Integration
vinod.pandita
I want to integrate two Networks
LAN A------- 134.65.32.0/20
LAN B--------134.65.47.0/24
Router B has spare Eth port.
How packets will be routed between LAN A and LAN B .
Please specify the config .
rais
Level 7
Level 7
There is an overlap between the two networks. LAN B is part of LAN A. Cisco will not let you assign these networks on the same router.
Thanks.
See Rais I guess you have not understood LAN A and LAN B
LAN A---- Router A LAN
LAN B----- Router B LAN
minumathur
both the Network are overlap , and only singel routing entry is generated ,i.e 134.65.32.0/20, so when packet is confuse where to go and also cisco could not allow you to put the ip address , it is overlap.
-Minu
