Implementing cisco ASA
Addey Salameh
Community Member
Hi guys
i've recently bought a cisco asa 5506-x and i need to implement it in my network ,but i have multiple sites connected together through DMVPN
and i want to put the firewall behind the hub as described in the screenshot, also all spokes must be able to reach the server that is connected to r1 and the network that have the ASA, so guys i need help any ideas please 😄
8 Replies 8
I typically prefer a slightly different setup:
  • The DMVPN-network is connected the same way to the internet as shown.
  • The ASA also has a link to the ISP and a Link to the WAN (which is the DMVPN in your case).
  • The router R1 is connected to another interface of the ASA
With that setup the DMVPN-hup doesn't have to deal both with branch- and internet-traffic. The ASA can do the NAT for all other services. The setup of the DMVPN-hub will be greatly simplified by that.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
ok karsten i didn't get, so you mean to replace the asa with the hub (put the asa in front of the DMVPN hub ?)
no not in front of the hub:
  • Both the ASA and the DMVPN hub are connected to the ISP.
  • The hub is connected to an additional interface of the ASA
Traffic flows would be:
PC1 -> sw1 -> (inside) ASA (outside) -> ISP -> Internet-destination
PC1 -> sw1 -> (inside) ASA (WAN)  -> hub -> spoke
PC1 -> sw1 -> (inside) ASA (DMZ)  -> r1 -> server
thank you karsten ,your thoughts are really good ,but the problem is i don't have the server physically and i can't do any configuration on router r1 because they belong to the government (i only have r1 in my site to give me route to that server so some employees can access it from different branches) so my dilemma is if i put the ASA as in diagram this will create another network which it will replace my HUB-LAN in the DMVPN ,in this situation i guess i need some routes from the ASA to the hub and vice versa , or (i guess i let the ASA to participate in the DMVPN how about it??)
Still, I'm not really sure what your problem is.
But more general:
The ASA can't participate in your DMVPN-setup; and why should the ASA do that as a firewall? All DMVPN-related stuff will be handled by the hub-router.
To be more clear, this is the setup I was talking about that could simplify your setup:
Your DMVPN tunnel is going to be established through Internet?
If yes, the HUB and ASA locations are fine. You just need to create a DMZ on ASA and move the server behind the DMZ.
Inside zone-client,
Outside zone:HUB and internet
DMZ:server.
If you have license limitation, you can put server and client mixed in one zone and HUB and Internet in another zone to prevent your server to be attacked from Internet.
Or you can put server behind the inside zone and connect client directly to HUB router and control them by access-list on HUB.
Hope it helps,
Masoud
thank you masoud ,your thoughts are really good ,but the problem is i don't have the server physically and i can't do  any configuration on router r1 because they belong to the government (i only have r1 in my site to give me route to that server so some employees can access it from different branches)
ASA does not support DMVPN. If r1 is working now, it means it has route toward spokes and hubs. You can disconnect r1 from hub and connect it to ASA.
r1--ASA-hub.
Then you will put the current IP address of HUB on ASA, so packet will route toward ASA(Same IP address). You need to create DMZ zone on ASA for that.
If you have limitation in ASA license or government router, your topology seems fine to me.
I supposed spokes connect to HUB through Internet.
ASA will have a default route toward HUB and HUB a return route toward client to ASA. And some access-lists on ASA. Thats all you need to do.
Client will connect to ASA inside zone.
Hub will connect to ASA outside zone.
Hope it helps,
Masoud
