How to set IP-SLA failure values
JW_UK
I have a basic UDP-Jitter IP-SLA test:
ip sla 1
 udp-jitter 1.1.5.1 5000
 request-data-size 96
 response-data-size 96
 threshold 1
 timeout 100
 frequency 5
branch1#sh ip sla statistics
IPSLAs Latest Operation Statistics
IPSLA operation id: 1
Type of operation: udp-jitter
        Latest RTT: 4 milliseconds
Latest operation start time: 14:40:34 UTC Tue May 19 2020
Latest operation return code: Over threshold
RTT Values:
        Number Of RTT: 10               RTT Min/Avg/Max: 2/4/8 milliseconds
Latency one-way time:
        Number of Latency one-way Samples: 0
        Source to Destination Latency one way Min/Avg/Max: 0/0/0 milliseconds
        Destination to Source Latency one way Min/Avg/Max: 0/0/0 milliseconds
Jitter Time:
        Number of SD Jitter Samples: 9
        Number of DS Jitter Samples: 9
        Source to Destination Jitter Min/Avg/Max: 0/4/7 milliseconds
        Destination to Source Jitter Min/Avg/Max: 0/4/6 milliseconds
Over Threshold:
        Number Of RTT Over Threshold: 10 (100%)
Packet Loss Values:
        Loss Source to Destination: 0
        Source to Destination Loss Periods Number: 0
        Source to Destination Loss Period Length Min/Max: 0/0
        Source to Destination Inter Loss Period Length Min/Max: 0/0
        Loss Destination to Source: 0
        Destination to Source Loss Periods Number: 0
        Destination to Source Loss Period Length Min/Max: 0/0
        Destination to Source Inter Loss Period Length Min/Max: 0/0
        Out Of Sequence: 0      Tail Drop: 0
        Packet Late Arrival: 0  Packet Skipped: 0
Voice Score Values:
        Calculated Planning Impairment Factor (ICPIF): 0
        Mean Opinion Score (MOS): 0
Number of successes: 21
Number of failures: 0
Operation time to live: Forever
I can see that although I have set a threshold of “1” (milliseconds) the IP-SLA has not failed because the responder is still reachable, albeit responding Over threshold.
I would like to configure the IP-SLA test to fail if, for example:
  • RTT >=10ms
  • Packet Loss <1%
  • Latency one-way time <50ms
Is this possible, or is the failure merely UP/DOWN ?
Thanks!
Hello
  • RTT >=10ms
  • Packet Loss <1%
In your case SLA has logged jitter as being over the specified threshold however the number of failures hasn't incremented here as this will be down to the reachabiliy of the responder and that is okay no reported source/destination drops, loss etc..
Kind Regards
Paul
Hi @paul driver
Thanks for your reply, that was my conclusion too, so the IP-SLA will only fail when the responder is unreachable.
It seems like a missed opportunity, but do you agree it is not possible to make the IP-SLA fail using, for example, RTT >=10ms ?
Thanks!
