Implementing Two ISP Public IP Blocks
axiollc
Client has moved ISPs and has been provided two public IP blocks, a /29 "WAN block" and a /28 "LAN block".  We initially utilized the single WAN IP provided by the ISP /29 "WAN block", but we now need to utilize additional public addresses made available via the ISP's /28 "LAN block".  I would like some input on how we would implement the /28 public IP block with our existing configuration, basically chaning the NAT IPs from using the default single WAN ip to the provided /28 public ips for the network objects that have inbound open ports (smtp, webmail, etc.) and some that connect outbound (smtp).  Redacted config follows.  Any input would be greatly appreciated.
ASA Version 8.6(1)2
hostname pi
domain-name $$$$$$.$$$
enable password @@@@@@@ encrypted
passwd @@@@@@@@ encrypted
names
interface GigabitEthernet0/0
 nameif WAN
 security-level 0
 ip address x.x.124.34 255.255.255.252
interface GigabitEthernet0/1
 nameif LAN
 security-level 100
 ip address 192.168.0.253 255.255.255.0
interface GigabitEthernet0/2
 nameif LANMAC
 security-level 50
 ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/5
 nameif GUEST
 security-level 10
 ip address 192.168.254.1 255.255.255.0
interface Management0/0
 nameif management
 security-level 100
 management-only
boot system disk0:/asa861-2-smp-k8.bin
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns domain-lookup WAN
dns domain-lookup LAN
dns domain-lookup LANMAC
dns domain-lookup GUEST
dns domain-lookup management
dns server-group DefaultDNS
 name-server 192.168.0.240
 name-server d.d.d.d
 name-server d2.d2.d2.d2
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network gwava_smtp
 host 192.168.0.252
object network gwava_123
 host 192.168.0.252
object network gwava_ssh
 host 192.168.0.252
object network sanderling_https
 host 192.168.0.241
object service gwavaRAS
 service tcp destination eq 49282
object service sandRAS
 service tcp destination eq 6523
object network gwava_ras
 host 192.168.0.252
object network sanderling_ras
 host 192.168.0.241
object service SSLvpn
 service tcp destination eq 6666
object network NETWORK_OBJ_192.168.168.0_26
 subnet 192.168.168.0 255.255.255.192
object network NETWORK_OBJ_192.168.0.0_24
 subnet 192.168.0.0 255.255.255.0
object network sanderling_https_nat
 host 192.168.0.241
object network RSAPort5500
 host 192.168.0.254
 description RSA
object network RSAport7004
 host 192.168.0.254
 description RSA
object network RSAport7072
 host 192.168.0.254
 description RSA
object network WAN
 host x.x.124.34
object network RSAServer
 host 192.168.0.254
object service 7004
 service tcp source eq 7004
object network RSAport7004_1
 host 192.168.0.254
object network LANVPN_Network
 subnet 192.168.168.0 255.255.255.0
 description VPN Clients
object network Merganser
 host 192.168.0.240
 description Merganser DNS
object-group network BLOCKLIST
 network-object host 95.213.157.141
 network-object host 46.4.193.146
 network-object host 65.15.88.243
 network-object host 185.104.11.154
 network-object host 185.104.9.39
object-group service RDP tcp
 description Remote Desktop
 port-object eq 3389
object-group protocol TCPUDP
 protocol-object udp
 protocol-object tcp
access-list WAN_access_in_1 extended permit udp any host 192.168.0.254 eq 5500
access-list WAN_access_in_1 extended permit tcp any host 192.168.0.254 eq 7072
access-list WAN_access_in_1 extended permit tcp any host 192.168.0.254 eq 7004
access-list WAN_access_in_1 extended permit tcp any object gwava_smtp eq smtp
access-list WAN_access_in_1 extended permit udp any object gwava_123 eq ntp
access-list WAN_access_in_1 extended permit tcp any object gwava_ssh eq ssh
access-list WAN_access_in_1 extended permit tcp any object sanderling_https eq https
access-list WAN_access_in_1 extended permit tcp any object sanderling_ras eq 6523
access-list WAN_access_in_1 extended permit tcp any object gwava_ras eq 49282
access-list WAN_access_in_1 extended permit object SSLvpn any any
access-list WAN_access_in_1 extended deny ip object-group BLOCKLIST any
access-list ****_Tunnel_splitTunnelAcl standard permit 192.168.0.0 255.255.255.0
access-list global_access extended permit tcp 192.168.0.0 255.255.255.0 any eq www
access-list global_access extended permit ip 192.168.0.0 255.255.255.0 any
access-list global_access extended permit object-group TCPUDP object Merganser any eq domain
access-list global_access extended permit tcp object LANVPN_Network 192.168.0.0 255.255.255.0 object-group RDP
pager lines 24
logging enable
logging buffer-size 20000
logging buffered debugging
logging asdm informational
mtu WAN 1500
mtu LAN 1500
mtu LANMAC 1500
mtu GUEST 1500
mtu management 1500
ip local pool ****_VPN 192.168.168.1-192.168.168.50 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-66114.bin
no asdm history enable
arp timeout 14400
