Inter VLAN Routing Using a Multilayer Switch
Stuart D
Visitor
I've been trying to setup inter vlan routing using a multilayer switch, however I'm having some trouble getting it working.
I've followed a couple of tutorials I've read online but still can't get it to work. It will ping within the same vlan, but not across different vlans.
One thing I've been unable to do is use the 'switchport trunk encapsulation dot1q' command on the layer 2 switch trunk ports. I'm not sure what this command does though, so I don't know if it's needed.
Can anyone help with this?
Here are the configs for the two layer 2 switches and the multilayer switch:
Switch1:
interface Port-channel1
switchport mode trunk
interface FastEthernet0/1
channel-group 1 mode active
interface FastEthernet0/2
interface FastEthernet0/10
switchport access vlan 10
switchport mode access
interface FastEthernet0/11
switchport access vlan 20
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0001.97c3.a001
ip address 192.168.10.1 255.255.255.0
interface Vlan20
mac-address 0001.97c3.a002
ip address 192.168.20.1 255.255.255.0
interface Vlan30
mac-address 0001.97c3.a004
ip address 192.168.30.1 255.255.255.0
interface Vlan40
mac-address 0001.97c3.a005
ip address 192.168.40.1 255.255.255.0
Switch 2:
interface Port-channel2
channel-group 2 mode active
switchport access vlan 30
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0007.ecc6.3901
interface Vlan20
mac-address 0007.ecc6.3902
interface Vlan30
mac-address 0007.ecc6.3903
interface Vlan40
mac-address 0007.ecc6.3904
Multilayer Switch:
interface Port-channel3
interface Port-channel4
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
channel-group 3 mode active
interface FastEthernet0/6
interface FastEthernet0/7
channel-group 4 mode active
interface FastEthernet0/8
interface GigabitEthernet0/1
no switchport
ip address 10.1.1.1 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0002.1658.5d01
interface Vlan20
mac-address 0002.1658.5d02
interface Vlan30
mac-address 0002.1658.5d03
interface Vlan40
mac-address 0002.1658.5d04
Here's the section of the topology I'm configuring:
-Stuart
Hi @Stuart D ,
Review your exercise and I found these details about concepts:
-The VLAN interface of the L2 switches is only for administration, so you should not assign the VLAN gateway in that interface.
In the administration interface, a valid ip of the VLAN must be assigned, as well as a gateway for the switch:
As you see in the image, I deleted all the VLAN interfaces that were not the administration one and assigned it the VLAN gateway(I changed the gateway IP, I'll explain why later).
I replicated this process on all the L2 switches in your topology.
-In the two switch L3 you had the same IP configured in the VLAN interfaces.
If you want to achieve redundancy, this is incorrect, since the devices do not know which of these L3 is his gateway.
To achieve redundancy in this topology, you must use the HSRP protocol, which assigns a virtual gateway to the devices (192.168.x.100) and assigns roles (active / standby) to the L3 switches:
The L3 switch on the left will remain as active, so in the L3 switch on the right the same commands are entered, except the priority one, since it is already 100 by default:
Sorry if I went long, but I wanted to explain the concepts.
I enclose the exercise with the changes.
10 Replies 10
Alan Ng'ethe
Level 7
Level 7
ISL encapsulation which would be the other type of encapsulation in addition to dot1q, is deprecated. Therefore when you configure encapsulation, dot1q is the only encapsulation supported. You can verify the encapsulation type by using the command show interfaces trunk.
As for not being able to ping across vlans, please ensure the ip routing command is enabled on the multi-layer switch
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
Hi Alan,
Thanks for the response. I've just double checked an I do have ip routing enabled. Both vlans are configured on the multilayer switch and the ports are both set to trunk. I can't think what else could be wrong. I'm fairly new to this, so I could be missing something
Hello
This is a duplicate post  with the below and you have marked that has solved?
https://community.cisco.com/t5/switching/implementing-vlans-in-a-hierarchical-design/m-p/3846450#M464604
Kind Regards
Paul
Hi Paul,
Sorry for the confusion. Previously I was trying to communicate within the same VLAN which I was able to get working. Now I'm playing around with trying to get PCs within different VLANs to communicate with each other. I'm still very new to this, so I may have used the wrong terminology. This is the first network I've attempted to setup outside of the Cisco lessons.
-Stuart
Hi @Stuart D ,
Could you compress your exercise (with Winzip, for example) and attach it to review your settings?
Here it is, I'm currently working on the two left most switches.
Hi @Stuart D ,
Thanks, this is really helpful. I'd been messing around with HSRP but had been unable to get it working so gave up. Thanks for the explanation as well, helps me to understand it too! 🙂
You need to remove all VLAN interfaces from both L2 switches (and leave just one, for management. I created Vlan 101 for that purpose, as it is not recommended to use Vlan 1 for manegement).
Your PCs need to have the default gateway set to the IP addresses of the VLAN interfaces on the L3 switch. So the configs would look like below:
Switch1:
interface Vlan1
no ip address
shutdown
interface Vlan101
description Management Vlan
ip address 192.168.101.1 255.255.255.0
Switch 2:
interface Vlan1
no ip address
shutdown
interface Vlan101
ip address 192.168.101.2 255.255.255.0
Multilayer Switch:
no switchport
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
interface Vlan10
interface Vlan20
interface Vlan30
interface Vlan40
interface Vlan101
ip address 192.168.101.254 255.255.255.0
Hello
Not to worry but FTI - if you look back at that post , I did provide you will a solution that should enable to allow host-host communication within a vlan and between vlans
Kind Regards
Paul
