HSRP Packet Issues
david-swope
I am at a site and have an interesting HSRP situation between two 7200 routers. These routers are running v15.0(1)M3 (AdvSecurity) IOS and configured interfaces are both G0/2 on each router.
They are laid out as shown in the attached drawing, nothing out of the ordinary there.
Configs are as follows
R1
interface GigabitEthernet0/2
description Nunya
ip address x.x.x.2 x.x.x.x.x
ip access-group 101 in
ip flow ingress
duplex auto
speed auto
media-type rj45
negotiation auto
standby 100 ip x.x.x.1
standby 100 priority 110
standby 100 preempt delay minimum 30
R2
description Nunya
ip address x.x.x.3 x.x.x.x
duplex auto
speed auto
media-type rj45
negotiation auto
standby 100 x.x.x.1
standby 100 priority 105
R1#sh standby br
                     P indicates configured to preempt.
Interface   Grp  Pri   P   State      Active       Standby         Virtual IP
Gi0/2       100  110  P   Active     local          unknown        x.x.x.1
R2#sh standby brief
Gi0/2       100  105  P    Standby   x.x.x.2         local              x.x.x.1
Debug output from R1
Jan 20 2014 09:30:54.178 CST: HSRP: Gi0/2 Grp 100 Hello  out x.x.x.2 Active  pri 110 vIP x.x.x.1
Jan 20 2014 09:30:59.154 CST: HSRP: Gi0/2 Grp 100 Hello  out x.x.x.2 Active  pri 110 vIP x.x.x.1
Jan 20 2014 09:31:01.795 CST: HSRP: Gi0/2 Grp 100 Hello  out x.x.x.2 Active  pri 110 vIP x.x.x.1
Jan 20 2014 09:31:04.723 CST: HSRP: Gi0/2 Grp 100 Hello  out x.x.x.2 Active  pri 110 vIP x.x.x.1
Jan 20 2014 09:31:07.155 CST: HSRP: Gi0/2 Grp 100 Hello  out x.x.x.2 Active  pri 110 vIP x.x.x.1
Debug output from R2
Jan 20 2014 09:31:23.447 CST: HSRP: Gi0/2 Grp 100 Hello  out x.x.x.3 Standby pri 105 vIP x.x.x.1
Jan 20 2014 09:31:23.459 CST: HSRP: Gi0/2 Grp 100 Hello  in  x.x.x.2 Active  pri 110 vIP x.x.x.1
Jan 20 2014 09:31:25.879 CST: HSRP: Gi0/2 Grp 100 Hello  out x.x.x.3 Standby pri 105 vIP x.x.x.1
Jan 20 2014 09:31:25.971 CST: HSRP: Gi0/2 Grp 100 Hello  in  x.x.x.2 Active  pri 110 vIP x.x.x.1
Jan 20 2014 09:31:28.451 CST: HSRP: Gi0/2 Grp 100 Hello  in  x.x.x.2 Active  pri 110 vIP x.x.x.1
Jan 20 2014 09:31:28.455 CST: HSRP: Gi0/2 Grp 100 Hello  out x.x.x.3 Standby pri 105 vIP x.x.x.1
Jan 20 2014 09:31:29.127 CST: HSRP: Gi0/2 Interface adv out, Passive, active 0 passive 1
Here is what I have done. I have specifically added a permit statement to ACL 101 on R1 for 224.0.0.2 port 1985, it still does nothing. I then added the same to R2 just to see the hit count increase, it did of course although the ACL is not needed, more of a visual way for me to track it. On the end of each ACL 101 there is a "permit ip any any"
I made sure both sides had appropriate priorities, preempt statements. The routers have been rebooted and the next thing I could remove HSRP all together from G0/2 on R1 and add it back. It's simply an odd issue, is it buggy IOS perhaps?  Switches are configured the same, can find nothing wrong there.
23 Replies 23
Richard Burts
The debug is pretty clear that R1 sees outbound HSRP but no inbound. My first question would be what does CDP show on each router? Does R1 see R2 as a neighbor on G0/2? My second question would be whether the routers can traceroute to each other and if so is the response coming back from G0/2?
Rick
Rick
David
Apologies for interrupting the thread.
Rick
Could i ask you a favour. I have been involved in a thread where i seem to be going round in circles and cannot understand exactly how things are working.
If possible could you have a look at it and see if it makes sense to you because it doesn't to me but it could be my lack of understanding -
https://supportforums.cisco.com/thread/2262246?tstart=0
Many thanks.
Jon
Sorry, should have put that data in the first post
CDP shows
R1#sh cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
Sw1
                 Gig 0/2            168          S I      WS-C2960G Gig 0/15
R2#sh cdp neighbors
Sw2
                 Gig 0/2            150          S I      WS-C2960G Gig 0/15
R1#traceroute x.x.x.3
Tracing the route to x.x.x.3
  1  *  *
    x.x.x.3 0 msec
R1#
R1#ping x.x.x.3
Sending 5, 100-byte ICMP Echos to x.x.x.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
R1#
R2#traceroute x.x.x.2
Tracing the route to x.x.x.2
  1 x.x.x.2 0 msec *  0 msec
R2#
R2#ping x.x.x.2
Sending 5, 100-byte ICMP Echos to x.x.x.2, timeout is 2 seconds:
There is obviously an issue with pinging the vIP as shown here
R1#ping x.x.x.1
Sending 5, 100-byte ICMP Echos to x.x.x.1, timeout is 2 seconds:
R1#
R2#ping x.x.x.1
Success rate is 0 percent (0/5)
R2#
David,
could you do one more ping on R2:
ping 224.0.0.2 source gi0/2
just to see if R1 responds?
