INTERNET ISSUES (SLOW)
ojasvi.bansal
I use a Cisco 2611XM with NM1E card. I have dual ISP failover scenario using IP SLA.
The problem is that my internet runs slow. All the people go to one site to enter data.
Here's an output from the router.
FastEthernet0/1 is up, line protocol is up
Hardware is AmdFE, address is XX.XX.XX.XX.XX
Description: SHAW_CABLE
Internet address is XX.XX.XX.XX
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 01:12:56
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 34000 bits/sec, 27 packets/sec
5 minute output rate 43000 bits/sec, 10 packets/sec
66149 packets input, 23647626 bytes
Received 33923 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
36256 packets output, 24405685 bytes, 0 underruns
256 lost carrier, 0 no carrier
interface FastEthernet0/1
description SHAW_CABLE
ip address XX.XX.XX.XX /22
ip verify unicast source reachable-via rx allow-default 100
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
no ip mroute-cache
duplex auto
speed 100
no mop enabled
I have tried using 10/half, 10/full, 100/half, 100/full auto/auto as far as speed and duplex is concerned.
Any help is really appreciated.
OJ
Steve Lyons
Level 4
Level 4
I do not see any errors on your fa0/1 interface. Under config t > int fa0/1 type load 30 and then type show int again and monitor. This will change your show output interval to 30 seconds. You are looking for high utilization. Based on the output you provided above your at approximately 30kbits/sec for egress/ingress. Also under config t > int fa0/1 type no ip virtual-reassembly and test again.
Steve Lyons - Cisco
Thanks Steve,
I did that and it did not change anything. Still users have issue accessing the website.
Any other recommendations?
OJ
I would recommend opening a TAC case.
thiru.vel10
Level 5
Level 5
HI,
1}Try to enable the
IP NAT translation max-entries 100 command in global configuration mode and then monitor the NAT traffic by using command sh ip nat sta.
2} ping the internet gateway and check the latency,
3} ping the Internet IP and check the Latency.
If the internet gateway latency is good means problem with ISP end only so please report this issue to ISP .or
