it is, is the switch causing any problem to the network performance?
Giorgos
Hi Giorgos,
Thank you..
As of now it is not impacting the working of the network. But the cpu utilization is increasing till 88%.
Just not able to figure out what would be causing so much of Mgmt LoPri CPU utilization.
If anything you could finger on plsz suggest it would be very helpfull in troubleshoooting the issue.
Ajith
What IOS are you running?
IOS version :  cat4000-i5s-mz.122-25.EWA12.bin
Ummmm ... The EWA series IOS is pretty old.  I'd upgrade the IOS and see if there are improvements.
Limitless1801
I know there is a bug related to the 4506 and high CPU utilization but I don't Rene weber the IOS version. Have you made configuration changes?
Thanks, RG
Hi all,
I'm also experienceing the same problam as yours. Have you got the solution to your problem?
The difference is that
software version: cat4500-entservicesk9-mz.122-53.SG1.bin
chassis: WS-C4506-E
SW-02#sh processes cpu hist
    7777777777777777777776666666666777777777788888777777777777
    5999998888855555000008888888888222229999911111888888888811
100
90
80 ****************                    ********************
70 **********************************************************
60 **********************************************************
50 **********************************************************
40 **********************************************************
30 **********************************************************
20 **********************************************************
10 **********************************************************
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
    8777667788878877777777778888777776667877778888888888899888
    1325898955181301441646650303877724459188442465238918700641
100
90         **                                  **  ** *****
80 *  *  **###***     * ****#*#****    *#**  *##***##########
70 ####**##########*###############*  *######################
60 ##########################################################
50 ##########################################################
40 ##########################################################
30 ##########################################################
20 ##########################################################
10 ##########################################################
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    9988844832323233966889989877543332332333486899979877633333323323557989
    0432072464582643206024319763328632114356940943594085565973262372306725
100                         *                     *                    * *
90 **              *    ** **                 **** *                  * *
80 *****  *        *  *****#**              * *****#***              ***#
70 ##***  *        * ***##*#***             * **##*#****             ***#
60 ####*  *        ***#########             **#########*             *###
50 ####** *        ***#########*           ***#########*           ***###
40 ####***** *     #*##########****      ***###########*****       **####
30 #####**** ******#############**** ** ***#############***********######
20 #########*#######################**######################***#**#######
10 ######################################################################
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
SW-02#sh processes cpu sorted
CPU utilization for five seconds: 78%/2%; one minute: 73%; five minutes: 70%
  52  20299303521872289096       1084 70.95% 66.19% 63.21%   0 Cat4k Mgmt LoPri
  51  1517908736 301988123       5026  3.59%  3.58%  3.57%   0 Cat4k Mgmt HiPri
106    27452208 351631834         78  0.39%  0.38%  0.39%   0 Spanning Tree
203     25618522749068309          0  0.23%  0.20%  0.21%   0 HSRP Common
100    40990012 553230172         74  0.15%  0.14%  0.14%   0 IP Input
  14    12517032  76230143        164  0.15%  0.05%  0.05%   0 ARP Input
218          32       137        233  0.07%  0.03%  0.00%   1 Virtual Exec
164     3587744 111127984         32  0.07%  0.03%  0.02%   0 VLAN Manager
142     7034680  75234030         93  0.07%  0.09%  0.07%   0 CEF: IPv4 proces
  36     2617764  44256667         59  0.07%  0.08%  0.07%   0 IDB Work
212     4067260 260189871         15  0.07%  0.06%  0.07%   0 EIGRP-IPv4: Hell
  39      904368  47215013         19  0.07%  0.04%  0.05%   0 Per-Second Jobs
204    10340868 358613727         28  0.07%  0.03%  0.02%   0 HSRP IPv4
  13           0         1          0  0.00%  0.00%  0.00%   0 ifIndex Receive
  12           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
   7    54687412   6721341       8136  0.00%  0.08%  0.10%   0 Check heaps
