Http core
lalgee.albert
We have two connections to an ISP. one with serial links and the other with FSO link. Whenever i am trying to shift the FSO as primary using BGP. My CPU process shows 100%. Http core is taking the almost 96%. Please help.
18590 97.67% 97.73% 97.31% 0 HTTP CORE
regards
mheusing
Rerouting itself should not have any relation to HTTP in a router.
BUT: next time, please give info about hardware, IOS version and if possible the relevant portions of the config.
So without detailed info a guess: did you disable http server and https server?
no ip http server
no ip http secure server
This could maybe cure the problem. Be aware, that you will not be able to use f.e. SDM or other HTTP related access to the router, if executing the command above.
Hope this helps!
Regards, Martin
Amit Singh
Do you have any authentication proxy configured on the router? Do you have " ip http server" enabled on the router? If yes, then try disabling it " no ip http server ", " no ip http secure-server" and see if it makes any difference.
Please paste the config for more insight on this.
-amit singh
