How to config MPLS with DHCP
zavira123
hi, i am novice in MPLS
please help me to config below scenario , i want to config DHCP service on CE router (in picture:: CE2: Customer B )
which other CE (like CE1) can get IP address
assume that we have different IP range
i want to enable DHCP only on CE router Not on PE
if possible please please put me sample config :)
tnx a lot
Peter Paluch
Hi zavira123,
I am not entirely sure what you are trying to accomplish. Do you want your CE routers to obtain their own IP addresses on the CE/PE links using DHCP? Is this a real-life scenario you are trying to solve, or is this just a lab or a homework assignment? Usually, the CE/PE links are configured statically for MPLS VPNs.
Best regards,
Peter
mziyada
Hi Zavira,,
check this web site where you can see an example that is similar to your case.
http://www.cisco.com/c/en/us/td/docs/ios/12_2/12_2b/12_2b4/feature/guide/12b_dhc.html