  15           0         1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  11           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  19           4        55         72  0.00%  0.00%  0.00%   0 Entity MIB API
  20          36      1454         24  0.00%  0.00%  0.00%   0 EEM ED Syslog
  16           0         6          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  10          64         4      16000  0.00%  0.00%  0.00%   0 PrstVbl
  23           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  17           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  18           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  26        9716  44222986          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  27           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  21           0         1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  29           0         1          0  0.00%  0.00%  0.00%   0 client_entity_se
  30           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  31           0         1          0  0.00%  0.00%  0.00%   0 ARP Snoop
  32       12168  44222984          0  0.00%  0.00%  0.00%   0 Dynamic ARP Insp
  22          76    737606          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  34           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  35       15152   7931519          1  0.00%  0.00%  0.00%   0 Net Background
  24       10384  44222985          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  37           0      2682          0  0.00%  0.00%  0.00%   0 Logger
  38       15728  44222962          0  0.00%  0.00%  0.00%   0 TTY Background
  25           0         1          0  0.00%  0.00%  0.00%   0 IPC Managed Time
  40    20682172   1290296      16029  0.00%  0.06%  0.00%   0 Per-minute Jobs
  28           0         1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  42          24      4879          4  0.00%  0.00%  0.00%   0 IF-MGR event pro
  43           0         1          0  0.00%  0.00%  0.00%   0 ISSU PROCESS IPC
  44           0         1          0  0.00%  0.00%  0.00%   0 PrstVbl IPC Msg
  45           0         2          0  0.00%  0.00%  0.00%   0 cpf_msg_holdq_pr
  46           0         1          0  0.00%  0.00%  0.00%   0 cpf_msg_rcvq_pro
   9           0         2          0  0.00%  0.00%  0.00%   0 Timers
  48           0         2          0  0.00%  0.00%  0.00%   0 ARP HA
  49           0         1          0  0.00%  0.00%  0.00%   0 IP Admission HA
  50           0         1          0  0.00%  0.00%  0.00%   0 Network-rf Notif
   6           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Receive
   5           0         1          0  0.00%  0.00%  0.00%   0 Retransmission o
  53        2156  11639870          0  0.00%  0.00%  0.00%   0 Galios Reschedul
  54           0        68          0  0.00%  0.00%  0.00%   0 IOS ACL Helper
  55          36      5092          7  0.00%  0.00%  0.00%   0 BACK CHECK
  56           4         2       2000  0.00%  0.00%  0.00%   0 rf task
   8          20       432         46  0.00%  0.00%  0.00%   0 Pool Manager
  33       10832  44222967          0  0.00%  0.00%  0.00%   0 GraphIt
  41           8        69        115  0.00%  0.00%  0.00%   0 IF-MGR control p
  60           0         1          0  0.00%  0.00%  0.00%   0 cpf_process_tpQ
  61           0         1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  62          16     28443          0  0.00%  0.00%  0.00%   0 Transport Port A
  63       57488  13247053          4  0.00%  0.00%  0.00%   0 HC Counter Timer
  64           0         1          0  0.00%  0.00%  0.00%   0 SFF8472
  65           0         2          0  0.00%  0.00%  0.00%   0 Ethernet OAM Pro
  66           0         1          0  0.00%  0.00%  0.00%   0 PPPOE IA
  67           0         2          0  0.00%  0.00%  0.00%   0 REP Topology cha
  68          92      5357         17  0.00%  0.00%  0.00%   0 Auth Manager
  69           0         2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
  70           0         1          0  0.00%  0.00%  0.00%   0 MAB Framework
  71           0         1          0  0.00%  0.00%  0.00%   0 AUTH POLICY Fram
  72           0         1          0  0.00%  0.00%  0.00%   0 802.1x Webauth F
  73         240      5256         45  0.00%  0.00%  0.00%   0 802.1x switch
  74      371804  26059545         14  0.00%  0.00%  0.00%   0 DTP Protocol
  47           0         2          0  0.00%  0.00%  0.00%   0 IP Host Track HA
  76          32    737608          0  0.00%  0.00%  0.00%   0 Port-Security
