interface dialer on a layer 3 switch
adi_shakarchi
Community Member
Is it possible to establish a interface dialer on a layar 3 switch?
Or is it only interface for routers?
I have a c3750 switch (WS-C3750G-24T), and when i try to establish a dialer interface i get an error message:
Switch(config)#interface dialer 0
% Invalid input detected at '^' marker.
Thank you.
Giuseppe Larosa
Hello Adi,
a dialer interface is used for PPP or PPPoX (PPPoE, PPPoA and so on) access so it is not likely a multilayer switch supports it as they are considered WAN features supported on SW based routers like ISR, ISR G2
Only PPPoE client could be supported on a multilayer switch but again is seen as a WAN feature.
ISR routers support PPPoE client and also PPPoE server side I tested it on C3725, C3745 for example
you could try to use feature navigator at
http://www.cisco.com/go/fn
search by feature
digit PPPoE in filter by field
select PPPoE client among listed features  press "add" to put in on the right column  and then press "continue" all on  the right
to find supporting platforms you will see that almost all listed devices for IOS are routers
Hope to help
Giuseppe
Giuseppe Larosa
Hello Adi,
search by feature
Hope to help
Giuseppe
Thanks for your fast answer.
I looked at the link you attached, and i saw that 3750 not support pppoe at all, and no matter what IOS version or license.
