How configure two ADSL links on the Cisco router 2911?
Geovane Freitas
How to set up two ADSL links on the Cisco router 2911?
I have two ADSL links connected to the Cisco router, Dinamyc IP link that is working in giga interface 0/2 with IP DHCP, this works perfectly. Now you need to set up another fixed IP PPP link in Giga 0/1 and already configured using Authentication pap, he of the success message in using Authentication but I can not even give a ping to any external host.
brianw2
I want to make sure I'm understanding you correctly. You have DHCP setup for gi0/2 on the 2911 that is working correctly, and you are having trouble setting up gi0/1 as a PPP link with PAP authentication on this same 2911 device? Can you provide me with the running configuration that you have on the 2911?