  77           0         2          0  0.00%  0.00%  0.00%   0 Ethernet CFM
  78       12424  43365159          0  0.00%  0.00%  0.00%   0 Ethernet Timer C
  79           0         2          0  0.00%  0.00%  0.00%   0 EFP Errd
  80      931900  61243677         15  0.00%  0.00%  0.00%   0 UDLD
  81           0         2          0  0.00%  0.00%  0.00%   0 IP Host Track Pr
  82           0         1          0  0.00%  0.00%  0.00%   0 Switch Backup In
  83          36    737606          0  0.00%  0.00%  0.00%   0 MMN bkgrd proces
  84           0         1          0  0.00%  0.00%  0.00%   0 powernet proxy t
  85      831628  10711219         77  0.00%  0.00%  0.00%   0 powernet proxy u
  57           0         1          0  0.00%  0.00%  0.00%   0 RF High Priority
  87         152      6144         24  0.00%  0.00%  0.00%   0 AAA Server
  88         152      5272         28  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  89           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  90           0         1          0  0.00%  0.00%  0.00%   0 AAA System Acct
  91           0         1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
  92          16    147546          0  0.00%  0.00%  0.00%   0 IP Admin SM Proc
  93      832224  39463483         21  0.00%  0.01%  0.00%   0 CDP Protocol
  94        2200      4383        501  0.00%  0.00%  0.00%   0 SpanTree Helper
  95         144    741857          0  0.00%  0.00%  0.00%   0 Call Home Timer
  96           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  97          44    368905          0  0.00%  0.00%  0.00%   0 DHCP Snooping
  98           0         2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
  99           0         3          0  0.00%  0.00%  0.00%   0 CEF switching ba
   4           0         1          0  0.00%  0.00%  0.00%   0 Deferred Events
101           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
102       31448  86403356          0  0.00%  0.00%  0.00%   0 IP ARP Track
103      124348    976356        127  0.00%  0.00%  0.00%   0 ADJ resolve proc
104           0         1          0  0.00%  0.00%  0.00%   0 IPv6 Echo event
105           4        17        235  0.00%  0.00%  0.00%   0 SNMP Timers
  58      186284  13096602         14  0.00%  0.00%  0.00%   0 Net Input
107          12       518         23  0.00%  0.00%  0.00%   0 SXP CORE
108       10568    947377         11  0.00%  0.00%  0.00%   0 CEF background p
  59      162016  10074213         16  0.00%  0.00%  0.00%   0 Compute load avg
  75           0         1          0  0.00%  0.00%  0.00%   0 EAP Framework
111           0         1          0  0.00%  0.00%  0.00%   0 IPC LC Message H
112           0         1          0  0.00%  0.00%  0.00%   0 XDR RP Ping Back
113          40    370046          0  0.00%  0.00%  0.00%   0 XDR RP backgroun
114           0         1          0  0.00%  0.00%  0.00%   0 XDR RP Test Back
115        1308    231004          5  0.00%  0.00%  0.00%   0 TCP Timer
116         304      3131         97  0.00%  0.00%  0.00%   0 TCP Protocols
117       12816  51379172          0  0.00%  0.00%  0.00%   0 Socket Timers
118       24812    312924         79  0.00%  0.00%  0.00%   0 HTTP CORE
119          32    553208          0  0.00%  0.00%  0.00%   0 Cluster L2
120         648   4426034          0  0.00%  0.00%  0.00%   0 Cluster RARP
121           0         1          0  0.00%  0.00%  0.00%   0 COPS
122           0         1          0  0.00%  0.00%  0.00%   0 Probe Input
123         324      5357         60  0.00%  0.00%  0.00%   0 RARP Input
124           0         2          0  0.00%  0.00%  0.00%   0 REP LSL Proc
125           0         2          0  0.00%  0.00%  0.00%   0 REP BPA/EPA Proc
126           0         1          0  0.00%  0.00%  0.00%   0 Critical Auth
127         840     16842         49  0.00%  0.00%  0.00%   0 L2MM
128          72      2852         25  0.00%  0.00%  0.00%   0 MRD
129         176      5543         31  0.00%  0.00%  0.00%   0 IGMPSN
130           0         1          0  0.00%  0.00%  0.00%   0 IGMPQR
131         460     16695         27  0.00%  0.00%  0.00%   0 MLDSN L2MCM
132           0         1          0  0.00%  0.00%  0.00%   0 MRD
133           0         1          0  0.00%  0.00%  0.00%   0 MLD_SNOOP
134           0         2          0  0.00%  0.00%  0.00%   0 L2TRACE SERVER
135           0         1          0  0.00%  0.00%  0.00%   0 IGMPSN-HA
136           0         1          0  0.00%  0.00%  0.00%   0 DHCP Snooping HA
137           0         2          0  0.00%  0.00%  0.00%   0 ATIP_UDP_TSK
