I encountered an issue while activating the smart license.
yunus1996
Hello Community,
Recently, I encountered an issue when uploading and activating the license on the Cisco C1111-8P ISR device.
I found that the current IOS-XE 17 version no longer supports using the command license install xxxx.lic to install and activate the license.
I referred to the following link:
Configure Smart Licensing Using Policy on Cisco IOS XE Routers - Cisco
Since my ISR router is in an offline environment and I do not have access to CSSM, I chose the activation method "Router not Connected to the CSSM and Without CSLU in Place."
However, I found that with this solution, I encountered an error when entering a command: "The requested item was not found."(As shown in the image below). The version of the ISR router is IOS XE 17.09.05a.
However, I used another ISR of the same model, with the version IOS XE 17.12.03. I found that the command license smart save usage all file bootflash:all_rum.txt can be successfully entered and generates the all_rum.txt file.
I want to know why this is happening.
How to resolve this ?
AshSe
Hey @yunus1996
The issue you're encountering is related to the changes in Cisco's Smart Licensing Using Policy (SLP) framework and the specific IOS-XE versions running on your Cisco ISR devices. Let me break this down and provide a solution.
Why This Is Happening:
  1. Smart Licensing Using Policy (SLP):
    • Starting with IOS-XE 17.3.2, Cisco introduced Smart Licensing Using Policy, which changes how licenses are managed and activated. The traditional license installcommand is no longer supported in these versions.
    • Instead, licenses are managed through Smart Licensing Using Policy, which requires either a connection to Cisco Smart Software Manager (CSSM) or an offline workflow.
  2. Version-Specific Behavior:
    • In IOS-XE 17.9.x (e.g., 17.09.05a), there may be a bug or limitation in the implementation of the offline workflow for Smart Licensing Using Policy. This could explain why the license smart save usage all file bootflash:all_rum.txtcommand fails with the error "The requested item was not found."
    • In IOS-XE 17.12.x (e.g., 17.12.03), Cisco has likely resolved this issue, allowing the command to work as expected and generate the all_rum.txt file.
  3. Command Behavior:
    • The license smart save usage all command is used to generate a usage report (RUM report) for offline environments. If the command fails, it indicates that the router is unable to retrieve the required licensing information, possibly due to a bug or incomplete implementation in the specific IOS-XE version.
How to Resolve This:
To resolve the issue, you have a few options:
Option 1: Upgrade to a Newer IOS-XE Version
  • Since the issue does not occur in IOS-XE 17.12.03, the simplest solution is to upgrade your ISR router to this version or a later stable release.
  • Upgrading will ensure that the license smart save usage all command works correctly and generates the required all_rum.txt file for offline activation.
Option 2: Use an Alternative Workflow
If upgrading is not an option, you can try the following steps:
  1. Verify Smart Licensing Configuration:
    • Ensure that Smart Licensing Using Policy is properly configured on the router. Use the following commands to check the status:
      show license status
      show license summary
    • Confirm that the router is in the correct licensing mode (e.g., Transport Mode: Offfor offline environments).
  2. Manually Generate the RUM File:
    • If the license smart save usage all command fails, try generating the RUM file manually using the following command:
      license smart save usage file bootflash:manual_rum.txt
    • This command may work as an alternative to the all option.
  3. Check for Known Bugs:
    • Review the Cisco Bug Search Tool (https://bst.cloudapps.cisco.com/bugsearch/) for any known issues with IOS-XE 17.09.05a related to Smart Licensing Using Policy. If a bug is identified, Cisco may provide a workaround or recommend an upgrade.
Option 3: Open a Cisco TAC Case
  • If the issue persists and upgrading is not feasible, consider opening a case with Cisco Technical Assistance Center (TAC). Provide them with the following details:
    • The exact IOS-XE version (17.09.05a).
    • The commands you attempted and the error messages received.
    • The licensing mode and configuration of the router.
  • Cisco TAC can confirm if this is a known issue and provide guidance or a patch.
Recommendations:
  • Preferred Solution: Upgrade to IOS-XE 17.12.03 or later, as this version resolves the issue and ensures compatibility with Smart Licensing Using Policy.
  • Alternative: Use the manual RUM file generation command or consult Cisco TAC for further assistance.
Hope This Helps!!!
AshSe
Forum Tips:
  1. Insert photos/images inline - don't attach.
  2. Always mark helpful and correct answers, it helps others find what they need.
  3. For a prompt reply, kindly tag @name. An email will be automatically sent to the member.
Thank you for your answer. However, because our upstream supplier's SA account does not have the relevant permissions for the smart license, we downgraded the router version to IOS-XE 16.09 to resolve this issue.
