How NAT works in this design?
paulnigel
Hi forum,
we were given this network design in order to integrate with another company's network. Network A is our network running EIGRP, Network B is our partner's network running EIGRP as well.
R1(router) will policy route traffic that has been changed to 172.16.0.0 to R2, and will policy route those conflicting IP address to R3 before going to R2.
How should I configure my DNS in this case? How NAT actually works in this case?
Thanks much,
pn
Pavel Bykov
Level 5
Level 5
DNS in your network should point to translated addresses of the other network.
NAT works both ways in this example, so devices in one network communicate to OUTSIDE LOCAL address, which is translated afterwards to the OUTSIDE GLOBAL.
In your example:
Perspective 1:
NET1 192.168.0.0/16 = inside local
NET1 172.16.0.0/16 = outside local
NET2 192.168.0.0/16 = outside global
NET2 172.16.0.0/16 = inside global
Perspective 2 is reversed.
These two documents will help you understand the concept better:
http://www.cisco.com/en/US/customer/products/ps6640/products_white_paper09186a0080091cb9.shtml
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f30.shtml
Hope this helps.
Plese rate all helpful posts.