138        8636    976445          8  0.00%  0.00%  0.00%   0 IP Background
139        1160    737696          1  0.00%  0.00%  0.00%   0 IP RIB Update
140     2104944  93977541         22  0.00%  0.01%  0.00%   0 DHCPD Receive
141           0         1          0  0.00%  0.00%  0.00%   0 HSRP HA
  86         560   4425501          0  0.00%  0.00%  0.00%   0 Ethchnl
143           0        11          0  0.00%  0.00%  0.00%   0 ADJ background
144           0         1          0  0.00%  0.00%  0.00%   0 CFMPAL Process
145           0         1          0  0.00%  0.00%  0.00%   0 EPM MAIN PROCESS
146           0         1          0  0.00%  0.00%  0.00%   0 EM Background Pr
147           0        90          0  0.00%  0.00%  0.00%   0 LOCAL AAA
148           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
149           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
150          36        47        765  0.00%  0.00%  0.00%   0 Collection proce
151       18944     59176        320  0.00%  0.00%  0.00%   0 TPLUS
152           4        12        333  0.00%  0.00%  0.00%   0 crypto engine pr
153           0         1          0  0.00%  0.00%  0.00%   0 encrypt proc
154           0         4          0  0.00%  0.00%  0.00%   0 Crypto CA
155           0         1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
156           0         1          0  0.00%  0.00%  0.00%   0 Crypto SSL
157           0         2          0  0.00%  0.00%  0.00%   0 VTPMIB EDIT BUFF
158           0         2          0  0.00%  0.00%  0.00%   0 DHCP Security He
159           0         2          0  0.00%  0.00%  0.00%   0 DiagCard1/-1
160           0         2          0  0.00%  0.00%  0.00%   0 DiagCard2/-1
161           0         2          0  0.00%  0.00%  0.00%   0 DiagCard3/-1
162           0         3          0  0.00%  0.00%  0.00%   0 Online Diag EEM
163      218280 268909915          0  0.00%  0.00%  0.00%   0 PM Callback
   3           0         1          0  0.00%  0.00%  0.00%   0 CEF RP IPC Backg
165         356   3554755          0  0.00%  0.00%  0.00%   0 dhcp snooping sw
166           4        55         72  0.00%  0.00%  0.00%   0 VTP Trap Process
167        6284  22124889          0  0.00%  0.00%  0.00%   0 System polling
168           0         1          0  0.00%  0.00%  0.00%   0 DATA Transfer Pr
169           0         1          0  0.00%  0.00%  0.00%   0 DATA Collector
170       17056     63159        270  0.00%  0.00%  0.00%   0 SpanTree Flush
171         240      2932         81  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
172        1744       796       2190  0.00%  0.00%  0.00%   0 Syslog Traps
173           0         2          0  0.00%  0.00%  0.00%   0 CTS HA
174           0         1          0  0.00%  0.00%  0.00%   0 Online Diag CNS
175           0         1          0  0.00%  0.00%  0.00%   0 Online Diag CNS
176          16        35        457  0.00%  0.00%  0.00%   0 SPAN switch
177           0        48          0  0.00%  0.00%  0.00%   0 EEM Server
178           0         2          0  0.00%  0.00%  0.00%   0 EEM ED POWERNET
179         412   2198764          0  0.00%  0.00%  0.00%   0 IP SLAs MPLSLM P
180           0         1          0  0.00%  0.00%  0.00%   0 IP SLAs Ethernet
181           0         1          0  0.00%  0.00%  0.00%   0 IP SLAs AutoEthe
182           8      1342          5  0.00%  0.00%  0.00%   0 Syslog
183           4         2       2000  0.00%  0.00%  0.00%   0 Call Home proces
184           0         2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
185           0         3          0  0.00%  0.00%  0.00%   0 EEM ED CLI
186           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Config
187           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Counter
188           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Env
189           4         3       1333  0.00%  0.00%  0.00%   0 EM ED GOLD
190           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Interface
191           0         3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
192           0         3          0  0.00%  0.00%  0.00%   0 EEM ED None
193           0         3          0  0.00%  0.00%  0.00%   0 EEM ED OIR
194           0         3          0  0.00%  0.00%  0.00%   0 EEM ED RF
195           0         3          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
196           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Snmp_Prox
197           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Test
198         916   1116021          0  0.00%  0.00%  0.00%   0 EEM ED Timer
