Interface Naming Convention
cyee
I recently configured a couple of 1841 routers and used SDM instead of doing it manually. I'm a bit confused as to the naming conventions "chosen" by SDM:
The routers each had a 1dsu WIC in slot 0 and a vanilla 1T in slot 1. SDM named them:
Serial0/0/0 (1dsu)
Serial0/1/0 (1T)
I had been expecting Serial0 and Serial1.
I don't intend to change them, but would appreciate an explanation of the logic behind the "selection". (Could not find docs on CCO.)
TIA
thisisshanky
Level 11
Level 11
You cannot change them.
This link explains in detail.
http://www.cisco.com/en/US/products/hw/routers/ps282/products_tech_note09186a008035b051.shtml
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Shanky (hope your'e not a golfer), thanks for the helpful reference.
Concluding question:
If I want to define a subinterface on S0/0/0,
Would it be S0/0/1, or S0/0/0.1, or S0/0/0/1 or ???
TIA
Curt
I was on a logical path to the answer. Sankar found an excellent link which gave a good technical explanation. I believe that the answer to your concluding question is that a subinterface would be s0/0/0.1. (subinterfaces are always a .x of the major physical interface).
I believe that s0/0/1 would be a different physical interface. And s0/0/0/1 is an entity that logically does not exist.
Rick
Rick
Richard Burts
Curt
I do not know that I have ever seen it written anywhere but I believe that the sinmple integer names like serial 0 and serial 1 were developed especially for the fixed configuration routers where the position of the network cards was fixed and permanent. Cisco developed a more complex and sophisticated naming convention especially for routers with card slots where cards can be inserted and removed and moved around, Cisco generally uses names with x/y format so they can identify which slot and which card element.
Rick
Rick
