Implement a Redundancy Link
alsayed
Hi All
I've a site connected to the H.Q.i just need to implement a Redundancy Link to H.Q.Trough Route-Map(Primary Link it will be Wirless Link;The second it wil be Leased line)so PLS Can u list the config of the router(2620S) in the Site.
!I Think Pareh was list the config,But i dont know where.
10xs for ur reply
Ali
pratik.rb
Level 3
Level 3
If the purpose of having a redundant link is backup, then you can manipulate the cost of the other link if you are using a dynamic routing protocol or by increasing AD if using static route. This should effectively utilize your primary link & upon failure utilize the secondary link.
PBR (route-map) are used more when you want to policy some specific traffic thru one link & some specific traffic thru other.
Please provide more details on your setup & current config.
Pls rate posts...
Pratik
10xs for ur reply. the Purpose of having redundant link is sure the backup.The config not ready yet also the whole design design.this why i've consulting in this great form to advising me to the Optimum Solution.if u have like this situation what u will do. PS list Ur config
10xs
Again
Hi Ali,
For LAN redundant design you can plan for etherchannel , STP, HSRP or GLBP
Have a look at these links
For HSRP with topolgy and configuration guide
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12120ea2/3550scg/swhsrp.htm
For STP with topology and config guide
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12120ea2/3550scg/swstp.htm
For etherchannel config and guide
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12120ea2/3550scg/swethchl.htm
For wan design consideration
http://www.cisco.com/en/US/netsol/ns206/networking_solutions_white_paper0900aecd801229a6.shtml
HTH, if yes please rate the post.
Ankur
Hi ankurbhasin
PS Can u list to me ur Prospective Config for the router in the site and that in the H.Q,if u have this Envirment
10XS 4 UR Reply
Ali