199           0         3          0  0.00%  0.00%  0.00%   0 EEM ED RPC
200           0         3          0  0.00%  0.00%  0.00%   0 RBM CORE
201           4         3       1333  0.00%  0.00%  0.00%   0 IPv6 RIB Event H
202           0      4106          0  0.00%  0.00%  0.00%   0 TACACS+
   2        2060   8851252          0  0.00%  0.00%  0.00%   0 Load Meter
110           0         3          0  0.00%  0.00%  0.00%   0 XDR mcast
205     1445848  17598493         82  0.00%  0.00%  0.00%   0 IP SNMP
206      477276   6006368         79  0.00%  0.00%  0.00%   0 PDU DISPATCHER
207          32         5       6400  0.00%  0.00%  0.00%   0 crypto sw pk pro
208          68    368875          0  0.00%  0.00%  0.00%   0 DHCPD Timer
209          36    737611          0  0.00%  0.00%  0.00%   0 DHCPD Database
210           0        61          0  0.00%  0.00%  0.00%   0 EIGRP: Router
211     4207392 130558106         32  0.00%  0.00%  0.00%   0 EIGRP-IPv4:
   1       39996  64998393          0  0.00%  0.00%  0.00%   0 Chunk Manager
213     4090440   6645843        615  0.00%  0.00%  0.00%   0 SNMP ENGINE
214           0         1          0  0.00%  0.00%  0.00%   0 IP SNMPV6
215           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
216       45620      7186       6348  0.00%  0.00%  0.00%   0 SNMP Traps
109           0         1          0  0.00%  0.00%  0.00%   0 IP IRDP
SW-02#sh processes memory sorted
Processor Pool Total:  484854164 Used:  168349696 Free:  316504468
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0  139410788    3457092  124550644          0          0 *Init*
   0   0 2239848368 2108158920   31616904    2035252          0 *Dead*
  52   0    1863136     473884    1144756          0          0 Cat4k Mgmt LoPri
  14   0    3687356   24290540     565108          0          0 ARP Input
140   0    5862072        180     514796      43092          0 DHCPD Receive
  51   0 2080905856 2310085372     476596       2268          0 Cat4k Mgmt HiPri
142   0     263768        336     269208          0          0 CEF: IPv4 proces
  20   0     230560          0     266484      99792          0 EEM ED Syslog
139   0     220024       2872     253076          0          0 IP RIB Update
213   0 3026264904 4282440928     196140     855036          0 SNMP ENGINE
  74   0     560356      56216     186820          0          0 DTP Protocol
177   0     153332          0     186256          0          0 EEM Server
164   0   53382740   52961464     183304      29556          0 VLAN Manager
211   0     177184      81084     120316          0          0 EIGRP-IPv4:
  56   0     146556          0     113632          0          0 rf task
150   0      65864       3060     104720          0          0 Collection proce
  82   0      71308          0     104232          0          0 Switch Backup In
  19   0      79516      63000      95804          0       9880 Entity MIB API
183   0      98704      22032      95404          0          0 Call Home proces
163   0    7791100   17918472      75160          0          0 PM Callback
218   1      23244      12388      72032          0          0 Virtual Exec
131   0    3079844   94131992      64756          0          0 MLDSN L2MCM
127   0      31800    3692548      63784          0          0 L2MM
204   0      64720      10600      63264          0          0 HSRP IPv4
   1   0    4597588 4049847300      59496          0          0 Chunk Manager
203   0      63964      52428      58920          0          0 HSRP Common
  93   0  906824204  906802112      57040          0          0 CDP Protocol
152   0      57164       1836      53008          0          0 crypto engine pr
103   0   16418748        180      51528          0          0 ADJ resolve proc
121   0          0          0      50924          0          0 COPS
  12   0          0          0      50924          0          0 Crash writer
118   0   93454584   93483920      47700       6804          0 HTTP CORE
210   0          0          0      44192          0          0 EIGRP: Router
125   0      10224        180      42968          0          0 REP BPA/EPA Proc
  41   0       9640      65724      42420          0          0 IF-MGR control p
184   0       9676        832      41768          0          0 EEM Policy Direc
107   0       2084      48308      40828          0          0 SXP CORE
154   0       7276       1424      40776          0          0 Crypto CA
100   0   23756336    1924656      40500      36288          0 IP Input
  35   0      66904          0      39980          0          0 Net Background
205   0 3333936716 3332815336      39856          0          0 IP SNMP
