ILP
innojohn69
What is an ilp power supply in a cisco 2801 router?
Mark Malone
its an inline power supply , unlike say a 3750 x that would have hot swappable power supplies that can be easily replaced , you would need to completely open up a 2801 to replace the ps
heres how you do it
http://www.cisco.com/c/en/us/td/docs/routers/access/2800/hardware/installation/guide/hw/10_hw.html#wp1151075
Thank you.
I have configured all my dhcp, nat, and access lists but i cant figure out why i cannot connect to the host to get internet. Below is my sh ip route and sh ip int brief.
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.0.1
is directly connected, FastEthernet0/0
192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.0.0/24 is directly connected, FastEthernet0/0
L 192.168.0.6/32 is directly connected, FastEthernet0/0
192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.2.0/24 is directly connected, FastEthernet0/1
L 192.168.2.1/32 is directly connected, FastEthernet0/1
Router#sh ip int bri
FastEthernet0/0 192.168.0.6 YES DHCP up up
FastEthernet0/1 192.168.2.1 YES manual up up
NVI0 192.168.0.6 YES unset up up
if you post your running config il take a look , wont be able to tell something like that from the route table,need to see what way its been setup
Thank you. I did figure out what was  wrong with my configurations.
