How Do Static NAT exemption
martinbuffleo
Level 5
Level 5
I have a branch office VPN configured:
Site A 192.168.0.0/24
Site B 192.168.2.0/24
Site A also host my mail server so I have this static NAT rule.
ip nat inside source static tcp 192.168.1.99 25 interface GigabitEthernet0/0 25
This all works fin for the ourside world.
How ever I think this NAT rule is stopping device at 192.168.2.0/24 from being able to connect to the SMTP service
Can I convert this to a route map that denys the NAT for connection from 192.168.2.0/24 but allows for a source of "any"
Peter Paluch
I am slightly confused by the fact that your SiteA uses 192.168.0.0/24 while the static PAT is configured for 192.168.1.99 - is there perhaps a typo?
Anyway, is the GigabitEthernet0/0 using a static IP address? If yes, you can use its IP address in the ip nat inside source command which will allow you to refer to a route-map afterwards.
ip access-list extended NAT
  deny ip any 192.168.2.0 0.0.0.255
  permit ip any any
route-map NAT permit 10
  match ip address NAT
ip nat inside source static tcp 192.168.1.99 25 X.X.X.X 25 route-map NAT
Here, replace X.X.X.X with the IP address of the GigabitEthernet0/0 interface.
This configuration makes sure that when responses from your SMTP server are received by your NAT box, it will first check whether they are addressed to SiteB 192.168.2.0/24. If they are, the NAT won't be performed.
Best regards,
Peter
EDIT: Added a missing tcp keyword to the ip nat inside command.
Peter Paluch
  permit ip any any
Best regards,
Peter
Thank you very much for the reply. Sorry for the confusing typo.
That helpped me out greatly.
One little correction I had to add tcp to enable me to specifiy port 25.
Have implemented and tested and it works a treat.
Thanks again
Oh, yes, thank you! You're completely right. Sorry for the typo - adding it to my answer now.
Best regards,
Peter