214   0        876          0      39800          0          0 IP SNMPV6
216   0   37179528   37094660      39800      79380          0 SNMP Traps
194   0       3892         72      39744          0          0 EEM ED RF
188   0       3724          0      39648          0          0 EEM ED Env
197   0       3724          0      39648          0          0 EEM ED Test
187   0       3724          0      39648          0          0 EEM ED Counter
178   0       3724          0      39648          0          0 EEM ED POWERNET
185   0       3724          0      39648          0          0 EEM ED CLI
190   0       3724          0      39648          0          0 EEM ED Interface
199   0       3724          0      39648          0          0 EEM ED RPC
191   0       3724          0      39648          0          0 EEM ED IOSWD
192   0       3724          0      39648          0          0 EEM ED None
193   0       3724          0      39648          0          0 EEM ED OIR
198   0       3724          0      39648          0          0 EEM ED Timer
195   0       3724          0      39648          0          0 EEM ED SNMP
186   0       3724          0      39648          0          0 EEM ED Config
196   0       3724          0      39648          0          0 EEM ED Snmp_Prox
189   0       3724          0      39648          0          0 EM ED GOLD
115   0    2173048   32212536      39200          0          0 TCP Timer
108   0        544        552      39140          0          0 CEF background p
  99   0        396        180      39140          0          0 CEF switching ba
200   0        596        380      39140          0          0 RBM CORE
215   0          0          0      38924          0          0 SNMP ConfCopyPro
  18   0          0          0      38924          0          0 Policy Manager
206   0 1257219996      65160      38924          0          0 PDU DISPATCHER
  36   0 2182340644 2182340644      38924          0          0 IDB Work
182   0     286368     286368      38924          0          0 Syslog
116   0   58825636       1212      38924          0          0 TCP Protocols
  37   0        180        180      38924          0          0 Logger
  78   0        180        180      38924          0          0 Ethernet Timer C
  77   0        180        180      38924          0          0 Ethernet CFM
138   0     661880     642652      36888          0          0 IP Background
151   0   25861060   17355908      36436      61236          0 TPLUS
201   0          0          0      35924          0          0 IPv6 RIB Event H
  49   0          0          0      35924          0          0 IP Admission HA
  65   0        180        180      35924          0          0 Ethernet OAM Pro
  47   0        180        180      35924          0          0 IP Host Track HA
  98   0        180        180      35924          0          0 EAPoUDP Process
109   0          0          0      35924          0          0 IP IRDP
  81   0        180        180      35924          0          0 IP Host Track Pr
  38   0    1224792      59428      35924          0          0 TTY Background
102   0        180        180      35924          0          0 IP ARP Track
134   0       2880        180      35624          0          0 L2TRACE SERVER
  85   0 1746386148 1746383296      35580          0          0 powernet proxy u
156   0          0          0      34924          0          0 Crypto SSL
155   0          0          0      34924          0          0 Crypto PKI-CRL
207   0      23968      24288      34924          0          0 crypto sw pk pro
  27   0       1688          0      34612          0          0 IPC Seat Manager
  80   0 2338318396 2338313360      34328          0          0 UDLD
  94   0   19028016    2740220      33260          0          0 SpanTree Helper
168   0        216          0      33156          0          0 DATA Transfer Pr
  76   0        216          0      33140          0          0 Port-Security
174   0        216          0      33140          0          0 Online Diag CNS
143   0        216          0      33140          0          0 ADJ background
169   0        216          0      33140          0          0 DATA Collector
162   0      59016      59232      33140          0          0 Online Diag EEM
   3   0        216          0      33140          0          0 CEF RP IPC Backg
209   0        216          0      33140          0          0 DHCPD Database
175   0        216          0      33140          0          0 Online Diag CNS
106   0  132885468     136184      33140      37068          0 Spanning Tree
