Internet Link - Load-Balance/Failover
Amin Shaikh
I have Router with 3 Ethernet-ports
ISP1= connected to F0/0
ISP2= connected to F0/1
Inside = connected to LAN F1/1
Is there a way to make load-balancing and Failover for these Internet Link.
The idea behind this is to have Office-executive browse internet with good speed and uninterrupted services....
Currently we have
Internet----<Internet-RTR>------BLUECOAT---<SWitch-connected to LAN>>
I am sorry not....
I think you can use source IP address to load blance.
Best Regards
Cheng
5 Replies 5
vassiliev
This is my Example:
interface Ethernet0/0 (LAN interface)
ip address 10.0.123.1 255.255.255.0
ip nat inside
ip policy route-map MAP1
half-duplex
interface Serial0/0 (WAN interface 1)
ip address 10.0.15.1 255.255.255.0
ip nat outside
encapsulation frame-relay
shutdown
frame-relay map ip 10.0.15.5 100 broadcast
interface Ethernet0/1
no ip address
shutdown
half-duplex
interface Serial0/1 (WAN interface 2)
ip address 10.0.14.1 255.255.255.0
ip nat outside
frame-relay map ip 10.0.14.4 777 broadcast
ip nat inside source route-map NAT1 interface Serial0/1 overload
ip nat inside source route-map NAT2 interface Serial0/0 overload
ip nat inside source route-map NAT3 interface Serial0/0 overload
ip nat inside source route-map NAT4 interface Serial0/1 overload
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.15.5
ip route 0.0.0.0 0.0.0.0 10.0.14.4
access-list 1 permit 10.0.123.3
access-list 2 permit 10.0.123.2
route-map NAT3 permit 10
match ip address 2
match interface Serial0/0
route-map NAT2 permit 10
match ip address 1
route-map NAT1 permit 10
match ip address 1
match interface Serial0/1
route-map MAP1 permit 10
match ip address 1
set interface Serial0/1
route-map MAP1 permit 20
match ip address 2
set interface Serial0/0
route-map NAT4 permit 10
match ip address 2
Best Regards
Cheng
Thanks.
I will check the config on lab and check.
can you let me know what these hosts are 10.0.123.3 // 10.0.123.2 ( bluecoat / proxy-server // cache-engine )
10.0.123.3 and 10.0.123.2 is my test PC ip address. Their default gateway is 10.0.123.1.
Topology looks like this:
PC1 and PC2 connect Switch. Switch connect R1.
R1 lan interface is 10.0.123.1.
R1 have got two internet circuit connect ISP.
In current, PC1 use ISP1 with NAT to access Internet. PC2 use ISP2 with NAT to access Internet.
If ISP1 DOWN! PC1 use ISP2 access Internet. So is PC2.
Best Regards
Cheng
Thanks....
Did you did any test or implemented using hardware based Proxy.
in our scenario all users browse internet using BLUECOAT
I am sorry not....
Best Regards
Cheng