Rolf
R1#ping 224.0.0.2 source g0/2
Sending 1, 100-byte ICMP Echos to 224.0.0.2, timeout is 2 seconds:
Packet sent with a source address of x.x.x.2
Reply to request 0 from x.x.x.3, 1 ms
R1#
R2#ping 224.0.0.2 source g0/2
Packet sent with a source address of x.x.x.3
Richard Burts
That certainly is interesting and suggests a one way issue with multi cast. Your earlier test shows that we have good two way communication for unicast. It might be interesting to see the output of show ip interface g0/2 from both routers.
I also wonder if there might be something in the configuration of the switches that might cause this.
Rick
Rick
Yeah, an interesting issue to say the least, it's going to be something i've over looked. I can feel it. ha
R1#
sh ip interface g0/2
GigabitEthernet0/2 is up, line protocol is up
  Internet address is x.x.x.2/x
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Multicast reserved groups joined: 224.0.0.2
  Outgoing access list is not set
  Inbound  access list is 101
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP CEF turbo switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is disabled
  BGP Policy Mapping is disabled
  Input features: Ingress-NetFlow, Access List, MCI Check
  Output features: Post-Ingress-NetFlow
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
R2#sh ip int g0/2
  Internet address is x.x.x.3/x
  MTU is 1500 bytes
  Input features: Access List, MCI Check
Richard Burts
David
Thanks for this output. But what I asked for was show ip interface and not just show interface.
Rick
Rick
Oops, there you go..edited post above
David
Thanks for the updated output. I had hoped that it would have some insight into the issue. But other than demonstrating that both have "Multicast reserved groups joined: 224.0.0.2"  it does not have much clue (at least that I can detect). One more request: would you post the access-list 101 from both routers?
Rick
Rick
I agree, I see nothing at this point and almost at a loss..here are the ACL's
R1#sh access-lists
Standard IP access list 1
    10 permit x.x.x.x, wildcard bits 0.0.0.255
Standard IP access list 2
Extended IP access list 101
    10 permit tcp x.x.x.x 0.0.1.255 x.x.x.x 0.0.1.255 eq 22 (7498 matches)
    20 permit udp x.x.x.x 0.0.1.255 x.x.x.x 0.0.1.255 eq ntp
    30 permit udp host x.x.x.x x. x.x.x 0.0.1.255 eq ntp (2095 matches)
    40 permit udp x.x.x.x 0.0.1.255 host x.x.x.x eq ntp (2265 matches)
    50 permit udp x.x.x.x 0.0.1.255 x.x.x.x 0.0.1.255 eq snmp (475234 matches)
    70 deny tcp any host x.x.x.x eq 22 (43 matches)
    80 deny udp any host x.x.x.x eq snmp (6 matches)
    100 deny tcp any host x.x.x.x eq 22 (92 matches)
    110 deny udp any host x.x.x.x eq ntp
    120 deny udp any host x.x.x.1 eq snmp (3 matches)
    130 deny tcp any host x.x.x.x.2 eq 22 (204 matches)
    140 deny udp any host x.x.x.x.2 eq ntp (1 match)
    150 deny udp any host x.x.x.2 eq snmp (3 matches)
    160 permit ip any any (732299596 matches)
R2#sh access-lists
    10 permit x.x.x.x, wildcard bits 0.0.0.255 (1 match)
    10 permit tcp x.x.x.x 0.0.1.255 x.x.x.x0.0.1.255 eq 22 (10586 matches)
    30 permit udp host x.x.x.x x.x.x.x 0.0.1.255 eq ntp (2 matches)
    40 permit udp x.x.x.x 0.0.1.255 host x.x.x.x eq ntp (31 matches)
    50 permit udp x.x.x.x 0.0.1.255 x.x.x.x 0.0.1.255 eq snmp (494446 matches)
    60 permit udp host x.x.x.2 host 224.0.0.2 eq 1985 (97910 matches)
    80 deny udp any host x.x.x.x eq ntp
    90 deny udp any host x.x.x.x eq snmp
    100 deny tcp any host x.x.x.1 eq 22
    110 deny udp any host x.x.x.1 eq ntp
    130 deny tcp any host x.x.x.3 eq 22 (88 matches)
    140 deny udp any host x.x.x.3 eq ntp
    150 deny udp any host x.x.x.3 eq snmp (3 matches)
    160 permit ip any any (90446403 matches)
Highlighted the ACL I put in place to get a visual on the hit count for the multicast traffic for HSRP, added and removed from R1 with no hits of course
David
Have you checked your switch configurations eg. specifically do you have any port acls applied to any of the interfaces that are part of the path between the routers.
Also worth checking if the switches are using VACLs which could be blocking multicast one way.
Jon
Yeah, I have checked the switches..there are several ACL's on the 2nd switch to which R2 is connected but nothing affecting this issue
Sw2#sh ip int g0/9
GigabitEthernet0/9 is up, line protocol is up
  Inbound  access list is not set
access-list 103 deny tcp host x.x.x.x eq 1723 any
access-list 103 permit ip any any
access-list 178 deny udp any eq ntp host x.x.x.x
access-list 178 permit ip any any
Connection to R1
interface GigabitEthernet0/9
description R1
switchport access vlan x
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
Connection to R2
description R2
I also want to mention that there have been some ARP issues with these routers recently, wondering if this IOS is buggy? (C7200P-ADVSECURITYK9-M) Version 15.0(1)M3
David
Thanks for the additional information. I am wondering about the possibility that something on some switch is causing the issue. Perhaps some CGMP/IGMP config? I am wondering if we can try some other multicast traffic and see if it is impacted. Perhaps something like trying to run EIGRP or OSPF on these two router interfaces? We do not need to advertise anything, but it would be interesting to see if R1 receives the multicast hello from R2.
Rick
Rick