  10   0       1636       1636      32992          0          0 PrstVbl
202   0      26672          0      32972          0          0 TACACS+
  90   0          0          0      32948          0          0 AAA System Acct
105   0          0          0      32940          0          0 SNMP Timers
101   0          0          0      32924          0          0 ICMP event handl
  89   0          0          0      32924          0          0 ACCT Periodic Pr
  55   0          0          0      32924          0          0 BACK CHECK
104   0          0          0      32924          0          0 IPv6 Echo event
  13   0          0          0      32924          0          0 ifIndex Receive
  54   0          0          0      32924          0          0 IOS ACL Helper
  68   0        180        180      32924          0          0 Auth Manager
  88   0          0          0      32924          0          0 AAA ACCT Proc
110   0          0          0      32924          0          0 XDR mcast
111   0          0          0      32924          0          0 IPC LC Message H
112   0          0          0      32924          0          0 XDR RP Ping Back
113   0          0          0      32924          0          0 XDR RP backgroun
114   0          0          0      32924          0          0 XDR RP Test Back
  53   0          0          0      32924          0          0 Galios Reschedul
  67   0        180        180      32924          0          0 REP Topology cha
117   0          0          0      32924          0          0 Socket Timers
119   0        180        180      32924          0          0 Cluster L2
120   0          0          0      32924          0          0 Cluster RARP
  16   0          0        380      32924          0          0 AAA_SERVER_DEADT
122   0          0          0      32924          0          0 Probe Input
123   0          0          0      32924          0          0 RARP Input
  87   0        180        180      32924          0          0 AAA Server
  97   0          0          0      32924          0          0 DHCP Snooping
126   0          0          0      32924          0          0 Critical Auth
  96   0        204        204      32924          0          0 AAA Dictionary R
  95   0          0          0      32924          0          0 Call Home Timer
129   0          0          0      32924          0          0 IGMPSN
  91   0          0          0      32924          0          0 Auth-proxy AAA B
  48   0          0          0      32924          0          0 ARP HA
132   0          0          0      32924          0          0 MRD
  57   0          0          0      32924          0          0 RF High Priority
  86   0        180        180      32924          0          0 Ethchnl
  84   0          0          0      32924          0          0 powernet proxy t
  83   0          0          0      32924          0          0 MMN bkgrd proces
137   0        180        180      32924          0          0 ATIP_UDP_TSK
  66   0          0          0      32924          0          0 PPPOE IA
   9   0        180        180      32924          0          0 Timers
   8   0          0    6532656      32924          0    2845904 Pool Manager
141   0          0          0      32924          0          0 HSRP HA
   7   0          0        196      32924          0          0 Check heaps
  15   0          0          0      32924          0          0 CEF MIB API
  73   0          0    1035628      32924          0          0 802.1x switch
145   0          0          0      32924          0          0 EPM MAIN PROCESS
146   0          0          0      32924          0          0 EM Background Pr
147   0      11816        180      32924          0          0 LOCAL AAA
148   0        180        180      32924          0          0 ENABLE AAA
149   0        180        180      32924          0          0 LINE AAA
   6   0          0          0      32924          0          0 IPC ISSU Receive
  72   0          0          0      32924          0          0 802.1x Webauth F
  11   0        180        180      32924          0          0 Serial Backgroun
153   0          0          0      32924          0          0 encrypt proc
  46   0          0          0      32924          0          0 cpf_msg_rcvq_pro
  79   0        180        180      32924          0          0 EFP Errd
  69   0        180        180      32924          0          0 Dot1x Mgr Proces
157   0        180        180      32924          0          0 VTPMIB EDIT BUFF
158   0        180        180      32924          0          0 DHCP Security He
