HWIC-4T Question
kurtzhalsm
If I have a 2801 with a HWIC-4t and 3 remote p2p connections off it what kind of wic will I need at the remote 2801s. Will I need HWICs there also. Thanks
tdrais
Level 7
Level 7
Cisco would like you to buy them I'm sure. You should be able to use a wic-1t if you like. There are very few wic interfaces that are not supported on the 2800. You can run wic cards in a hwic slot but not the other way around.
