I need help with this VLAN assessment
c1200761
I need help of packet tracer of this.
3 sites must be included in the network (plus 1 internet connection on the Cambridge site). Each site will have to allow bandwidth for at least: Cambridge 600 hosts London 900 hosts Manchester 1200 hosts An addressing table is to be included in the finished report. With the rapid change in-laws this year, all sites must be secured with strong passwords and only allow safe connection methods on each site. (check labs for securing switches and routes to see what’s deemed as safe) The company has also heard that switches are great for scaling and segmenting network traffic. Please use them in your design. redundancy should also be considered. All 3 sites must have three V LAN: V LAN 10 labelled “IT” V LAN 20 labelled “HR” V LAN 30 labelled “Consulting”
The choice of how you wish to segment the layer 2 networks, is for you to decide and justify why you picked it. Each site must have a routing protocol that you must justify and have working. Due to the previous problems of services going down, the company wants a method for the network to function, even if the dynamic routing has gone down. The line speed on all serial lines must be set to 64000. There is an internet connection that is set in Cambridge and sent out via the internal network. However, due to the sensitive work from the Manchester branch, they are not allowed to access the internet at any time. The company also wants each user's end device to have an IP address set automatically. To get an idea of what the company currently has (though you are to add), an image has been provided for you below:The choice of how you wish to segment the layer 2 networks, is for you to decide and justify why you picked it. Each site must have a routing protocol that you must justify and have working. Due to the previous problems of services going down, the company wants a method for the network to function, even if the dynamic routing has gone down. The line speed on all serial lines must be set to 64000. There is an internet connection that is set in Cambridge and sent out via the internal network. However, due to the sensitive work from the Manchester branch, they are not allowed to access the internet at any time. The company also wants each user's end device to have an IP address set automatically. To get an idea of what the company currently has (though you are to add), an image has been provided for you below:
Hello
Please review the attach file.
Kind Regards
Paul
Do you have packet tracer file for this?
Hello
No i dont, However you should be able to create yourself with the information i have supplied.
Kind Regards
Paul