159   0         76        312      32924          0          0 DiagCard1/-1
160   0         76        312      32924          0          0 DiagCard2/-1
161   0         76        312      32924          0          0 DiagCard3/-1
  92   0          0          0      32924          0          0 IP Admin SM Proc
   5   0          0          0      32924          0          0 Retransmission o
   4   0          0          0      32924          0          0 Deferred Events
165   0        180        180      32924          0          0 dhcp snooping sw
166   0        180       5008      32924          0          0 VTP Trap Process
  70   0          0          0      32924          0          0 MAB Framework
  75   0          0          0      32924          0          0 EAP Framework
133   0          0          0      32924          0          0 MLD_SNOOP
170   0          0   64187360      32924          0          0 SpanTree Flush
171   0    1106852    2236260      32924          0          0 AAA SEND STOP EV
172   0    2380784    2380784      32924          0          0 Syslog Traps
173   0        180        180      32924          0          0 CTS HA
124   0        180        180      32924          0          0 REP LSL Proc
  50   0          0          0      32924          0          0 Network-rf Notif
176   0      41212      42284      32924          0          0 SPAN switch
  58   0          0          0      32924          0          0 Net Input
  45   0          0          0      32924          0          0 cpf_msg_holdq_pr
179   0          0          0      32924          0          0 IP SLAs MPLSLM P
180   0          0          0      32924          0          0 IP SLAs Ethernet
181   0          0          0      32924          0          0 IP SLAs AutoEthe
128   0       1692       1692      32924          0          0 MRD
130   0          0          0      32924          0          0 IGMPQR
  44   0          0          0      32924          0          0 PrstVbl IPC Msg
  43   0          0          0      32924          0          0 ISSU PROCESS IPC
  42   0          0          0      32924          0          0 IF-MGR event pro
  40   0          0      10608      32924          0          0 Per-minute Jobs
  39   0  405316584  405816008      32924          0          0 Per-Second Jobs
135   0          0          0      32924          0          0 IGMPSN-HA
  64   0          0          0      32924          0          0 SFF8472
  63   0          0          0      32924          0          0 HC Counter Timer
  34   0          0          0      32924          0          0 Critical Bkgnd
  33   0        180        180      32924          0          0 GraphIt
  32   0          0          0      32924          0          0 Dynamic ARP Insp
  31   0          0          0      32924          0          0 ARP Snoop
  30   0          0          0      32924          0          0 SERIAL A'detect
  29   0          0          0      32924          0          0 client_entity_se
  28   0          0          0      32924          0          0 IPC Session Serv
  71   0          0          0      32924          0          0 AUTH POLICY Fram
  62   0          0    2481100      32924          0          0 Transport Port A
136   0          0          0      32924          0          0 DHCP Snooping HA
144   0          0          0      32924          0          0 CFMPAL Process
  26   0          0          0      32924          0          0 IPC Deferred Por
  25   0          0          0      32924          0          0 IPC Managed Time
  24   0          0          0      32924          0          0 IPC Periodic Tim
  61   0          0          0      32924          0          0 AggMgr Process
  23   0          0          0      32924          0          0 IPC Zone Manager
208   0          0          0      32924          0          0 DHCPD Timer
  59   0        204        204      32924          0          0 Compute load avg
212   0          0          0      32924          0          0 EIGRP-IPv4: Hell
  22   0          0          0      32924          0          0 IPC Dynamic Cach
  17   0        180        180      32924          0          0 AAA high-capacit
  21   0          0          0      32924          0          0 IFS Agent Manage
  60   0          0          0      32924          0          0 cpf_process_tpQ
   2   0        180        180      29924          0          0 Load Meter
167   0          0          0      29924          0          0 System polling
   0   0      13372  156246696      13372          0          0 *Sched*
                                168305816 Total
-JM
