How Many private network cisco 2800 supports
ThomasMull9000
Hello guys , i have two cisco 2800 routers ,  and i have three differnet networks , so can cisco routers supports more than one private network example
My First localation i have one public connection of 200.100.100. 1 and private network of 192.168.1.x network
and the second router i have one public connecion of 200.100.100.10 and two private networkos of 192.168.50.x  and 192.168.60.x ,  So can i route my first location to this two different networks , because my router have only two FastEthernet connection , so how it's possbile or not .. thank you guys
In this scenario, create a site to site ipsec VPN. It is very simple.
After VPN configuration you will be able to communicate with each networks in these two routers.
Please let me know if you need any further help.
Rate this if it is helpful
Vipin
Thanks and Regards, Vipin
vipinrajrc
Level 3
Level 3
Is these two routers are connected together? if it so then configure staic routes to reach other networks.
Could you please provide a sample diagram of this scenario.
Vipin
Here is my scenerio , please find the atttachment file
thank very much for you reply
Vipin