nat (LAN,WAN) source static RSAport7004_1 interface service 7004 7004
nat (LAN,WAN) source static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 destination static
NETWORK_OBJ_192.168.168.0_26 NETWORK_OBJ_192.168.168.0_26
 nat (LAN,WAN) static interface service tcp smtp smtp
 nat (LAN,WAN) static interface service udp ntp ntp
 nat (LAN,WAN) static interface service tcp ssh ssh
 nat (LAN,WAN) static interface service tcp 49282 49282
 nat (LAN,WAN) static interface service tcp 6523 6523
 nat (WAN,WAN) dynamic interface
 nat (LAN,WAN) static interface service tcp https https
 nat (LAN,WAN) static interface service udp 5500 5500
 nat (LAN,WAN) static interface service tcp 7072 7072
nat (LAN,WAN) after-auto source dynamic any interface
nat (LANMAC,WAN) after-auto source dynamic any interface
nat (GUEST,WAN) after-auto source dynamic any interface
access-group WAN_access_in_1 in interface WAN
access-group global_access global
route WAN 0.0.0.0 0.0.0.0 x.x.124.33 1
no snmp-server location
no snmp-server contact
dhcpd address 192.168.0.100-192.168.0.149 LAN
dhcpd dns 192.168.0.240 interface LAN
dhcpd domain $$$$$$.$$$ interface LAN
dhcpd enable LAN
dhcpd address 192.168.2.50-192.168.2.99 LANMAC
dhcpd dns 75.75.75.75 75.75.76.76 interface LANMAC
dhcpd enable LANMAC
dhcpd address 192.168.254.50-192.168.254.99 GUEST
dhcpd dns 75.75.75.75 75.75.76.76 interface GUEST
dhcpd enable GUEST
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:796c435fd57ac64dcbddd4f99159dafd
: end
pi#
here is an example (I hope this is what you are trying to do): 192.168.0.1 is the inside host, and 212.12.10.1 the outside IP address from your pool. The static NAT entry is for TCP 80 to 8080.
ASA(config)# object network ISP_STATIC_1
ASA(config-network-object)# host 212.12.10.1
ASA(config-network-object)# object network LAN_HOST_1
ASA(config-network-object)# host 192.168.0.1
ASA(config-network-object)# nat (inside,outside) static ISP_STATIC_1 service tcp 80 8080
14 Replies 14
Julio E. Moisa
Both blocks were provided to the client by the same ISP, they are public IP ranges, is that correct?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yes.
I think your ISP is providing both blocks over the same VLAN (1 block /29 as primary and the second block /28 is configured as secondary under the same vlan), so you dont need big changes, you can use the other block /28 like you do with primary for the NATs. Both blocks will use the same gateway.
Exactly.  However, I'm unsure how to write the NAT config for the internal server objects to use the new /28 ip addresses, inbound and outbound.
I think you should not change the current config, you could create static NAT with range /28.
Yes, my thoughts too, but how would I rewrite these existing NATs to use a specific ip of the /28 block?
Just replace "interface" with the ip and subnet?  Create and address object with the /28 IP address and reference that?
Please forgive my ignorance here.
That looks right, and I was thinking it could be that easy.
Essentially, the existing /29 public IP on the outside (WAN) interface and its GW are what we need to use.  I'm assuming that the ISP routes the separate /29 network IPs to our router (though the /29 subnet is a completely different network from the /28).
I just was concerned the ASA would balk at sending or receiving packets with a previously undefined public IP address (meaning not bound to an interface, etc.).
However, do I need to define the /28 pool anywhere in the ASA before setting a host object with an IP from the /28 public address from which to NAT?
you only need the pool object if you would use it for dynamic NAT. For just static NAT, you can use the example I gave you earlier.
Well, Georg and Julio, you guys are great.  I felt it was likely that simple, but I couldn't resolve the "text book" examples I had seen into changes for this config.
A very big thank you for your responses.  I'll try it out in the running config, and revert to the startup if it fails to work.
Not sure if I can set two correct answers, but I will try. ;-)
Thanks again!
You are welcome, please keep us posted. Always remember get a backup.
Worked perfectly, of course after adding the access permit rule.
Thanks again!
at the very least, if I understand your setup correctly, you need a network object defining the /28 block of IP addresses:
object network ISP_POOL
 range 212.12.10.1 212.12.10.14
Then, add the dynamic NAT entry to your network object defining the LAN:
 nat (INSIDE, OUTSIDE) dynamic ISP_POOL
Yes, and dynamic would be fine for clients browsing etc.  Just not sure about configuring that for static ips from the /28 block for internal server objects with inbound smtp, webmail, vpn (anyconnect) authing through an rsa, etc.  Also outbound smtp needs to be a static address from the /28 block.  I understand the examples, just trying to make it work with the existing config.
